Author Topic: Weird piston damage - LNF - tuned, GT3071 -  (Read 59647 times)
Re: Weird piston damage - LNF - tuned, GT3071 -
« Reply #50 on: February 22, 2015, 10:27:22 AM »
So I am at Cracker Barrel right now and I  just ordered a V8
See Kelu
You can get them everywhere
« Reply #51 on: February 22, 2015, 02:04:18 PM »
Great time to change that water pump with the one you won from the meet, if you haven't yet.
Damn right, as soon I entered the shop and saw the block, first thing which I said to the guys was: Don't forget to change the water pump and thermostat ;)
Showed them also the water pump tool  :thumbs:
See Kelu
Stop teasing or .... you might have a visitor  :lol: ... a weird one ... kind of ...
« Reply #52 on: February 22, 2015, 06:13:32 PM »
Your sending GJ to Elff's?  What's he going to do hide the Triscuits on him?
« Reply #53 on: February 22, 2015, 08:19:00 PM »
I'm not sure the tool will be much help with the block already torn down...
« Reply #54 on: February 23, 2015, 12:18:21 PM »
Even more weird one :) if I start to hide thier things, both will need a ladder for sure  :lol:
Indeed the timing chain being out is not too much trouble but the pump is still rotating in the housing.
The assembly didn't start and already faced issues:
1) Timing and balancing chains - reported not being in a great shape:
They were not supposed to bend so much  :idk: found timing chain in Romania, going to reuse balancers chain.
2) Oil pump reported being full of debris ... still searching for a solution
Wonder how come the oil pan has no debris from the failure and oil pump is full of them ... oil pump is supposed not to suck all the debris from the pan, right?   :huh:
« Reply #55 on: February 23, 2015, 02:20:29 PM »
Often times there are pickup screens to filter out the large metal pieces where the oil gets picked up in the pan.  The oil then goes through the pump, the filter, and then the engine.  As pumps wear they can generate their own metal debris.
Those chains look like they can go around a compound corner now.
PS I think Elff had to stand on a chair last time we hid something on him.
« Reply #56 on: February 23, 2015, 03:24:03 PM »
I did not have to stand on a chair.
That is a bold faced lie.
I was standing directly on the countertop.
« Reply #57 on: February 23, 2015, 04:32:48 PM »
How did you get to the counter top?
Was it maybe, I don't know.....a chair?
« Reply #58 on: February 23, 2015, 05:04:15 PM »
I jumped off the back of my greyhound
« Reply #59 on: February 23, 2015, 09:49:55 PM »
I hope PETA doesn't find out.
« Reply #60 on: February 24, 2015, 01:59:41 AM »
The greyhound didn't notice.
« Reply #61 on: February 24, 2015, 02:22:28 AM »
Stop trying to hijack Kelu's thread GJ!
« Reply #62 on: February 24, 2015, 12:07:06 PM »
Again, The Greyhound didn't notice.
« Reply #63 on: February 24, 2015, 12:35:36 PM »
Thanks for trying to educate ;)
Now Head studs are not to be found :(
This drives me crazy...
GJ: but I noticed ...
« Reply #64 on: February 24, 2015, 03:12:03 PM »
Head studs only get deliverd with v8s
« Reply #65 on: February 24, 2015, 04:32:10 PM »
If I am involved with shipping them to Kelu that will be true.
« Reply #66 on: February 24, 2015, 04:33:33 PM »
I'm asking myself why in the hell I started this topic ...
elff: did you get Lusi back? :)
« Reply #67 on: February 24, 2015, 04:39:56 PM »
Where else are you going to get this kind of helpful information?
« Reply #68 on: February 24, 2015, 05:41:48 PM »
Maybe............. :cool:
« Reply #69 on: February 24, 2015, 06:07:44 PM »
« Reply #70 on: February 24, 2015, 06:40:58 PM »
It's home.  I will put together a separate post so as to not further clog up yours.
« Reply #71 on: February 25, 2015, 12:07:57 AM »
Kelu-
Come home!
Your room is ready.
The Zoo is open.
See you soon.
« Reply #72 on: February 25, 2015, 12:39:31 PM »
Kelu-
Come home!
Your room is ready.
The Zoo is open.
Piiictureeesss  :D
Offline Ironhide
« Reply #73 on: March 01, 2015, 07:29:27 AM »
The last time I've seen such a damaged piston has been when I worked for Volkswagon.
The reason for the damage had been poor lubrication.
They called it a kind of piston jamming.
Oliver  :usa:
« Reply #74 on: March 01, 2015, 04:53:06 PM »
That is very interesting theory, when they started to re-assemble the engine, they discovered the oil pump damaged, the gears had scratches between them and also to the plate where the gears are sitting.
Nobody though to this because I always used Motul 300V oil which is very good oil and even if gets hot it still lubricates very well and ECU didn't reported any issues with oil.
Now the question would be: the oil pump got damaged because of metal pieces which came from the piston failure or the other way around?
