Author Topic: How To: Install a Kenwood 8120 Head Unit  (Read 42597 times)
Offline Cheers
Re: How To: Install a Kenwood 8120 Head Unit
« Reply #50 on: January 26, 2009, 12:54:07 AM »
Next was the XM Wanted to use the OEM anttenna in the truck rather than the one that came with the 8120 setup.  The OEM box in in the truck on the NAV side -- the large silver thing -- DeepBlueGXP is removing the cable to the front -- This was the only hiccup.  the stock cable and the cable provided from the radio would not have been a problem if we used the provide antenna --- we didn't and Dark Tech came to the rescue and made a three foot SAMB cable for me THANKS :thumbs:
Here is the OEM box and the newXM box that will go  under the center consol.
Threading the cable through the wall between the truck and cockpit
On the driver's side a similar routing of the camera cable
« Last Edit: January 26, 2009, 01:06:49 AM by Cheers »
Offline Cheers
« Reply #51 on: January 26, 2009, 01:07:17 AM »
The wire bundle to hook everything into the receiver looked like wildly colored spaghetti even after DeepBlueGXP soldered it all together to make the install easier
Lets see tab A goping into slot B
The WHOLE THING
« Last Edit: January 26, 2009, 08:58:40 PM by Cheers »
Offline Cheers
« Reply #52 on: January 26, 2009, 01:07:33 AM »
While DeepBlueGXP was taming the bundle I was doubleside tapingthe XM module and code chip where I was told  :lol: behind the parking brake -- the black box in the middle back of the frame.  The smaller black wires working their way toward the shift are the XM antenna and backup camera cables.  Two person job -- one lifts the plastic piece around the shifter (very carefully) while the second person threads the cables under and through following the large OEM cable bundle.  Use cable ties to secure these cables and the one from the XCM box to the OEM cable.
Before wrapping up this section you have to figure out which wire in the OEM center is tied to the parking brake so, if you chose to, you can over ride the NANNY control that stops you from programing the GPS or watching videos unless the parking brake is engaged. (It was the small light green one, put a ring terminal on it and place it on the ground post.)
The backup camera purple wire is connected to one of the two light green wires, you this by testing the main bundle under the door sill.  Use a test proble with a LED and put the car in and out of reverse to see the LED light up at the same time of the reverse lights.  This will turn on the backup camera when you put the car in reverse.
« Last Edit: January 29, 2009, 08:39:27 AM by DeepBlueGXP »
Offline Cheers
« Reply #53 on: January 26, 2009, 01:07:50 AM »
Next step is to connect all the wiring to the receiver, test all functions, then tape up the harness.
« Last Edit: January 29, 2009, 08:52:07 AM by DeepBlueGXP »
Offline Cheers
« Reply #54 on: January 26, 2009, 01:08:12 AM »
I don't have On-Star, but GM was frugal enough to put mic holes in all left A pillars which makes for a great location for the Bluetooth mic
Getting the mic wire into the dash
« Last Edit: January 28, 2009, 09:29:52 PM by Cheers »
Offline Cheers
« Reply #55 on: January 26, 2009, 01:08:21 AM »
Next very important step and a two-man J*O*B is making sure everything works before stuffing all into the dash -- Dark Tech and DeepBlueGXP ran into one minor problem -- getting my IPod Classic to play video.  Actually not a problem works GREAT, helps to read the instructions --My bad. The is a squadron symbol that appears to the left the listing of the soing title etc. -- most often the picture of the album --Touch it and the video start DUH...
« Last Edit: January 28, 2009, 09:36:32 PM by Cheers »
Offline Cheers
« Reply #56 on: January 28, 2009, 09:45:36 PM »
With the receiver in the remaindor of putting Cheers back together got underway. Including the glove box with its new IPod connector and spare USB line.  The USB line can be used with thumb drives to add wallpaper photos, play music and videos etc. etc.  There is also a sanddisk slot behind the screen -- hold down the DVD/CD reject button and it appears - this is used by Garmin to update its software -- upgraded from 2.4 to 2.5 without a problem.
« Last Edit: January 29, 2009, 08:42:04 AM by DeepBlueGXP »
Offline Cheers
« Reply #57 on: January 28, 2009, 09:47:01 PM »
ONE REMINDER WATCH THE ELECTRICAL USEAGE! OR YOU WILL DRAIN THE BATTERY :gaah: :gaah: :gaah:
Offline Cheers
« Reply #58 on: January 28, 2009, 09:48:41 PM »
DO NOT FORGET THE GREATEST KAPPA WRENCH ON THE PLANET
« Last Edit: January 29, 2009, 08:50:52 AM by DeepBlueGXP »
« Reply #59 on: January 29, 2009, 08:52:48 AM »
Fixed a few things, great job documenting Cheers!!!
« Reply #60 on: January 29, 2009, 11:56:45 PM »
Great pictures! They will come in handy over here when the time comes to install mine.  :D
« Reply #61 on: March 03, 2009, 03:01:34 PM »
I helped Dark Tech with his install last night.  I went to bed about 10:30 and the 8120 was installed.  He got the XM and IPod Adapters.   The Steering Wheel Interface worked also.
Whip - Did your garage door opener work?
Offline chuckdoc
« Reply #62 on: March 03, 2009, 06:02:27 PM »
Way to go Joe and lil Joe.  I know Darktech will enjoy the radio.  It makes driving a lot of fun.
My KappaPerformance Mod Page
Offline Whip
  • Global Moderator
  • Air Force Retired
« Reply #63 on: March 03, 2009, 07:29:06 PM »
Sorry to say, Joe, the garage door opener did not work.  I even reprogrammed it and it still wouldn't work.  I returned the SWI-Jack for the steering wheel control to Crutchfield.  I called and explained what happened and they said to send it back for a refund.  They even emailed me a UPS label and paid for return shipping.  Quality outfit!
« Last Edit: March 03, 2009, 07:31:32 PM by Whip »
GMPP Stage II Tune
Deepblue turn signal mod
Burl wood dash
Offline Cheers
« Reply #64 on: March 04, 2009, 01:14:44 AM »
 :woohoo:  Way to go DeepBlueGXP and Dark Tech --- the practice on mine and Whip's pays off   :yay: :yay:  Can't wait to see it this weekend.
« Reply #65 on: March 04, 2009, 07:48:24 AM »
Since Joe Jr's dash was painted Wicked a while back, he had the radio mount painted to match and it came out great.
Grant, he's having the same problem you are with your steering wheel interface.  It worked initially but isn't now...
« Reply #66 on: March 04, 2009, 11:03:01 AM »
no I'm not going to do it, no I'm not - I love my stock piece of $#%^%# radio
Offline Cheers
« Reply #67 on: March 04, 2009, 11:39:26 AM »
Come on over to the darkside  I'll have to do a show and tell Sat -- Just think Christ could watch movies or BBC shows on long drives   :devil: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
« Reply #68 on: March 04, 2009, 12:24:55 PM »
Heck, With mine, Joe Jr's, ChuckDoc's and yours, we can all do a show and tell  :lol:
« Reply #69 on: March 04, 2009, 01:40:49 PM »
Wait till I get the one that I've been keeping my eye on!  ;)
Offline Gunnys GXP
  • SEMPER FI
« Reply #70 on: March 04, 2009, 02:26:39 PM »
Having this problem too.  Volume down is about the only one still functioning.  Guess I'll have to yank her out again and try a re-learn.
« Reply #71 on: March 04, 2009, 03:15:05 PM »
Same thing here.  Same for Cheers also.  We found the problem before we closed up the dash, did the relearn and finished the car, the next day it doesn't work again.
Offline Gunnys GXP
  • SEMPER FI
« Reply #72 on: March 04, 2009, 04:19:41 PM »
If you used the PAC SWI-PS, what version install set up did you all use?  Version 1 and the green wire right?
Does this match the order of programing
Programming order for
SWI-PS
1 Volume Up
2 Volume Down
3 Mute
4 Track Up/ Seek Up
5 Track Down/ Seek Down
6 Source
7 Preset Up/ Disc Up
8 Preset Down/ Disc Down
9 Band
Also, I found a review where a guy mentioned to hold the button for an addition couple seconds after the light flashes for each function.  Said his has worked fine ever since and has been over a year now.
« Last Edit: March 04, 2009, 04:25:10 PM by Gunnys GXP »
« Reply #73 on: March 04, 2009, 04:33:16 PM »
We held each button down for 3 seconds.  I used the PAC SWI-PS and I used the green wire.  Actually all the versions of the PAC SWI-XX use the green wire.
Correct on the programming but I only did the first 5 functions and wait the 7 seconds and it blinks 3 times and then blinks the version #.
Then with the Pioneer, you plug in the mini stereo plug.  With the Kenwood, there is a blue w/yellow stripe wire that comes out next to the mini-stereo jack and you connect that to the blue w/yellow on the adapter plugs.
Offline Gunnys GXP
  • SEMPER FI
« Reply #74 on: March 04, 2009, 05:12:00 PM »
So your programming it "before" you plug it into the radio?
