Author Topic: Questions about front fascia removal on a GXP  (Read 5516 times)
Offline KWhale
  • Playing with my
« on: July 07, 2009, 01:07:34 AM »
I've decided that one of my winter projects will be to install a Dejon Intercooler and pipes.  Because I usually only do simple things on the car such as oil, differential, transmission fluid changes, change plugs etc, I want to make sure I'm not biting off more than I can chew here.  Step 1 is to make sure I can get the fascia off and on again, which seems to be about 1/3 of the work required when doing the intercooler swap.
The first thing I did was read the service manual.  The explanation was written for someone who knows what they're doing (mostly ruling me out!), but was a good start.  Then I searched all the Solstice forums and found a couple of good post with pictures which also helped quite a bit.  Then I grabbed a flashlight and crawled in and under the car.  There are a few things that were sort of glossed over though, and I just KNOW that these little niggley things will bite me in the butt if I don't figure them out first.  So I have 3 questions that may seem very simple to most of you, but keep in mind I've never taken the fascia off of any car I've ever owned, so if you're responding here, please type slow so that I can follow along.
Question #1
   On the GXP there are brake cooling tubes that go from the fog light area and pass through the wheel liner.  How are these disconnected?  Do they just pull out of the liners when the fascia comes off, or do they need to be taken off of the fascia and left sticking into the wheel liners?  I couldn't really see any fasteners that could be undone, so this one has me stumped.
Question #2
   I crawled under the car to look at the retaining clips.  side note - it appears there have been a few "incidents" and there are a lot of scratches under there :lol:.  Personally I am not a fan of plastic retaining clips, and have little or no experience with them.  Are they reusable or should I purchase new ones?  If I've bonked them on the pavement a couple of times, will they be shot when I pull them out, so I should plan to replace them anyway?  IF I should replace them, does anyone know a part number for them?  I can't find a part number anywhere.
Question #3  (this one is just to build my confidence)
   There are quite a few people who have done this over the years.  Are there any gotchas I may run into that most people do not talk about?  ie, do you have an embarrassing experience with fascia removal you would like to share?
   I noticed that we don't seem to have a How To in Joe's Garage for facia removal yet.  I plan to do a practice run in a week or two, so I'll take some pictures along the way, and hopefully we'll end up with a How To that even rookies will be able to use.  Thanks in advance to those that respond with their first hand knowledge / answers / embarrassing stories!
Ben L
Re: Questions about front fascia removal on a GXP
« Reply #1 on: July 07, 2009, 06:48:25 AM »
Good questions!  I have never had the front clip off, unfortunately.
I will be watching this thread with interest.
Offline Administrator - Contact DeepBlueGXP
  • Contact DeepBlueGXP for assistance
« Reply #2 on: July 07, 2009, 07:25:56 AM »
The plugs only have a 1 or 2 use lifetime, no need to experiment.  Read this thread thanks to BLK GXP!
http://kappaperformance.com/forum/index.php?topic=244.0
« Last Edit: July 07, 2009, 03:59:02 PM by DeepBlueGXP »
Email KappaPerformance at yahoo.com
This is DeepBlueGXP's Admin account.
« Reply #3 on: July 07, 2009, 07:31:17 AM »
I have done it several times, in my experience all the write ups I read removed more than necessary, there are several 7 mm screws along the edge of the bumper, remove those, a couple are in the wheel wells, turn the wheels so you have room to work. On the plastic clips they make a removal tool should be available at any auto parts store, looks like a fork with the middle tine missing, really worth buying. You should not need new ones, but I keep a couple of spares, good chain hardware store sells them cheaper that the auto parts stores. The brake ducts just pull out, they are kind of a pain to get back in by yourself unless you have really long arms, bumper is very light anyone can help. Put a nice soft blanket or quilt in front of the car, so when you pull the bumper (again easier with 2 people) you have some place to set it down and not scratch the paint. I is a lot easier than you would think. You will need a dremel to trim the plastic behind the intercooler, take off about 1/4 inch. The intercooler is 4 bolts and some hose clamps, get some t-bolt clamps if you haven't already, might as well you are already half way there. I replaced the factory intercooler hoses with red silicone ones, I had to buy a 12" piece and cut them, they need to be about 4 1/2 " the factory ones or ones from Dejon are fine, I just wanted red ones. don't forget to unplug the turn signals, very easy connector on the front of the bumper.
« Reply #4 on: July 07, 2009, 08:59:57 AM »
Thank you for this, I just ordered Dejon's IC with silicone coupler and t-bolts.
If I would do this to myself I will try to make some pictures.
Offline KWhale
  • Playing with my
« Reply #5 on: July 07, 2009, 09:17:39 AM »
Thanks guys!  Deep - that thread you pointed out is one of the ones I had bookmarked during my searches, but it covered more than just taking off the fascia and glossed over some of the fascia removal steps (remember, this is for the total beginner of fascia removals).  It also did not mention the brake cooling tubes, and seems to indicate removal of screws in the wheel well that do not actually need to to come off.  That was a great thread for pictures though.
LG - I was planning on doing another question thread for the hoses later if I can get the nose off and on with ease.  The intercooler swap seems simple enough, even with the dremel trimming that's required.  I just wanted to make sure I can do this facia part of the task before I order the parts and then end up not being able to even do Step 1 :lol:  My plan was to order the pipes and clamps from Dejon at the same time, since I still have the stock clamps on mine.
So far so good, I think I have the answers to most of my questions.  I think I'll pop off one of the clips (assuming they are all the same?) and take it around to a few hardware stores looking for new ones.  I have a set of nylon prying tools for the interior work (where I am in my comfort zone a little more) and one of those looks like a good fork shaped candidate to use for removal of the clips.
Now -- That just leaves Question #3.  Someone must have an embarrassing moment to share that happened to them while doing this???  Dropped the fascia?  Busted the fog light lenses?  Lost the bolts/clips?  The dog ran away with the fascia while it was on the ground???
Offline KWhale
  • Playing with my
« Reply #6 on: July 07, 2009, 09:23:37 AM »
Right on Kelu!  It sounds like we have the same plan, except I don't plan to do mine until winter.  I do plan to do the fascia removal only in the next week or two as a test.  Your car may have some differences due to the fact it's an Opel version, which is more Sky similar than Solstice similar I think?  I will be very interested to see how the pipes and clamps replacements go for you.  That is probably going to be the hardest part of the project, and I was leaving those questions until later.  If you can take pictures and post them as well that will be very helpful.
Good luck with your install!
« Reply #7 on: July 07, 2009, 09:26:25 AM »
The brake cooling tubes just poke through.  Easy to forget when installing so you need to pay attention to them when re-assembly or the bumper allignment will be tough.  Remove the IC pipes first and install last.  IF you aren't upgrading the air box, make sure you cut the corner off the passenger side mount or the passenger IC pipe will rub against the hood hinge.  Also make sure you slide the IC pipes down as far as possible to prevent rubbing.
« Reply #8 on: July 07, 2009, 09:46:06 AM »
And if all else fails a SawsAll is your friend :rofl:
« Reply #9 on: July 07, 2009, 10:47:03 AM »
KWhale Actually I made the order some hours ago, hopefully in a a week or two I will have it.
Even I will not install this myself I will ask the person who makes the install (a friend of mine or a "mechanic") to stop each step to make pictures, I'm sure I will be cursed and sworn :D
My Opel is very same as Saturn Sky RedLine but another informative might only help.
Offline Imaj
« Reply #10 on: July 07, 2009, 03:35:55 PM »
I just took my front fascia off for a repaint. Just follow the Administrator's thread and it is a no brainer. A few things I did (Or did not do) when putting the fascia back on....
I did not reinstall the brake cooling tubes or the piece they connect to that is behind the fog light grate. Also, I did not reinstall the metal clips that hold the front grill. All is well. Good luck!
Offline KWhale
  • Playing with my
« Reply #11 on: July 07, 2009, 05:07:25 PM »
Thanks Imaj.  I can understand not putting the grill clips back on, but, why did you decide to leave off the brake cooling tubes?  You must have a hole showing on both your wheel well liners now, and a messier engine compartment I would guess?
« Last Edit: July 07, 2009, 09:55:08 PM by KWhale »
