Author Topic: P0243  (Read 3537 times)
Offline DirtyMike
P0243
« on: December 29, 2012, 05:41:09 PM »
P0243
Turbocharger Wastegate Solenoid Control Circuit
i have no boost..would work and lose boost and come back again for sometime then nothing, removed the turbo and sent it for repair, new seals,cleaned and found some play on the shaft.all that got fixed. Where is the Wastegate Solenoid Control Solenoid so i can check it out, pic? if its easy i'll just swap it to test w/ the gxp..
thanks
P0243
« Reply #1 on: December 29, 2012, 06:45:36 PM »
Drivers side of engine. Right on top. Dont have pick handy.
Offline DirtyMike
Re: P0243
« Reply #2 on: December 29, 2012, 08:10:28 PM »
switched mine with the one from the gxp, also switch sensor on driver side ic pipe, checked the hoses and put in space ecm i had...same problem
Re: P0243
« Reply #3 on: December 29, 2012, 08:18:55 PM »
Mike what about the one that is located right underneath the turbo intake?.
Offline DirtyMike
Re: P0243
« Reply #4 on: December 29, 2012, 09:12:26 PM »
ill try that one tomorrow
Offline DirtyMike
Re: P0243
« Reply #5 on: January 02, 2013, 03:41:55 AM »
Switched the one under the turbo, same issue and dtc
Re: P0243
« Reply #6 on: January 02, 2013, 04:17:15 PM »
Mike.
You have checked all the hoses connections right.
Otherwise if you have a leak anywhere it will set the code.
Offline DirtyMike
Re: P0243
« Reply #7 on: January 02, 2013, 04:27:56 PM »
First thing I did was check all hoses and connections, I'm going to remove the intercooler next and inspect it well and switch it w/ the gxp one...
Re: P0243
« Reply #8 on: January 02, 2013, 05:06:57 PM »
Do you still have the 2bar map sensors?
the Bosch 3 bars are not mentioned in your signature, so I am assuming the answer is no but figured I would ask as the connections on these are known to cause similar issues
Offline DirtyMike
Re: P0243
« Reply #9 on: January 02, 2013, 06:42:27 PM »
nope
