Author Topic: Help on installing turn signal mirrors and ghost lights  (Read 2844 times)
Offline cdflint
« on: August 18, 2013, 09:34:52 AM »
I have two items to install:
1. Turn signal mirrors
2. Ghost lights
First, at Nationals I purchased the turn signal mirrors at the silent auction. In talking to the guy who made them, he said there a different ways to connect. Wire to the front signals, rear signals or near the BCM. When I tried to do the the turn signal to side marker mod, it failed because I have a LED switchback light on the front light where the fog light housing is. At that time the side markers were not LED's so I believe that is why the mod didn't work. My question for this mod, since they are both LED's, can I connect there or connect next to the BCM or trail it back to the rear wiring be better? Then, which wires to tap into?
Second, again at Nationals they were installing Ghost lights but didn't pay attention to them at first until I was able to see them at the night light car show. I you have not seen them, they are LED lights that project an image under your door when the door opens. I went on ebay and purchased a pair of a Pontiac version with the arrow logo for $25.00. I founds them cheaper now but that's what I paid. My question again is wiring. They should turn on only when the door is open. What wire should I tap into or is there a fuse I can add on to. I have footwell leds I could tap into but just wanted your expertise.
Here is how the image looks on the ground.
« Last Edit: August 18, 2013, 09:40:57 AM by cdflint »
She's an 09 Brazen GXP.
Re: Help on installing turn signal mirrors and ghost lights
« Reply #1 on: August 18, 2013, 09:53:39 AM »
Not sure about the first one... never done it, never looked.
As for the puddle lights, I have done that (both lighted sills and puddle lights only light when that door is open).  There is a post on how/where to wire this here: http://www.kappaperformance.com/forum/index.php/topic,4345.msg56001.html#msg56001
Personally, I didn't do exactly that, since I found it too difficult to find the wires external to the connector (there's a lot of wires that are the same or similar colors, plus colors can change).  I wired the +12V to a different 'always-on' source and then I opened up the connector and soldered wires direct to the pins for the door grounds.  See pins 19 & 22 below:
Offline cdflint
« Reply #2 on: August 18, 2013, 10:23:36 AM »
Thanks TS, I'll give it a go on the puddle/ghost lights.
