Author Topic: Just bought Super Eliminator Drag car  (Read 4453 times)
Offline Graywolf
« on: February 01, 2015, 01:27:51 PM »
Just bought a 34 Ford roadster Top  Eliminator drag car. Weights 1720 lbs, 496cu inch GM block,roller cam,bushing style lifters,Wiseco pistons ,13.5:1 compression,eagle rods,Callies crank,Rupert carburetor set up for Menthol (Alcohol),engelbrock heads Makes about 700 to 750 hp Runs around 8.7 sec 160 plus mph in 1/4 miles.  Will pick in 3-4 weeks,needs the hood and fake front grill painted.  Need to make some changes in seat and move steering wheel back 2", also need to add small step to get in cockpit.  Body is all fiberglass  OK OK This post is worthless because no pics I promise I will have someone . show me how to do it. I have picture
[/img][/img]
« Last Edit: February 01, 2015, 04:50:23 PM by Graywolf »
Offline Graywolf
Re: Just bought Super Eliminator Drag car
« Reply #1 on: February 01, 2015, 04:56:01 PM »
Some one call me and I will text u the pics to post 309-737-6596 Thanks Tom
« Last Edit: February 01, 2015, 05:03:50 PM by Graywolf »
« Reply #2 on: February 01, 2015, 05:00:10 PM »
Supporting members can attach direcyl to the forum in the post box.  Everyone else will have to use a picture hosting site like Photobucket or Flickr and copy the forum code to past in a message.  It will start with
Code: [Select]
[img]http://host site/photo.jpg and end with[/img]
Offline Graywolf
« Reply #3 on: February 01, 2015, 05:17:56 PM »
Sorry,tryed ,didnt work
« Reply #4 on: February 01, 2015, 06:21:25 PM »
Where are the pics located?
