2007 Solstice GXP (Mysterious Black)
Gen 3 LDK block, Wiesco Pistons, ZZP 4340 Rods, ZZP Ported & Polished LNF Head,#84 Valve Springs, Iconel Valves, ARP Head Studs, ZZP Stage 2 cams, Opel Injectors, AEM High Flow Fuel Pump, ZZP Z54 6758 Turbo, Forge K04 Recirculation Valve, RPM Intake, RPM Charge Tubes, RPM Intercooler, RPM Catless Downpipe GM 3 Bar Map Sensor, Spec Aluminum Flywheel, Spec Stage3+ Clutch, Fluidamper Under Drive Pulley, PAW MLS Head Gasket, PAW Copper Turbo Gasket, PAW Intake & Throttle Body Phenolic Spacer, PAW Aluminum Racing Radiator, PAW Clutch Slave Cylinder Spacer, PAW Painted Valve Cover, PAW Stainless Steel Clutch Hose, PAW Oil Take-Off Whip, DDM Short Shifter, DDM Stainless Shift Knob, DDM Stainless Lil' Chromies, DDM Coolant Lines, DDM Throttle Body Elbow, DDM Venom Brace, DDM Race Backbone, DDM Probeam, DDM Gauge Pods, DDM Coil Cover, DDM Oil Catch Can, Solo Performance Mach Shorty Exhaust, BC Racing Coilovers, ZOK Sway Bars, Moog End Links, 20x8.5f & 20x10r Niche Concourse Wheels, 245/35/20's f & 275/30/20's r, Stoptech Stage 5 Brake Rotors and Pads w/ Stainless Steel Brake Lines, VDI Vertical Door Kit, Prosport Premium Digital Boost & Oil Pressure Gauges, Sprintbooster.
