Author Topic: FS: 2007 GXP instrument cluster - IDEAL FOR V8 SWAPPED CAR  (Read 5533 times)
Offline username
« on: July 21, 2013, 06:43:33 PM »
Some scratches on the lens, but appears to be in perfect working order.
Selling for what I paid on eBay + shipping to you (shouldn't be more than $10-15 in the continental US.)
$125
Mileage: It will pick up mileage from your car, the mileage isn't stored in the cluster.
Scratches: mainly at the bottom, except for the tach, nearly all covered up by the dash tunnels. Lenses are all interchangeable, so you can use your good set if you want.
Functionality: All the indicators, idiot lights, tach and speedo work, and read the correct speed. I tested in a base Solstice.
Why I'm selling the gauge cluster: The cluster worked nearly perfectly in the car, but the DIC would only report the mileage. Investigation on Cobalt forums (who use the same cluster, just cosmetically different) is that there are DIC compatibility issues not between 2.4L and LNF cars, but between model years. I'm selling this to get one for the same model year as my car. If you have an '07, you should have full functionality. Any other year, you should have a working odometer, but no way to check the tire pressures, trip computer, etc.
« Last Edit: July 30, 2013, 11:51:41 PM by username »
Offline username
Re: FS: 2007 GXP instrument cluster
« Reply #1 on: July 30, 2013, 11:51:32 PM »
Update, still for sale. This should work in ANY 2007 Solstice, and the GXP redline is ideal for V8 swapped cars.
See this thread: http://www.kappaperformance.com/forum/index.php/topic,9825.msg165533.html#msg165533
Offline username
Re: FS: 2007 GXP instrument cluster - IDEAL FOR V8 SWAPPED CAR
« Reply #2 on: December 11, 2013, 10:46:22 PM »
Bump. Still for sale.
Offline username
« Reply #3 on: February 19, 2014, 03:11:50 PM »
This is still available, make an offer.
Offline ryansalazan
« Reply #4 on: February 20, 2014, 12:16:43 PM »
Do you know if this cluster does a gauge sweep when it first starts up? Is that just a solstice thing, or is it actually the instrument cluster? If I can find a for sure answer as to if that will work on a 08 sky redline and maintain the gauge sweep, I'll buy this off of you for sure.
Offline username
« Reply #5 on: February 20, 2014, 02:36:37 PM »
I *think* the '08 GXP cluster in mine does a sweep at startup, but I'll have to double check tonight.
I'm not going to take apart my dash to re-install the '07 cluster, and I don't know if the signal comes from the BCM or it is intrinsic to the cluster, but I'll get you the info for what my car does right now.
Offline ryansalazan
« Reply #6 on: February 20, 2014, 04:53:08 PM »
Thats cool. I need to find someone locally that will switch with me just to see if t does the sweep haha
« Reply #7 on: February 20, 2014, 09:12:28 PM »
The 07 GXP does do a gauge sweep at start up, at least on the tach and spedo.
Offline username
« Reply #8 on: February 21, 2014, 08:15:36 PM »
My '08 cluster (the one in the car, not the one I'm selling) does a sweep, but again, no idea if that's built into the cluster or the body computer.
Offline ryansalazan
« Reply #9 on: February 21, 2014, 08:30:49 PM »
Anyone local have a solstice I can try this on? Ill buy you lunch! Lol
Offline username
« Reply #10 on: July 10, 2014, 04:37:34 PM »
This cluster is still waiting for a new home.
Offline username
« Reply #11 on: October 27, 2014, 12:39:09 PM »
Still available.
Offline username
« Reply #12 on: January 21, 2015, 05:05:40 PM »
Just a bump, still have this in my garage.
Offline username
« Reply #13 on: May 02, 2015, 05:57:58 PM »
Another bump! Still for sale!
Offline hammy221
« Reply #14 on: June 18, 2015, 09:05:51 PM »
Still got the cluster
Offline username
« Reply #15 on: June 22, 2015, 02:05:23 AM »
Yes, it is still available.
