Author Topic: What did you do to your Kappa today!  (Read 1544389 times)
0 Members and 6 Guests are viewing this topic.
« Reply #3950 on: May 22, 2011, 06:47:34 PM »
Watch (supervised) Joe and Joey while they cut and hacked away at the front of my car.  Learned some new words as well.  Shame on you Joey
« Last Edit: May 23, 2011, 08:38:22 AM by Critterman »
Offline JimmyBaja
« Reply #3951 on: May 22, 2011, 06:57:52 PM »
So how'd it turn out?  :ttiwwp:
« Reply #3952 on: May 22, 2011, 07:03:34 PM »
We decided not to do a DYI, it is extremely difficult.  Getting the old off, and finally putting the new cover on were the easy parts.  It was the 3 hours of cutting, trimming, and fitment that was a killer.  We also didn't think about a camera until it was too late, we were not going to put it back on at that point.
PM me your phone number and I will send you a pick, I have one one my phone.
Offline JimmyBaja
« Reply #3953 on: May 22, 2011, 07:44:11 PM »
Will that improve airflow into the intercooler any?
« Reply #3954 on: May 22, 2011, 07:48:12 PM »
cruising at 62 on cruise, ambient and intake were identical.  Intake used to be 2 degrees warmer.
Offline IBDRINKEN
  • Donkey Master
« Reply #3955 on: May 22, 2011, 08:12:56 PM »
IBDRINKEN, check your fuses, I think there is a fuse and/or a relay that controlls the clutch to engage the a/c compressor.
Thats the first thing I did was check the 10a fuse and it was good to go. There is a bigger fuse that is the ac clutch fuse as you stated so I guess I will just replace that one and go from there.
« Last Edit: May 22, 2011, 08:42:09 PM by IBDRINKEN »
13.5@101.90
320HP 358 Torque
Kappa Intake
JPM Shifter, Center Console
DDM Intercooler
AEM Water/Meth Injection
« Reply #3956 on: May 22, 2011, 11:15:47 PM »
I let the rain clean the pollen off mine today
Offline duckSol
  • Onward through the fog
« Reply #3957 on: May 22, 2011, 11:27:45 PM »
Grilled ribs and worked on nose chiggers after taking the ferry home.
Offline JimVonBaden
« Reply #3958 on: May 22, 2011, 11:33:24 PM »
Welded on a set of clean painted exhaust tips.
Old
Dropped
Sitting on a jack stand
Removed tip
New tip on
Complete
I know the left one is off a bit, but no more than stock, and they look great!
Let's see how they hold up? I am having the others powder coated silver just in case.
Total time about an hour, and that was because I suck at welding.
Jim :cool:
« Reply #3959 on: May 22, 2011, 11:50:50 PM »
Nice work, Jim! :thumbs:
Offline JimVonBaden
« Reply #3960 on: May 23, 2011, 12:00:53 AM »
Thanks Susan. We will see how it holds up!
Jim :cool:
« Reply #3961 on: May 23, 2011, 05:25:04 AM »
Yeah they look great Jim.
« Reply #3962 on: May 23, 2011, 06:52:52 AM »
Installed dual exhaust on the coupe. :brnout:
Installing Norms F430 front bumper and rear finned diffuser on the vert. Pics to follow when completed!!! :drive:
Which exhaust did you put on the coupe?
my ac stopped blowing cold today so Im thinking its out which is weird since I only have 40,000 miles on it...
Does it come on when you put the dial on defrost?
Did you try the AC recalibration?
Painted?  I thought you were getting them chromed?  I don't think the paint will hold up to the harsh environment of the exhaust gases and heat.
Offline JimVonBaden
« Reply #3963 on: May 23, 2011, 08:34:27 AM »
They wanted $85 each for chrome. I just couldn't justify that. I have the other ones ready to be powder coated. I agree, they likely wont hold up, but I couldn't resist installing them. It is super easy to drop the exhaust, and I only tack welded these on so I can remove them again prety easily!
Jim :cool:
PS Anyone know a place to get chrome at a "reasonable" price?
« Reply #3964 on: May 23, 2011, 08:56:35 AM »
Norms GXP spoiler won't fit on a NA
Yeah I know DBG, but I don’t care for the mini-winglet style of the NA .  The GXP air dam looks is such a cleaner design which is why I’ve been thinking of picking up a GXP fascia.
Penny for your thoughts....  anyone think a wider but definitely not 'taller' lip spoiler would look good on the Sky?  Maybe similar to the whale-tail on the Crossfire SRT-6 that is has a flat-profile, but wider and more functional for downforce?
anyone prolific with photoshop?
Unless you have access to a wind tunnel who knows, in fact does anyone know if it's purely cosmetic or performance?
« Reply #3965 on: May 23, 2011, 09:01:12 AM »
i agree ! only aerodynamic tests could give any data
« Reply #3966 on: May 23, 2011, 09:11:46 AM »
From experience (well Joe's experience, I supervised :)) if you decide to go that route (GXP facia) make sure you get everything behind the facia cover as well, all the supports, crush material, and shrowding.  The facia will not fit over the NA structure without it.
Offline smarty
« Reply #3967 on: May 23, 2011, 09:15:39 AM »
I used my stock GXP exhaust.
« Last Edit: May 23, 2011, 04:34:50 PM by smarty »
2008 Gxp Aggressive Mods: GMPP CAI and Tune; DDM Race Backbone, Probeam, Led Hood and Trunk Lights and Lambo Doors; Molded flaps, Solo Street Race Exhaust, Norms F430, winged rear diffuser, Joe's side marker light mod with leds, Windblade, with the Bull Dawg!...
« Reply #3968 on: May 23, 2011, 10:47:16 AM »
OK, thanks Critter because I thought it was nothing more than a remove & install, though I knew I'd have to pick up the GXP turn/running light grill.   Anyone know of a thread dedicated to it off-hand?
Offline duckSol
« Reply #3969 on: May 23, 2011, 11:06:52 AM »
Far from it Chop. A lot of the parts you need are very hard to get if not impossible. Been there for 7 months.
Offline IBDRINKEN
  • Donkey Master
« Reply #3970 on: May 23, 2011, 03:50:22 PM »
So I repalced all the ac fuses and its a no go, looks like I have to bring it in to the damn dealership...
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
« Reply #3971 on: May 23, 2011, 04:29:20 PM »
did you try the recal procedure?
Offline IBDRINKEN
  • Donkey Master
« Reply #3972 on: May 23, 2011, 04:49:43 PM »
Im not aware of this..
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
Offline JimmyBaja
Offline IBDRINKEN
  • Donkey Master
« Reply #3974 on: May 23, 2011, 06:42:33 PM »
thanks guys i did the reset and still warm air. Looks like it needs to be recharged..
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
