Author Topic: Calling all electrical pros  (Read 3759 times)
Offline Excelsior
« on: May 24, 2009, 02:08:18 PM »
I am looking for a constant power source under the hood that I can tap into for LEDs.  I will be installing a button to turn the LEDs on and off manually, but I don't want to leave the parking lights on, etc.
Offline Fred
Re: Calling all electrical pros
« Reply #1 on: May 24, 2009, 02:45:30 PM »
I'm thinking here that you want something other than the battery??  :huh:
Pops' car is Cool, Black Leather. Everything but Onstar and pretty much stock. VIN 12228.
« Reply #2 on: May 24, 2009, 02:50:52 PM »
If not the battery, in what area under the hood were you hoping to be able to hook up?
Offline Excelsior
« Reply #3 on: May 24, 2009, 04:09:50 PM »
I did a test run and can do it to the battery and hide the wiring quite well.  We will see how it looks tonight.
Offline LiquidPT
  • TechHead
    • LiquidPT's website
« Reply #4 on: May 24, 2009, 04:12:15 PM »
If you hook up to the battery, please remember to put in a fuse, relatively close to the battery. Last thing you want is a short...
LiquidPT aka Matt
driving Black Sun
« Reply #5 on: May 24, 2009, 04:13:55 PM »
Think he may be wanting to tap into the fuse box that sits above the battery?
I did this on another vehicle I own where I taped one of the relay pins for a override switch for a efan that helped cool a heat exchanger with an extra set of fans .
Would have no idea if that could be done on the Sol though?
Offline BLK GXP
  • Rollin'
« Reply #6 on: May 24, 2009, 04:40:29 PM »
The fuse box cover above the battery has a red cover on one side of it that hides a positive post. This would be a good spot to get power.
Offline LiquidPT
  • TechHead
« Reply #7 on: May 24, 2009, 08:35:21 PM »
Would that be your jump start post? You'd still want to fuse whatever you tapped off of there...
LiquidPT aka Matt
driving Black Sun
« Reply #8 on: May 24, 2009, 08:40:25 PM »
You would want to put a fuse in no mater where you tap from.
Offline BLK GXP
  • Rollin'
« Reply #9 on: May 24, 2009, 08:48:13 PM »
Absolutely!
Offline Ceeker
    • Ceeker
« Reply #10 on: May 24, 2009, 11:28:05 PM »
Yup that would be the best spot. Use a fused tap and your set to go!
Silver/RL 2007 - Red/Black Leather
DeJon CAI, IC Pipes
Magnaflow, Opel Badges, Tail Lights, Back Up Light.
Hahn Intercooler, Westers Race Tune.
GO NAK3D Member (UT Division)
