Author Topic: Front sway bar bushing upgrade  (Read 46847 times)
Re: Front sway bar bushing upgrade
« Reply #25 on: September 04, 2009, 07:13:00 PM »
OK I get most of what you said Bob, I have the HKS coilovers, they spring rate are whatever HKS made them. What I was reffering to was the the actual bushing and bracket are very different in size. OK here is the stock bushing and bracket O
Here is the polyurethane one O the wall of the bushing is about 1/4 as thick all the way around. Enough that it changes the angle between the end link and bar. I was reading about all this on the Hotchkis site. I do not fully understand all this admittedly, and I know what happens with my lowered suspension and different spring rates, may not be the same on a car with the stock suspension. If I still had stock suspension, I would not hesitate to spend $20 to see what would happen, for now I like the reduced vagueness of the stiffer bushings but am not completely used to it, there is something that is not quite right for daily driving, it is great out running the twisties, and have I not been to the auto X yet. I think I need a bit of fine tuning in the damping but that is pretty easy. I can certainly feel the difference, was not sure it would be noticeable.
I think you are feeling exactly what I did. WITH the poly bushings the response is certainly different than the stock bushings. What motivated me to go BACK to the stock bushings is that the poly bushings are SO tight on the bar that I absolutely KNOW that they are restricting the movement of the bar!! When I jacked up the car from the right, the right front wheel wheel SLOOOOWLY dropped into its position once it was in the air. I immediately swapped back to stock bushings and that did NOT happen. I know I have the correct i.d. poly bushing. Hwat I may do is hone out the poly bushing so that it is not "pinching" the bar.
As for the possible variables of "positioning" the sway bar, I'll just say this. I am not Mark Donohue, so I doubt I'll feel the difference. This may be a different application of the "dyno discussion" !!!!!!!!!!!!!!!!
« Reply #26 on: September 05, 2009, 12:42:59 PM »
U-238 measured the bar it is not 33mm but 33.5mm. On mine there is a small gap so I am ordering 34mm bushings. I did some VERY high speed driving this morning, at high speeds, I mean above 80 the cornering is much improved and you can really feel a difference, at slower speeds it is not as smooth and that may be the bushings being tight. I really really like the high speed feel, out on a road course these would work very well. I will take a picture of the stock bushing today, others are on the car but I can take a picture of the new 34's when they get here. It is a huge difference in the wall thickness.
If the bar is free to move in the poly bushings you'll get the handling without the low speed binding. I plan on trying honing out the poly bushings (just a little) and see how they feel.
« Reply #27 on: September 08, 2009, 08:06:45 AM »
The 34's are on there way, today it is raining, and it's been raining all night the back end stepped out quite easily this morning, was easy to control but for certain came out easier than before. I need to reduce damping or maybe the 34's will help with this. I thought about honing them out but, even though I ordered the greasable ones I got the non greasable 33's. At $12 wasn't worth sending them back, new 34's  have grease fittings. Jegs has them.
I forgot to post something yesterday. My FE3 front bar measured 33.2mm (at the bushing) and the GXP/Z0K bar measured 33.4mm. I sanded the paint off at the bushing location on the "big" bar and they both measured 33.2mm. The 33mm poly bushings measure UNDER 33mm (actually about 32.4mm) in their bracket and off the car. Since my Solo season is basically over after the Nationals the 34mm bushing become part of the 2010 to-do list. I'll be checking the rears as well for the same "issue".
« Reply #28 on: September 16, 2009, 06:28:04 PM »
When I installed the front bar I use the same bushings as the FE3 bar and had no issues.
Order the Z0K rear bushings  and installed those. I have the Jeg's for the rear but thought to stay with the Z0K bushing parts instead.
« Reply #29 on: September 17, 2009, 07:32:46 AM »
What are the Z0K bushings made of? There is an advantage to the poly-urethane even if you don't change the bar, especially on the front. Those big rubber things are awful. Changing rubber bushings to poly is nothing new, I did it on my 1973 Datsun 240Z and my 1972 Datsun 510 a very long time ago (30+years). The factory uses the rubber for the softer smoother ride that many want, I think most people on here would prefer the urethane and for $20 why not, a lot cheaper than lambo doors.
« Reply #30 on: September 17, 2009, 08:41:59 AM »
But lambo doors are SO blingy !!!!!!!!!!!!!!
I think, maybe, they are. Or maybe not.
« Reply #31 on: September 17, 2009, 09:01:24 AM »
Question:  Dave from DDM has convinced me to possibly get both sway bars, front and rear, at the mod meet.  I have a GXP, so should I replace both or just one?  And should I reuse the OEM bushings or ask Dave to get the upgraded ones?
« Reply #32 on: September 17, 2009, 09:10:48 AM »
I think we have answered this already, the stock bushings will not work for the rear bar, get some 27mm Universal greasable fittings from Jegs, they are cheap. I did not do the front bar and don't plan on it, just don't see the need, our front bar is huge I did change the bushings to urethane. Jegs has them too, 34mm greasable universal. The front bar is supposed to be 33mm, it's not and the 33mm bushing are not 33mm more like 32mm. So there you go whether you do both or not I would get the new bushings, and I have to ask why you need Dave to buy them for you. Smartin bought her own and she's a girl! I will be installing them.
« Reply #33 on: September 17, 2009, 09:54:54 AM »
Steve, i wanted to test the rear only at first. then put on the front... but i didn't have time to do it. so i just slapped on both. if you have the time to do it, i would recommend it. and if you really want swap between the urethane and rubber bushings. or ride in goat's car then in mine to see the difference. i have rubber.
they are made as a package for racing solstices, they should work well together. i love them, but i haven't pushed my car hard yet to see how it really behaves under high G turbing.
« Reply #34 on: September 17, 2009, 10:22:17 AM »
Cool thanks...it is much easier to have Dave order the correct bar and just bring it to the meet instead of me paying shipping.  Maybe I will just do the rear.  I haven't decided yet.  Goat, maybe you can give me a call later tonight?
« Reply #35 on: September 17, 2009, 10:25:33 AM »
i say buy both and try them both. i think you will probably like both.
« Reply #36 on: September 17, 2009, 10:46:19 AM »
I don't buy what I don't need, to me the urethane is a no bainer, this is not my first rodeo been upgrading to urethane on just about every car I have owned for a very long time. Why do I want to negate the effects of the sway bar with rubber bushings, just seems dumb to me, hard cornering the rubber compresses and allows the sway bar to move out of alignment. Why would I even have to think about this? But then again I am not young enough to remember what it was like to know everything. Many many people have stated that they do not like the Z0K bar on the front of our cars, causes increased understeer and they are from a small group called the SCCA. If you have enormous tires (like Bob) I can see the advantage of the heavier bar. You will see the same kind of benefit from the stiffer bushings, as it also allows less flex. Which leads me to the conclusion that if I were to put a Z0K bar on the front of my car I would most likely use the Z0K rubber bushings. To me $20 for bushings and 5 minutes to change them makes more sense. Then again I have always had a lot more sense than money. If I had an NA, I would certainly try and find someone who had upgraded there GXP and get there old bars, front and rear.
« Last Edit: September 17, 2009, 11:06:26 AM by lil goat »
« Reply #37 on: September 17, 2009, 11:09:00 AM »
I am not really experienced with suspension-type things...which is why I count on you guys.  So this is what I should get:
Front ZOK Sway Bar
Front ZOK Sway Bushings
Rear ZOK Sway Bar
Rear Urethane Bushings from JEGS??  What size again?
« Reply #38 on: September 17, 2009, 12:24:29 PM »
Not in my opinion no, but if that's what you want, I hate the understeer up front and want more neutral. The stiffer front bar is known to increase understeer, I have the Z0K rear only and urethane bushings on both front and back and I am very happy! The front bushings made more of a difference than you would expect. I love the precise steering I have know and will have Ben's opinion on my setup by tomorrow night, I am giving him a short ride and am making him drive my car then we head to Cumberland airport where I will really be able to judge my setup. I can tell you I have been able to drive roads I am very familiar with at much greater speed and with more confidence. I tend to go at suspension changes in subtle stages, I did the backbone, so I knew what it did and could judge the change, then I did the Pro beam and could judge what it did, and the coilovers, got a point of reference, then the Z0K rear bar, again point of reference. Then the front bushings and again a point of reference. If I had done several changes at once and didn't like it, what would I undo? I do not make changes because it is the new shiny thing, I love Dave from DDM to death but for God's sake can you trust a man who used to drive a Miata and now drives a Mini! Just kidding Dave! I like the stepped approach, but that is just my opinion. None of the suspension upgrades are that hard except the coilovers, and I think I would look hard at them before I would upgrade the front bar, but that's just me.
Offline kwtoxman
« Reply #39 on: September 17, 2009, 12:41:37 PM »
The GXP Z0K is different from the base Z0K. Bear this in mind when discussing.
Front ZOK Sway Bar
Rear ZOK Sway Bar
For the GXP Z0K, the parts guy told me the Z0K front swaybar bushing is the same part number as stock (ie FE3 suspension). The Z0K rear swaybar bushing is a different part number than stock (FE3). So, IMO the rear should have the new bushings (or polyurethane ones), the front doesn't need a bushing change. The clamps are the same part number so there is no need to change.
« Last Edit: September 17, 2009, 12:49:36 PM by kwtoxman »
:ca2:
« Reply #40 on: September 17, 2009, 12:54:20 PM »
Snaponbob measured the stock front bar and the Z0K they are indeed the same size so that is correct, but have you looked at the bushing? It is HUGE, and awful lot of rubber to compress, if my 34mm urethane ones ever come in I will take a picture of them compared side by side to show the difference, my guess is that GM in it's fondness for understeer made the front bushings so huge to help with this, they are easily twice as thick as the rear stock bushings.
Offline DragonSolGXP
lil goat - part number or URL at Jegs?
« Reply #41 on: September 17, 2009, 12:56:43 PM »
Hi lil goat,
Do you have a part number for the front (stock GXP) sway bar (or URL for the Jegs page). I  checked out the site, but can't find 34mm. Just 33mm and then 35mm. Nothing in between
Also, does anyone know the size/diameter for the stock rear sway bar on the GXP?
Thanks.
2008 Mean Yellow GXP, RDC Exhaust, Westers Race Tune, BC Racing coil overs, ZOK Rear Sway bar and poly bushings front and rear.
Offline kwtoxman
« Reply #42 on: September 17, 2009, 01:16:15 PM »
Hi lil goat,
Thanks.
Same thing for me. I can find 33 and 35 mm universal greaseable polyurethane bushings at jegs. That's it. They are also style A only ! - energy.
« Last Edit: September 17, 2009, 01:43:41 PM by kwtoxman »
:ca2:
« Reply #43 on: September 17, 2009, 01:19:28 PM »
OK... I just ordered the  ZOK rear bar from Crate Engine Depot. So what's the size on these for the rear? 27mm?
Thanks Guys, Just about have the BC shocks dialed in, need to make an adjustment on height before the alignment. Do I need to install the back sway bar BEFORE I get an alignment? Or can I do the alignment for the sway bar swap?
« Reply #44 on: September 17, 2009, 01:24:01 PM »
Also... Do we get "Style A" or "Style B"
« Reply #45 on: September 17, 2009, 01:46:33 PM »
http://www.jegs.com/i/Energy+Suspension/355/4-5193G/10002/-1
Greaseable bushing is the best
Energy Suspension #355-4-5193G
# Front Sway Bar Bushings 34mm Sway Bar Diameter
# 2005-Up Mustang
# Black
 I am hoping mine will be at the house when I get home.
« Reply #46 on: September 17, 2009, 01:49:03 PM »
I wanted to try the back bar only first. But didn't have time to test both and I needed them done before I get my car inspected for a track weekend with porsche club.
I will do the track day, then play around. swap the front bar back to stock. then play with urethane bushings. i like to do things incrementally so i can tell how each part effects the ride.
« Reply #47 on: September 17, 2009, 01:49:43 PM »
Correct. Front bar uses stock size, rear bar needs a larger size.
Offline kwtoxman
« Reply #48 on: September 17, 2009, 01:56:11 PM »
# 2005-Up Mustang
# Black
Let us know if this works when you get it. It appears to be only the bushing, no clamp. I have no idea if this bushing will work with the solstice clamp.
This part also appears NON-greaseable. The link you have and pic look to me to be a universal description. Note how it talks about sway bar bushings, and then separately greaseable swaybar bushings.
http://www.energysuspension.com/search-result-details.html?id=1570&make=&year=&model=&partNumSearch=4.5193G
« Last Edit: September 17, 2009, 02:08:43 PM by kwtoxman »
:ca2:
« Reply #49 on: September 17, 2009, 02:06:33 PM »
The rear - for sure. The front is cheap enough that you can get it and try the FE3 and then the bigger bar and stay with the one you like. For daily driving you can stay with the rubber ones. No biggie.
