Author Topic: P0128  (Read 4656 times)
Offline Brazen17
P0128
« on: October 26, 2012, 11:19:42 PM »
Looks like I might be needing a new thermostat...  :mad: Are they easy to change on our cars (GXP)?
Re: P0128
« Reply #1 on: October 27, 2012, 11:39:04 AM »
I dont think so.
Passenger side and back of the engine block kind of a tight spot to get into.
Re: P0128
« Reply #2 on: October 27, 2012, 12:22:10 PM »
Though i do remember reading a how to on the thermostate replacement on one of the forums.
Re: P0128
« Reply #3 on: October 27, 2012, 01:11:38 PM »
It is not that bad to replace on the engine, but we do it by removing the plastic tray at the base of the windshield. There are 6 7mm head screws and a couple push pins that hold it in place, also you take the windshield wipers off and disconnect the windshield washer lines and that entire tray comes off and gives very good access to the back side of the engine and only takes about 5 minutes to do.
Hope that helps,
Dave
Offline Brazen17
Re: P0128
« Reply #4 on: October 27, 2012, 05:42:50 PM »
Hope that helps,
Dave
Thanks Dave! I'll take a look at it.
Re: P0128
« Reply #5 on: October 30, 2012, 12:58:10 PM »
Seems like I remember needed to follow a special purge procedure when opening the coolant system to prevent air bubbles and subsequent overheating.
Any opinions on that Dave?
Thanks!
Brent
Solo HF Cat and Mach Shorty
Dunlop Dirreza *Spec
1987 Buick Grand National
1978 Trans Am
Trifecta Dealer
Re: P0128
« Reply #6 on: October 30, 2012, 01:05:53 PM »
Also, if your car is heating up to 230ish and then will go down in temp all the sudden and then do it again next time you drive it may be an air bubble.  There was a GM fix for that issue and it worked in my car.  You may want to search for those threads.  Also, if your coolant is below the plastic line in the overflow tank that may cause the issue to occur more often.
1978 Trans Am
Trifecta Dealer
Re: P0128
« Reply #7 on: October 30, 2012, 03:07:11 PM »
don't you have to hold the colant tank over your head while filling, dancing on 1 foot chanting "die bubble die"?
Re: P0128
« Reply #8 on: October 30, 2012, 03:32:45 PM »
Yes but in Spanish because you will probably get a wet back, and front too.
Offline Brazen17
Re: P0128
« Reply #9 on: October 30, 2012, 07:12:23 PM »
Problem I have now is the car won't warm up. If I run it hard I can get it to about 180 for a minute or two then it drops back the high 160's. Not sure if you have to use the special procedure (like Critterman uses) or not for the t-stat.
Offline idkfa
  • Violent Jain
  • mostly harmless
    • Make
Re: P0128
« Reply #10 on: October 30, 2012, 09:14:55 PM »
This is the thread I used to change out mine. It's not difficult, just a pita to reach. Especially if one of the clamps is angled wrong.  I had an intermittent ---F temp reading on the DIC and it was a broken seal on the t-stat.
http://www.solsticeforum.com/forum/f64/how-change-thermostat-2-4-a-60727/
Offline Brazen17
Re: P0128
« Reply #11 on: October 31, 2012, 10:10:57 AM »
Thanks idkfa!
Re: P0128
« Reply #12 on: October 31, 2012, 07:20:41 PM »
That's the post I was talking about.
Thanks for finding that!!
Offline Brazen17
Re: P0128
« Reply #13 on: November 02, 2012, 07:52:44 PM »
Last couple of days it seems to be working. I'll keep an eye on it.
