Author Topic: Antenna Delete  (Read 19543 times)
Offline odiaz
  • Deep GXP
    • Cherod/solstice
Antenna Delete
« on: August 09, 2009, 07:38:20 PM »
I think I got the shortest antenna available, 0"
I used a Metra amplified windshield antenna to replace the stock antenna. It worked great and reception is slightly better than with the stock antenna. I removed the stock antenna and for now I am using a small black rubber shelf peg cap to cover the threads. Eventually I might remove the base and have the hole welded shut and painted.
I wrote up a set of instructions and placed them on my web site. You can find them here:
http://www.cherod.com/solstice/HowTos/AntDel.htm
Be very patient with this link, there are a lot of pictures and they will take a while to load
Re: Antenna Delete
« Reply #1 on: August 09, 2009, 08:41:46 PM »
You might want to check your how-to page. It sdoesn't seem like the images are matching the text...
Re: Antenna Delete
« Reply #2 on: August 09, 2009, 08:45:20 PM »
Nice write up.
Now you have me thinking about going the opposite way.
Since the wires are already pull to the rear of the vehicle,
I wonder if you could extend antenae from the stock location to the center of the trunk lid, and in effect, use the entire trunk for the antennae.
My main going would be to just eliminate the antenae on the ride side of the vehicle and only have the XM one visible.
I don't care if I'm not using it.
Where did you get this part from?
Offline BLK GXP
  • Rollin'
Re: Antenna Delete
« Reply #3 on: August 09, 2009, 09:59:00 PM »
This is a great idea. I put a stubby CF antenna on mine, but the reception suffered greatly, so I put the half stock one back on.
Offline odiaz
  • Deep GXP
    • Cherod/solstice
Re: Antenna Delete
« Reply #4 on: August 09, 2009, 11:29:22 PM »
Thanks for letting me know about the pictures. Some of them got renumbered during the file transfer.  I have no idea how that happened.  the original on my laptop was OK so I'm reloading the pictures again.
The antenna is sold by various vendors on the internet.  just do a Google search for Metra 44-UA200.  This antenna is fairly inexpensive.  You can pick one up for about $20-30.
Re: Antenna Delete
« Reply #5 on: August 10, 2009, 05:10:37 AM »
Great job, nice write up
Offline amo
Re: Antenna Delete
« Reply #6 on: August 10, 2009, 12:38:30 PM »
So if we put this in with an aftermarket radio we wont need the antenna adapter, right?
Offline odiaz
  • Deep GXP
    • Cherod/solstice
Re: Antenna Delete
« Reply #7 on: August 10, 2009, 01:12:23 PM »
Correct, the adaptor was only necessary for the stock radio.  The Stock Radios use the same type of antanna connector as the 2002 and newer Chryslers.
Offline HAMMER DOWN
Re: Antenna Delete
« Reply #8 on: August 10, 2009, 08:27:44 PM »
Very well done, great writeup  :award: It's what this car 1st. should of came with or at least 2nd what I did,  How To - Install a Power Antenna.
http://kappaperformance.com/forum/index.php?topic=1251.0
Mike
Offline Excelsior
Re: Antenna Delete
« Reply #9 on: August 10, 2009, 11:02:53 PM »
I love my Opel GT Antenna.
Offline odiaz
  • Deep GXP
    • Cherod/solstice
Re: Antenna Delete
« Reply #10 on: August 10, 2009, 11:37:26 PM »
Thanks Mike,
I was actually reading your post on the power antenna.  I was trying to see what would be involved in completely removing the stock antenna base.  My neighbor owns a body shop and he welded the antenna hole shut on my mustang and painted over it.  It came out great, you can't tell there was an antenna there at all.  I'm thinking of doing that to the Solstice.
Offline tekenaar
  • Cunning Linguist
Re: Antenna Delete
« Reply #11 on: February 05, 2010, 05:42:00 PM »
Anyone happen to have the GM P/N for the Opel GT antenna??
1985 Bitter SC 3.9CIH FI 5S 3.44P
2009 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P
Re: Antenna Delete
« Reply #12 on: February 05, 2010, 06:15:10 PM »
The antenna is $11.77, plus shipping of course and the part number is 25805645.
http://www.gmpartsdirect.com/results.cfm?singlepart=1&partnumber=25805645
Re: Antenna Delete
« Reply #13 on: February 05, 2010, 07:50:09 PM »
By the way, I did this delete, and I'm not happy so far. The reception is crappy, but I'm going to have to try moving the antenna to see if it helps.
Re: Antenna Delete
« Reply #14 on: February 05, 2010, 08:36:05 PM »
Don't they sell on EBay a antenna that is basically a wire type that can go across the top of the windshield so you could delete the stock antenna?
Re: Antenna Delete
« Reply #15 on: February 05, 2010, 08:55:13 PM »
I believe that's what Odiaz was talking about in his original post.
Re: Antenna Delete
« Reply #16 on: February 05, 2010, 08:57:04 PM »
I must be stupid today.
Offline odiaz
  • Deep GXP
    • Cherod/solstice
Re: Antenna Delete
« Reply #17 on: February 05, 2010, 09:20:06 PM »
Make sure the antenna is getting power.  Without power, the reception would be less than desirable.  I get better reception with the powered antenna then I did with the stock antenna.
Re: Antenna Delete
« Reply #18 on: February 05, 2010, 09:38:51 PM »
It's got power. The light is red. I have 2 theories I'm going to try out:
1) I also have a power line for my auto-dimming mirror running next to the antenna cable on the pillar. I don't THINK this is the problem, but unhooking this power is an easy test.
2) I have a coupe. So, this hidden antenna is sitting right above my Onstar box in the center of the windshield, behind some black paint. I assumed this would be OK, since the Onstar is behind the black paint too, but maybe either the Onstar or the paint is interfering/shielding. I'm going to try to move the antenna to clear glass on the passenger side to see if it gets better.
Should be able to try this weekend or early next week. Reception right now is horrible. Easily worse than the shorty antenna that I had in place.
Offline odiaz
  • Deep GXP
    • Cherod/solstice
Re: Antenna Delete
« Reply #19 on: March 27, 2010, 11:15:21 AM »
I'm taking this one step further.  I need some body work done so I will remove the antenna base completely and have the hole welded and painted.  I'll uipdate the instructions and show some pictures when it's done.
Offline crappa
  • What Do I Want To Be When I Grow Up? In Denial
Re: Antenna Delete
« Reply #20 on: March 27, 2010, 03:50:55 PM »
Wanted this to replace a plain old bolt on the chrome belt guard on Linda's Victory. These came in a two pack, and just happen to fit the antenna stud. Needed to cut an 1/8 inch or so off the stud.
Paul
Offline odiaz
  • Deep GXP
    • Cherod/solstice
Re: Antenna Delete
« Reply #21 on: April 16, 2010, 12:15:35 AM »
Antenna delete project is fnally complete.  Just got the car back from the body shop and I think it looks great.  The color match was perfect and it is very smooth.  Noone could ever tell there was anything there.
Re: Antenna Delete
« Reply #22 on: April 16, 2010, 02:10:02 AM »
nice  :thumbs:
Re: Antenna Delete
« Reply #23 on: April 16, 2010, 08:49:23 AM »
Reception sucks tho right?   Looks good and I take it you do not listen to am/fm radio
Re: Antenna Delete
« Reply #24 on: April 16, 2010, 10:57:27 AM »
I soooo wanna do that too and somehow tie into the Satellite antennae on the truck.
I wouldn't mind finding something similar in size to the stock XM antennae that is designed for AM/FM
I would think that if I can turn the entire rear deck lid into the antennae, it would get better reception
Anywho
that looks great.
