Author Topic: Regular members no longer have the ability to modify or delete posts  (Read 7703 times)
Due to recent events, regular members no longer have the ability to modify or delete posts.  This is only a feature for supporting members.
Can I ask why? I dont understand why this would be necessary to remove this feature. I only say this because I use this A LOT and modify my posts for typos and words i skip over.
Any clarification would be appreciated.
Thanks
Offline DaveOC
  • Running Wisconsin
Re: Regular members no longer have the ability to modify or delete posts
« Reply #1 on: January 18, 2013, 02:24:32 PM »
To DBG:
I, too, used the "modify" feature a lot to clean up the typos, extra words, and missed words in an attempt to make my messages more readable.
I know why you did it, but this response seems to be a bit of overkill.
I know I don't post a lot here, but this will inhibit my posting even more.
C'est le vie!
Aggressive #000741
« Reply #2 on: January 18, 2013, 02:28:06 PM »
can someone enlighten me why this was done?
« Reply #3 on: January 18, 2013, 02:49:17 PM »
I too, think this a bit reactionary.  Can you just disable the ability to modify title's and DELETE threads/posts?  Modifying seems fair to keep and very useful.
« Reply #4 on: January 18, 2013, 03:19:37 PM »
Ok, modify is back but deleting is off.  If you want a to delete a post, report the post and ask to remove the post in the request.
If you see a member abusing the modify priviledge, (i.e.  erasing all text and leaving ...) report the post and I'll look into it.   Every once in a while there is a member that doesn't abide by forum rules.  That causes me to make things more stringent for everyone.  I can't be on the forum all the time and I don't have time to read every post.
Please assist me in the manner above and I'll continue to allow members to modify their own posts.
Regards,
Joe
Offline DaveOC
  • Running Wisconsin
« Reply #5 on: January 18, 2013, 03:33:13 PM »
Thank you, DBG.  That seems like a reasonably compromise.  You do run a good board here!   :thumbs:
Aggressive #000741
Offline EarthNTX
« Reply #6 on: January 18, 2013, 03:40:09 PM »
 :yay:
The best! :)
Ride it like you mean it.
« Reply #7 on: January 18, 2013, 04:20:29 PM »
Works for me.  Thanks!
Offline idkfa
  • Violent Jain
  • mostly harmless
    • Make
« Reply #8 on: January 18, 2013, 05:25:50 PM »
Word!
[from someone who, no matter how many times, proof-reads a post will immediately always find a glaring mistake the moment it's submitted]
« Reply #9 on: January 18, 2013, 07:51:18 PM »
The above was ONLY for non paying members if I understood this correctly.
I can understand if a member do not want to become a modest paying one, but since that is your decision, then you should also understand the issues the board faces as stated by DBG.
That been said the modify only feature been re instated for them is a good move.
Offline idkfa
  • Violent Jain
  • mostly harmless
    • Make
« Reply #10 on: January 18, 2013, 09:55:19 PM »
Ha. I forgot I was a supporting member.
I believe you're right though and you make a very valid point.
(although I'm not sure what the problem is with a user removing their own post.)
« Reply #11 on: January 18, 2013, 10:03:28 PM »
The problem comes when someone abuses the privilege, everyone else has to pay for it.
« Reply #12 on: January 18, 2013, 11:49:49 PM »
You can still use your guns on this forum
Thanks DBG
« Reply #13 on: January 19, 2013, 01:26:17 AM »
And high capacity magazines too.
Offline JoshMcMadMac
« Reply #14 on: January 19, 2013, 08:31:05 AM »
I know on another forum they have it set up so that you can only modify your post for XX number of minutes after the original post.  That might work out better for this situation.
Offline cdflint
« Reply #15 on: January 19, 2013, 09:32:35 AM »
 .DBG you Thank .post the on properly it write not but head my in understand I that something write or ackwards bass something write or typo a miss to seems always I ,Whew
She's an 09 Brazen GXP.
« Reply #16 on: January 19, 2013, 11:00:45 AM »
^^^ that's funny right there!
