Author Topic: Black painted Intercoolers Mythbusted  (Read 4923 times)
« on: June 19, 2014, 07:59:00 AM »
Re: Black painted Intercoolers Mythbusted
« Reply #1 on: June 19, 2014, 05:59:21 PM »
Pretty interesting, so if you painted black, just make sure the sun does not shine on to it and you have a wining combination.
Although for a street car it does not matter.
Offline crisco
  • My Precious!
« Reply #2 on: June 26, 2014, 08:17:56 AM »
Just for off the line, like from a red light.
Offline cdflint
« Reply #3 on: July 04, 2014, 11:10:51 AM »
Interesting,
So if I understand correctly if you are stopped idle you get cooler airflow and while driving there isn't really a benefit? Would that help DD's cooling temps since there are more idle stops? Would it really keep the engine cooler at idle?
She's an 09 Brazen GXP.
« Reply #4 on: July 04, 2014, 12:46:22 PM »
I think a better paint job will work better. Spraying like they did will close up some of the airflow. If the inter cooler is made black from the design phase, i think the benefits would be even better.
« Reply #5 on: June 24, 2015, 07:45:56 PM »
The solution is black anodizing the aluminum.
« Reply #6 on: June 24, 2015, 08:44:27 PM »
Yeah that sounds like a good idea since anodizing is actually a layer of corrosion that will make the surface non conductive.
Offline cdnite
« Reply #7 on: June 24, 2015, 11:37:01 PM »
What the paint is doing is adding surface area because of the matte texture. so anodizing will do zero. Aerospace tested this years ago and while there is a benefit it is minimal.
--Christian
Offline KappaTarbo
« Reply #8 on: June 25, 2015, 09:21:39 AM »
After watching the Mighty Car Mods video you need to watch this one to come to the correct conclusion.
08 Carbon Flash Redline 5 Speed
LDK long block. DDM Works clutch kit, brace bundle, oil catch can and SS brake lines. Stoptech Street Performance pads with ATE Type 200 fluid. Fujita intake and charge tubes. Gutted stock downpipe. Tuned with HP Tuners.
