Author Topic: spit & sputtering  (Read 3220 times)
spit & sputtering
« on: December 01, 2012, 10:03:55 PM »
I haven't started the Sol in about a week . Last time I ran it ,it was OK . NOW
I went out and tried to start it and kept turning over ,Turned Off then tried again it started and just kept spiting over & over . Turned it off and tried again now it ran but was missing . Going out in the Morning and put the code reader on it . Any Ideas what codes it might  get ?       :banghead:     :gaah:     :idk:     Never did this Before
Re: spit & sputtering
« Reply #1 on: December 01, 2012, 10:33:13 PM »
Codes would help.  This could be a variety of things
« Reply #2 on: December 02, 2012, 12:21:18 AM »
Dave  ,  My first though was HPFP  I'm not ruling anything out . Will post codes in the Morning
« Reply #3 on: December 02, 2012, 04:45:06 AM »
Check the evap Bobby. Easy check and known to fail quite often
« Reply #4 on: December 02, 2012, 12:35:15 PM »
I've got (1) code and (2) pending .Got P0101code , P0101 and P2178 Pending says MAF or VAF  Low fuel range bank (1)  . Could it be the Plugs to sensors ? Wires are soldered ,Someone was saying the Pins in the connector plugs come loose . Is there a different connector I can get?
« Reply #5 on: December 02, 2012, 02:44:26 PM »
Ok well anyone who wants to send DDMworks money for my engine build is happy to do so.
I need that tool, that will save a lot of time
« Reply #6 on: December 02, 2012, 06:09:00 PM »
Nicely posted in the wrong thread.
Bobby,
Check for leaks in IC plumbing, evap valve,
« Reply #7 on: December 02, 2012, 08:31:06 PM »
OK thanks I did find Oil on bottom of Coupling at the Turbo Elbow . I had DDM powder coat it in Oct. at the Open house . I will pull it off on Monday after work either loose band or hole in Coupling or burrs letting it weep out.
« Reply #8 on: December 06, 2012, 06:49:16 PM »
I cleaned the sensors , took off Hoses ,tightened everything ,Checked for leaks . Reset codes .
            "   SO FAR SO GOOD  "         :yay:         :tool:       :knock:
