Author Topic: RAN A 13.5 AT THE TRACK  (Read 4189 times)
« on: May 16, 2009, 07:55:03 PM »
Went to the track last night and to run the GXP. The best run of the night was a 13.5. That was w/o the meth since the shop hasnt installed it yet. Timeslip below. All comments welcomed.
R/T .697
60 2.144
330 5.811
1/8 8.774
MPH 83.08
1000 11.335
1/4 13.503
MPH 101.90
Offline HAMMER DOWN
Re: RAN A 13.5 AT THE TRACK
« Reply #1 on: May 16, 2009, 08:02:08 PM »
Nice, what tires & how much psi did you run in the tires.
« Reply #2 on: May 16, 2009, 08:12:40 PM »
stock gxp tires with stock psi, i know if i drop the psi I might be able to pick a few tenths.
Offline Filipp
« Reply #3 on: May 16, 2009, 08:22:37 PM »
What rpm did you launch at?
« Reply #4 on: May 16, 2009, 09:54:59 PM »
Nice numbers, if you had dropped the PSI to 19, your 60 foot time would be much better also.
« Reply #5 on: May 17, 2009, 02:48:56 PM »
I believe I launed at about 2000 rpm's. I also has the esc off.
« Reply #6 on: May 17, 2009, 09:21:59 PM »
The stock rear tires need to be at 19-20 psi and you should get some better numbers, just like Joe said.
« Reply #7 on: May 17, 2009, 09:26:17 PM »
thanks for the tips, next time I go to the track I will do that
Offline sol_man
  • Enjoying the cool summer
« Reply #8 on: May 18, 2009, 08:35:59 AM »
Very solid numbers!
Is your car an auto or stick?  I have an auto and with the ESC off I launch around 2000 to 2400 (depends on the temp outside if I get wheel spin or not) and the car pulls hard through 3rd gear.  Most things I've read show the gearing between the auto & stick to be about the same, just curious how well 4th pulls in the manual trans cars.
0-60 in 4.37 seconds
« Reply #9 on: May 18, 2009, 12:57:21 PM »
Thanks its a manual forth pulls pretty strong
« Reply #10 on: May 18, 2009, 01:38:28 PM »
Interesting. Stock, my car's power really seems to die in fourth gear. It'll pull in 4th, but not in time for a 1/4 mile run. Revs are too low after the shift, and the finish line comes just as it's just starting to pull again.
I need a tune, but I just don't have the funds for it right now...
