Author Topic: New GXP/Z0K sway bar part number  (Read 196427 times)
« on: June 02, 2009, 03:21:59 PM »
P/N 25919110  --  Cheaper, too.
« Reply #1 on: June 08, 2009, 10:03:37 AM »
Damn it now everyone knows! shhh don't tell the guys on the BB.
 I just ordered two, figured be twice as stiff that way. Just kidding one for me and one for Jmac. Yes I will be selling my old sway bar to some lucky N/A owner, Critter has first dibs. I wonder if we need new bushings, Z0K bar is same size as stock GXP bar just thicker.
« Last Edit: June 10, 2009, 01:13:12 PM by lil goat »
« Reply #2 on: June 10, 2009, 01:47:30 PM »
I ordered new urethane bushings from Jegs, they are 27 mm and with shipping work out to $20 a set.
« Reply #3 on: June 10, 2009, 03:46:03 PM »
Has anyone found some teflon bushings for our sway bars? I'd like to be rid if the stock bushings squeaking for good.
« Reply #4 on: June 10, 2009, 06:01:42 PM »
The ones I ordered have grease fittings on them, the are not rubber like the stock,  they are just universal sway bar bushings so if you find teflon in 27 mm they should work. Even if you don't upgrade the sway bar these should be better than stock and you can lube them. Heck why not for $20. I think I will do the front ones too just the bushings, after I do the rear bar.
« Reply #5 on: June 10, 2009, 06:52:51 PM »
Shoot, ones like that with grease fittings alone would make life much simpler. $20? That's almost a no-brainer.
« Reply #6 on: June 10, 2009, 09:39:18 PM »
Yea I didn't have to think to long about it, the stock ones are about the same price and rubber with no grease fitting. I should have gotten the ones for the front too. Like I said these should help any GXP even with the stock sway bar. I bet it takes all of 10 minutes to change them too.
« Reply #7 on: June 11, 2009, 10:06:09 AM »
Goat,
If you decide to order the fronts, order another set of backs to go with your old swaybar :)
« Reply #8 on: June 11, 2009, 10:14:23 AM »
Seems like if someone wants my old sway bar they should order a new set of rear bushings and an extra set of front ones for me and some crabs at Chandlers  :lol: Cantlers. Jonymac will be doing his too if there are other NA owners that want an inexpensive handling upgrade, one certain spirited woman driver comes to mind.
Offline jonymac
« Reply #9 on: June 11, 2009, 10:16:32 AM »
Oh no Goat - you didn't bet on an install time did you!?  Every time I tell my wife - "Yeah, should only take a half hour"  I end up in the dog house four hours later...
Performance Mods
- Wester’s Race Tune
- Fujita CAI
- Dejon Intake TB Elbow
- Sprintbooster
- DDM Race Backbone & ProBeam
- Z0K Rear End
Other Mods
- Demoneyes
- Rain Sensing Wipers
- Flash2Pass
- Sound Deadener
« Reply #10 on: June 11, 2009, 11:25:47 AM »
I read up on a few people that have installed the Eibach sway bar, same procedure, I think I saw mostly 2 hours some said drop the exhaust others didn't, neither one of us has a stock exhaust but mine drops in about 2 minutes just remove one band clamp, this one time at band clamp, and it's down.  Soooooo maybe if we say it will take 4 hours we can make a parts run to NAPA. I had wings at NAPA last night, I just love there headlight display, and the upholstery was very nice too.
In my never ending search for truth justice and the American way, I have discovered another tidbit of info. It would seem that GM, and the urethane bushing makers recommend that you do not use a petroleum based grease to lube the sway bar bushings, this can cause the rubber/urethane to harden and crack. They recommend a synthetic based grease with PTFE, the one they spec only comes in 5 gallon buckets, just a bit more than I need. I did find some in a smaller amount 3 ounces for $3.33 on Amazon or at Ace Hardware. It's called Super Lube Synthetic Grease With PTFE Teflon. I am now trying to find it is a grease tube for a grease gun.
« Last Edit: June 11, 2009, 12:27:58 PM by lil goat »
Offline jonymac
« Reply #11 on: June 11, 2009, 04:38:53 PM »
should we take the super lube to NAPA?
Performance Mods
- Fujita CAI
- Sprintbooster
- Z0K Rear End
Other Mods
- Demoneyes
- Flash2Pass
- Sound Deadener
Offline Duck1313
    • Facebook
« Reply #12 on: June 11, 2009, 05:14:35 PM »
Where/Who do you order them from? :drag:
« Reply #13 on: June 11, 2009, 05:21:11 PM »
Order what, wings from NAPA and yes the lube would be good to take with us ya never know when we might need it, the GXP Z0K sway bars from GM Parts direct, the sway bar bushings from Jegs, the lube from Amazon.
Ben L
« Reply #14 on: June 11, 2009, 05:46:05 PM »
What!?  You are lubing the Amazons?  You are going to get your face slapped!
« Reply #15 on: June 12, 2009, 12:22:56 AM »
Goat did you hear something about Amazons?  No.  I didn't think so, must have been the wind. :drag:
« Reply #16 on: June 12, 2009, 06:28:26 AM »
I got nothing against Amazons, some of my best friends are Amazon's, why do ask essay, did someone say something about Amazon's
« Reply #17 on: June 12, 2009, 09:44:52 PM »
No I guess not.
For the record I got nuthin against Amazon's either.  I wonder why I thought of Amazon's though. :huh:
Offline yellowsky
« Reply #18 on: June 13, 2009, 11:30:27 AM »
hmm is this sway bar bigger then the one that comes on the RL? i dont remember?/
« Reply #19 on: June 13, 2009, 12:26:26 PM »
The rear GXP/Z0K bar is STIFFER than the FE3 rear bar by about 18-20%, but I don't know the dimension.
« Reply #20 on: June 13, 2009, 12:57:39 PM »
Both the Z0K and the stock GXP/RL are the same diameter they are both hollow, the Z0K has thicker walls so it is stiffer, both are 27mm diameter
« Reply #21 on: June 13, 2009, 01:19:50 PM »
THAT could make cheating sort of easy, wouldn't it ?!?!?!?!?!
« Reply #22 on: June 13, 2009, 06:38:34 PM »
We wont' say anything
« Reply #23 on: June 15, 2009, 07:13:21 AM »
I had not thought of that, but why yes it could. I am only going by quoted specs so far, but my Z0K bar and Jonymacs should be here this week, but he is not getting his until I get my damn doors handles! I don't care how many parts we get from NAPA.
Offline jonymac
« Reply #24 on: June 27, 2009, 04:49:17 PM »
LOL!  Well Goat - you're not getting your windscreen until i get my Z0K bar!
Performance Mods
- Fujita CAI
- Sprintbooster
- Z0K Rear End
Other Mods
- Demoneyes
- Flash2Pass
- Sound Deadener
