Author Topic: The magical gmpp tune  (Read 39650 times)
Re: The magical gmpp tune
« Reply #25 on: April 14, 2010, 11:30:55 PM »
someone smart told me that. but i don't remember why. it was more complex then that, or i'm totally wrong cuz i have a memory like a goldfish. next time i will keep my mouth shut :)
« Reply #26 on: April 15, 2010, 03:39:09 AM »
Offline JoshMcMadMac
« Reply #27 on: April 15, 2010, 10:41:12 AM »
I can also upload the GMPP tune for a 07 auto GXP in the tune repository.
Give it a shot, but it may not make it through.  I tried to post the 2009 manual Redline and it they would not put it up because it is a GMPP tune.
« Reply #28 on: April 17, 2010, 11:01:03 PM »
I tried the other day and said it would need to be validated before it would be put in the Repsitory so we'll see.
Has anyone made changes to the MAF frequency with HP tuners to "dial in" there tune better to possibly allow for more advance in timing?
« Reply #29 on: April 17, 2010, 11:16:21 PM »
Here's a nice tuning guide on how to accomplish that http://www.hptuners.com/forum/showthread.php?t=26756
« Reply #30 on: April 17, 2010, 11:20:47 PM »
Holy crap didn't know that existed.
« Reply #31 on: May 06, 2010, 10:31:00 PM »
Did i mention how much i love the gmpp tune? Almost 30psi, still a bit too high imo but damn thats impressive  :drive:
Offline perris
« Reply #32 on: May 07, 2010, 07:18:39 AM »
man that's impressive, what horespower or torque do you think you're getting
« Reply #33 on: May 07, 2010, 07:37:06 AM »
lots of boost. but not much more MAF than Lyndon's tunes
« Reply #34 on: May 07, 2010, 07:38:07 AM »
oh wait that is not your peak MAF. sorry
« Reply #35 on: May 07, 2010, 07:48:48 AM »
Shabby get yourself to a dyno with before and after.
« Reply #36 on: May 07, 2010, 03:53:05 PM »
I have a rough idea in my mind but i rather wait till i get it on a dyno.
I'd love to see some logs from Lyndons tune, but lets save that for another thread.
« Reply #37 on: May 07, 2010, 04:10:07 PM »
New thread coming right up. I've been meaning to start one to compare log results anyway
Offline perris
« Reply #38 on: May 07, 2010, 04:18:18 PM »
this sounds like fun, what logs are you guys posting, I have the gm tune and I'll get the info up as well if my dash daq will read what you guys are looking at
« Reply #39 on: May 07, 2010, 04:32:54 PM »
See my thread. If you can post stuff from DashDaq that would be hot
http://www.kappaperformance.com/forum/index.php?topic=4487.new#new
Offline perris
« Reply #40 on: May 07, 2010, 04:36:42 PM »
a great idea but I need to know what to log, dash daq might be able to do it but I won't know untill I see what those perameters are, the thread you linked doesn't give me that info
I can do , knock, I think fuel pressure or something to do with the fuel rails but I'll have to check and a bunch of other stuff, I can't log boost but so far all I get is 19 steady
« Reply #41 on: May 07, 2010, 04:38:29 PM »
See the first post of this thread. Shabby shows you all the important stuff.
« Reply #42 on: May 14, 2010, 07:00:14 AM »
Hey shabby iirc you stated you have big pulse widths in mid-range because there are some differences between read and commanded lambda. Isn't the differences because of MAF tuning?
What I'm trying to say here is you might have a different airflow than your MAF reports so read AFR is off the commanded AFR?
« Reply #43 on: June 02, 2010, 12:55:02 AM »
I'd like to see the answer to this question ^^^
Also shabby, do you know if you can adjust the NLS activation point with HPT? Or if you raise the rev limit, does the NLS point move with it?
« Reply #44 on: June 02, 2010, 07:00:41 PM »
Hey shabby iirc you stated you have big pulse widths in mid-range because there are some differences between read and commanded lambda. Isn't the differences because of MAF tuning? What I'm trying to say here is you might have a different airflow than your MAF reports so read AFR is off the commanded AFR?
I thought about that but my stft and ltft are pretty much near zero, if you check the pics of the logs in the first post you'll see that the afr is close to the commanded afr in the stock gmpp tune but on the rich side in the modded gmpp tune, and the only difference between those was the added boost... some 30psi in the midrange.
Kenny: you can't change anything with hptuners, just shift before your new higher redline and you'll be fine.
« Reply #45 on: June 03, 2010, 10:49:24 AM »
I got a question shabby. Didn't wanna pollute panther's NOS thread.
I noticed the same thing with the gmpp tune, the dal's are extremely touchy however i can command any amount of boost that i want now, without the gmpp tune i can only hit 22psi tops.
In my quest to understand, why were you only able to hit 22psi, when Lyndon is tuning cars without GMPP to 25+ psi
« Reply #46 on: June 03, 2010, 03:02:29 PM »
Doesn't Lyndon use his own software to tune the ECM but then uses HP tuners to write the tune to the ECM?
This would explain the reason for the difference since HP tuners does not unlock all the parameters in the ECM as of yet and may never unless HP tuners decides dedicate the time and effort to do so?  From what I see there are a few tables for the GXP that are not unlocked with HP tuners for our car.
« Reply #47 on: June 03, 2010, 03:06:19 PM »
That is exactly what I assumed.
« Reply #48 on: June 03, 2010, 04:32:59 PM »
Right, i set my dal's to 400 and i was still stuck at 22psi before the gmpp tune.
« Reply #49 on: June 03, 2010, 07:26:41 PM »
learning curve steep.
dal's?
stft?
ltft?
Thanks,
