Author Topic: Removal of Sky hood vents  (Read 11328 times)
« on: December 14, 2012, 10:57:40 AM »
Does anyone know how to remove the hood vents on the sky/gt ?
any help appreciated
Re: Removal of Sky hood vents
« Reply #1 on: December 14, 2012, 11:41:40 AM »
sawzall works best!
Use a heat gun and push them out. They are just body taped/glued into the hood. a little heat and a push from the bottom side should get them out.
« Reply #2 on: December 14, 2012, 11:47:56 AM »
sawzall works best!
first option: NO
second option: Thanx for the info
« Reply #3 on: December 14, 2012, 12:06:34 PM »
I haven't tried this but I hear hitting a deer will work, what do you think Shiny?
« Reply #4 on: December 14, 2012, 11:09:59 PM »
sawzall works best!
If its the same stuff they used at the Wilmington Plant . once it Hardens it was hell to get loose . Was like a Glue weld
« Reply #5 on: December 15, 2012, 03:49:47 AM »
As far as I know the hood vents can't be removed without breaking them.
« Reply #6 on: December 15, 2012, 04:07:36 PM »
Kelu Its like S/A stated Just hit a Deer or something the same size with Impack
 You know how it works " Murphy's Law " What you hope won't happen WILL
Offline critter
  • Married, 4 grandkids
« Reply #7 on: December 15, 2012, 06:29:04 PM »
and remember - Murphy was an optimist!!!!
Offline miuwdawg65
« Reply #8 on: December 18, 2012, 04:02:36 PM »
I would think a little C4 in the right place would get those off in an instant
"Political Correctness is a doctrine fostered by a delusional, illogical liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."  ~ anonymous
« Reply #9 on: December 18, 2012, 04:35:34 PM »
Is that something you happen to have laying around?  Good luck shipping that to Arabas.
« Reply #10 on: December 18, 2012, 09:30:51 PM »
S/A I'm sure they have C-4 or WD40 or something that will Cut the Glue or what ever Over There
« Reply #11 on: December 18, 2012, 09:59:06 PM »
C4 is nothing like WD40 Bobby.  :roll:
« Reply #12 on: December 18, 2012, 11:36:47 PM »
OK  , I was thinking of the penetrating CRC . Want to desolve it or loosen it not Put it in Orbit . With C-4 It is Best to remove Hood from Car .   :nuts:     :sorry:
« Reply #13 on: December 19, 2012, 03:57:52 PM »
Love to see that video
« Reply #14 on: December 19, 2012, 09:04:20 PM »
It frees rusted fasteners....
Offline RedLine Ronnie
« Reply #15 on: December 19, 2012, 10:52:05 PM »
Had to remove one. only way is a little heat &  a good hard push.from the backside. Be careful to not damage the area around the opening. D40 may help but will make a mess. You may need new retainer plugs for the hood blanket as they damage easy.Also there  are 3 nuts to remove . it is very easy to snap off the plastic nut retainer pins.
« Last Edit: December 19, 2012, 11:00:52 PM by RedLine Ronnie »
« Reply #16 on: December 20, 2012, 02:02:45 AM »
They make a panel popper to remove the retainers off the hood pins to get to the back of the hood .
« Reply #17 on: December 20, 2012, 03:35:30 AM »
thx for your info Redline Ronnie!
« Reply #18 on: May 19, 2013, 05:03:12 AM »
For the record.
Open the hood, remove the underhood blanket push pins and the blanket.
Each vent has two round clips that secure it in place. Remove these. Be carefull they are easy to brake.
Once you have them removed, close the hood.
Mask tape around the vents.
Stick a cutter between the hood and the vent and slide it around the vent to cut the glue tape.
Carefully use a screwdriver to push it off.
I am having some custom ones made soon
Offline bun1t
« Reply #19 on: June 11, 2013, 01:23:31 AM »
I wouldn't take a cutter anywhere near my hood. When I took mine off I used some fishing line.
Heating them up sounds like a good idea too so maybe heating them up and using fishing line would work pretty good
« Reply #20 on: June 11, 2013, 11:02:55 AM »
What size hook?
« Reply #21 on: June 11, 2013, 11:11:37 AM »
I think your going to need a bigger boat GJ
« Reply #22 on: June 11, 2013, 11:50:56 PM »
Nice :)
A classic.
« Reply #23 on: June 12, 2013, 06:43:48 AM »
I think you are not a funny man :(  My car has never been the same since  :'(
« Reply #24 on: June 12, 2013, 01:33:59 PM »
Sorry, I suppose I should have asked Miller.
