Author Topic: New Central Florida Member  (Read 3883 times)
Offline Mr. E Us
« on: February 04, 2018, 11:23:04 AM »
2007 Solstice GXP (Mysterious Black)
Gen 3 LDK block, Wiesco Pistons, ZZP 4340 Rods, ZZP Ported & Polished LNF Head,#84 Valve Springs, Iconel Valves, ARP Head Studs, ZZP Stage 2 cams, Opel Injectors, AEM High Flow Fuel Pump, ZZP Z54 6758 Turbo, Forge K04 Recirculation Valve, RPM Intake, RPM Charge Tubes, RPM Intercooler, RPM Catless Downpipe GM 3 Bar Map Sensor, Spec Aluminum Flywheel, Spec Stage3+ Clutch, Fluidamper Under Drive Pulley, PAW MLS Head Gasket, PAW Copper Turbo Gasket, PAW Intake & Throttle Body Phenolic Spacer, PAW Aluminum Racing Radiator, PAW Clutch Slave Cylinder Spacer, PAW Painted Valve Cover, PAW Stainless Steel Clutch Hose, PAW Oil Take-Off Whip, DDM Short Shifter, DDM Stainless Shift Knob, DDM Stainless Lil' Chromies, DDM Coolant Lines, DDM Throttle Body Elbow, DDM Venom Brace, DDM Race Backbone, DDM Probeam, DDM Gauge Pods, DDM Coil Cover, DDM Oil Catch Can, Solo Performance Mach Shorty Exhaust, BC Racing Coilovers, ZOK Sway Bars, Moog End Links, 20x8.5f & 20x10r Niche Concourse Wheels, 245/35/20's f & 275/30/20's r, Stoptech Stage 5 Brake Rotors and Pads w/ Stainless Steel Brake Lines, VDI Vertical Door Kit, Prosport Premium Digital Boost & Oil Pressure Gauges, Sprintbooster.
Fully Built, Fully Loaded, Proud Member of the 500hp Club
Re: New Central Florida Member
« Reply #1 on: February 04, 2018, 11:42:35 AM »
Wow. It looks like every possible aftermarket item.
Any pics?
Welcome to the forum!!
« Reply #2 on: February 04, 2018, 01:29:45 PM »
Indeed wow, huge list of upgrades.
Welcome to the forum ... "can we see it?" :D
« Reply #3 on: February 05, 2018, 10:58:58 AM »
 :ttiwwp:
I can't believe Kelu let it slide.  Welcome to the forum
« Reply #4 on: February 05, 2018, 12:07:17 PM »
Kelu could go visit, it's practically in his backyard now.
Welcome to the forum.
Offline Solar
« Reply #5 on: February 06, 2018, 12:31:37 AM »
well damn hahaha.  pics or gtfo!  les see it.  I usually go to central florida but living in the dirty south florida.
« Reply #6 on: February 06, 2018, 10:13:03 PM »
I didn't, I was just nice with "local" owners .... wow I waited long to say these things :D
SA: Dunno what backyard means for you but for us a trip more than 1h is something which needs to be planned :D
« Reply #7 on: February 07, 2018, 02:11:19 PM »
It's a lot closer to you than it would have been say 6 months ago, and still closer to you than me.
« Reply #8 on: February 07, 2018, 06:19:34 PM »
From Daytona to Orange city is probably an hour or less.
« Reply #9 on: February 07, 2018, 06:36:09 PM »
For SA one hour wouldn't even get him out of the corn fields.  :)
« Reply #10 on: February 07, 2018, 09:04:02 PM »
That's probably a 3-4hr drive
« Reply #11 on: February 08, 2018, 01:41:26 AM »
For me, 1 hour south puts me in another country. 1 hour north or east and I’m still in the same county. 1 hour west and I’m deep sea fishing.
