Author Topic: Tuning GXP With Meth  (Read 6023 times)
« on: May 01, 2009, 06:12:16 PM »
oK So I am new to the meth scene lol. I was wondering besides timing how I would go about tuning the gxp with meth, I have the pcm tune4less. I dont wanna do anything stupid. Thanks
Re: Tuning GXP With Meth
« Reply #1 on: May 01, 2009, 10:30:15 PM »
Meth is bad for you, takes your money, your car and your house
« Reply #2 on: May 01, 2009, 10:34:38 PM »
But all the cool kids are doing it.
I bet he is only going to do it this one time.
Offline Chemist
« Reply #3 on: May 02, 2009, 09:04:14 AM »
I thought the same thing, but then again, I _am_ a Chemist. :D
I'd rather be driving! :D
« Reply #4 on: May 02, 2009, 09:52:08 AM »
lol yes it only takesone time .
here is the brak down of the price, Its a little more pricey by imo its worth it.
1 PAC Progressive Alcohol Controller 189.00
1 pump Injection Pump 150.00
1 Filter Methanol Filter 35.00
1 Pump Fittings 4 Pump Fittings 15.00
1 M10 M10 nozzle assembly 10.00
1 Tank 90 Tank 90 degree w/barb 15.00
1 Mini OVF Mini Overflow assy for WW replacement 20.00
Shipping Shipping 10.00
Florida Sales tax 7.00% 30.38
$474.38
Offline Lucy'sDaddy
    • Lucy's cardomain page
« Reply #5 on: May 04, 2009, 08:52:09 PM »
Lyndon Wester is the guy to talk to on this subject. We had a lengthy conversation on it when I got my tune from him. He's a BIG fan of water/meth spraying.
« Reply #6 on: May 04, 2009, 09:32:47 PM »
what kind of info did he relate to you. I should have the kit tommorow afternoon. Hopefully I will have it installed by weeks end.
Offline DirtyMike
« Reply #7 on: May 04, 2009, 09:45:31 PM »
lyndon has a tune for water/meth, sky888 was using it till he got the gt30 think he's using a modified westers tune now not sure
« Reply #8 on: May 05, 2009, 05:49:38 AM »
I have been talking to sky alot picking h brain. I am going to try to dyno tune it through hp and see how that goes
« Reply #9 on: May 05, 2009, 06:45:22 AM »
I sent you a PM with some links.
« Reply #10 on: May 05, 2009, 07:57:12 AM »
i pmed you back :) thanks again
Offline Lucy'sDaddy
« Reply #11 on: May 05, 2009, 08:58:00 AM »
That was a year ago, and honestly, we didn't get into details. The only disadvantage he could come up with is that in COLD temp driving, you must be careful, cuz if the water/meth solution freezes, you got no squirt, and no squirt+hot tune=BIG trouble.
He HIGHLY recommended using it, as evidently he has used it before on some of his other tunes, for Corvettes or ???? That what he does best, tuning.  The reason we didn't go for it was this car has so much power now, I couldn't see adding extra cost to daily driving, which is what this car is, LadyT's D'D'r.  It's still an option down the road, but I have other priorities 1st, like finishing the interior and finding another JOB.
Offline oldskool
« Reply #12 on: July 01, 2009, 07:54:43 PM »
Here's my experience so far.  I have a boost switch that was originally set for 10 PSI activation.  I tried two solutions: 75% methanol and 50% methanol.  The nozzle is rated at 3 gallons per hour @ 100 PSI, but the pump is a 250 PSI pump.  I have the nozzle mounted on the cold side pipe on the bend coming up from the IC, about 12" or so from the T-MAP.
With both solutions, all WOT KR was gone.  The only KR was during throttle transistions/tip-in.  I ended up smoothing all main timing tables and adding two degrees in the last two columns over 3000RPM.  the car does feel strong and I'm getting a 29 lb/min VE airflow reading, where before I was getting 27-28lb/min max.  It holds 21-22 PSI to 6500rpm
My issue is with the intake temp reading.  I can physically feel the pipe is cooler, but my IAT2s are not significantly cooler than before the install/retune.  I'm emailing the vendor for suggestions on this.  I would have thought the temps would have been significantly cooler, maybe cooler than ambient, but its not reading that way.  Lowering the boost activation results in misfiring (spray is putting out the spark).
FYI, a 50% methanol/water solution will not freeze at any temps we get in the continental US.  the -20*F windshield washer fluid is only like 30% methanol.
« Reply #13 on: July 01, 2009, 09:19:07 PM »
With your activation triggered at 10psi, how long does the meth last?
Did you make your own tune from scratch or start with a BSR or Westers?
Thanks for the info.
« Reply #14 on: July 01, 2009, 09:51:27 PM »
mine is trigged to come on at 8psi, but im running a m10 nozzle which is realy big and I can go though a bunch quick.
Offline oldskool
« Reply #15 on: July 02, 2009, 08:14:14 AM »
I tune the car with HPT :).  I've since upped the activation point to ~15PSI, and I haven't gone through an entire supply from the windshield washer resevior yet with is a little over a gallon.  I'm going to guess with the set up as it is, it will probably use a gallon every 2-4 tanks of gas depending on driving style.
I'm leaning towards a 5 or 7 gallon/hr nozzle though, and for the future I will probably upgrade to a dual nozzle set up.
« Reply #16 on: July 02, 2009, 09:14:45 AM »
When I explored this Lyndon Wester said start at about 14, I looked into the Stage 1 Devils Own, decided the Stage II might work better with the electronic controller.
