Author Topic: Dyno before exhaust + wester's "ss" tune and after  (Read 6326 times)
« on: October 26, 2009, 06:29:30 PM »
Some months ago I went to dyno and pulled 2 runs with a result of 235hp (176.3KW) and 386Nm (284 lbs-ft) this result:
I did a run with AFR and boost, but because I had the stock exhaust I don't know if the AFR was concluded.
The dyno was a mustang, no fan !!!, around 30 degrees Celsius (86F) and no compensations.
At that time I had only Dejon IC, custom made throttle body elbow and Wester's Tune.
In this weekend went again on the same dyno, and around 22 degrees Celsius (71F) and a small pretty strong fan but still I rated not enough for real air flow.
To my car a Solo catless downpipe, mach exhaust and the tune was updated to latest public version of Wester's tune.
I didn't received the files yet but I have a picture and some videos.
The results are: 253hp (189KW) with 418 Nm (308 lbs-ft)
The difference speaks but don't forget about the dyno situation: 17hp and 24lbs-ft
http://www.vimeo.com/7283485
This is a pretty conservative dyno, a base car probably will not go above 220 hp, maybe less and judging based on that, I'm pretty happy about the results. I didn't do more runs because I don't very happy about that fan.
I did also a 1/4 mile simulation drag race and the result came very close of my personal best E/T from drag strip.
On drag strip: 13.30s
On dyno: 13.37s
« Last Edit: December 01, 2010, 05:59:56 AM by Kelu »
Re: Dyno before exhaust + wester's "ss" tune and after
« Reply #1 on: October 27, 2009, 12:38:43 PM »
Always nice to see dyno results. Seems like a nice gain to me.
« Reply #2 on: October 27, 2009, 07:28:28 PM »
The gain is what matters and basically it shows how the tuner took advantage of the improvements to the exhaust.
« Reply #3 on: October 28, 2009, 10:51:48 AM »
Very nice gains for an already tuned car, keep the master busy he just updated my catless tune, it really helped down low, worked so much better on the auto x course last weekend.
« Reply #4 on: October 28, 2009, 03:08:29 PM »
Sorry guys, "official mail" still didn't arrived from the dyno.
Lil goat: what are you saying there? You are working on a newer version of the SS Tune?
I have some logs (not with HPT) do you think should I sent them to Lyndon? Or let him alone to do other more important things?
« Reply #5 on: November 01, 2009, 09:51:51 AM »
Updated first post with the files from the dyno.
Guys, maybe I did a mistake but I want to check with you. Converting kW to Hp I know I have to multiply kW by 1.36 to get Hp. Google and some other internet pages show I have to  multiply by 1.34:
http://www.google.com/search?hl=en&q=1+kW+to+hp&sourceid=navclient-ff&rlz=1B3GGGL_enRO308RO308&ie=UTF-8
I might be wrong and stated bigger values for Hp on my first post but I'm pretty confident I'm right, I can't convince the differences of the conversion, I think is related to mechanical horsepower but I couldn't clear myself up.
Offline baconbits
« Reply #6 on: November 01, 2009, 10:38:08 AM »
1 horsepower = 745.699872 watts... (1 / 745.699872) * 1 000 = 1.34102209...
Offline Wester's Garage
    • Wester's Garage
« Reply #7 on: November 02, 2009, 12:49:12 PM »
Looks about right on with our dyno, too ! ;)
« Reply #8 on: November 02, 2009, 06:35:09 PM »
I have updated the values in first topic, the difference remains same ;)
Wester's Garage: I'm not aiming high numbers, I was always annoyed by the 240 whp showed by DynoJet on stock cars, that would mean only a 10% loss on drivetrain which I consider it too low. I'm glad I have same numbers as your dyno and same with the numbers showed by the conservative dyno when the guys did the dyno day.
« Reply #9 on: November 12, 2009, 10:54:18 AM »
British System:- 746W = 1 H.P.
1000W (1 kW) = (1000 / 746) H.P. = 1.34 H.P.
Metric System:- 735.5W = 1 H.P.
1000W (1kW) = (1000/735.5) H.P. = 1.36 H.P.
Both we were right :)
