Author Topic: DDM Hood Light - add a mecury switch  (Read 7285 times)
« on: November 23, 2009, 08:26:14 PM »
What do you think about this switch.
http://www.amazon.com/gp/product/B001TWQ0KC/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B0002ZPBKM&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1J34786EQP9D0JD0HRJF
I may get a few to set up with the hood light so when you open the hood it'll turn on the  light.
Re: DDM Hood Light - add a mecury switch
« Reply #1 on: November 23, 2009, 08:52:20 PM »
Let me know if it works, that is what i wanted under my hood
« Reply #2 on: November 23, 2009, 10:47:08 PM »
Depends on if you will see the lights flickering with acceleration / deceleration or if you mind the lights being on if you park it on too much of an incline.  LED's don't draw too much power, so it's not like battery drain would be a concern...
Offline nolanb
« Reply #3 on: November 24, 2009, 01:19:09 AM »
That is the exact mercury switch I used.  Works like a charm.  I put it in a spot where it only turns on when the hood is almost all the way open.
« Reply #4 on: November 24, 2009, 11:34:30 AM »
Bryan I outed you on the switch to DBG  :D just seemed like a great idea and not quite as expensive as your way cool headlights.
Offline xtrememedic
« Reply #5 on: November 24, 2009, 02:30:40 PM »
  :ttiwwp: could you take some pics please so the rest of us knows where to put the switch...Thanks
« Reply #6 on: November 24, 2009, 05:33:31 PM »
I ordered some, enough for the cone crusher and Go-N Def
Offline Frank I
« Reply #7 on: November 25, 2009, 12:29:33 AM »
Deep:
Shipping charges were way too high at Amazon.  I'm going to try and find a tilt switch locally.  Should be available in automotive parts houses, hardware stores or electrical supply houses.
Frank I
Frank I
Frank I
« Reply #8 on: November 25, 2009, 02:28:40 AM »
Thanks Joe!
Offline LiquidPT
  • TechHead
    • LiquidPT's website
« Reply #9 on: November 25, 2009, 02:46:15 AM »
I kinda like the magnetic reed switch that JonyMac used... avoids "sloshing" flickering on acceleration.
LiquidPT aka Matt
driving Black Sun
Offline Machopirate
« Reply #10 on: November 25, 2009, 02:58:10 PM »
What type of switch is used for the stock trunk light?  Would it work under the hood?
« Reply #11 on: November 26, 2009, 12:08:38 AM »
The trunk light switch is integral to the trunk latch (similar to the door / dome light switches).
Offline nolanb
« Reply #12 on: November 26, 2009, 01:38:36 AM »
I will post a photo with the location I used for the mercury switch once I get back from holiday vacation.
« Reply #13 on: November 26, 2009, 11:30:55 PM »
Muchisimos gracias, Jose
