Author Topic: Extended Warranty questions  (Read 6542 times)
« on: January 18, 2010, 03:39:47 AM »
Hey all, questions about extended warranty / warranties
I bought my 07 GXP used with 11K miles and about 12 months remaining in the warranty.  The original owner had purchased the GMPP (GM protection plan) Major Guard.  He paid over 2K for it I believe.  All I had to pay was a $50 transfer fee within the first 30 days of ownership, which I did.
Anyway, what bugs me is it doesn't cover the TOP!  Convertible is specifically excluded.  What kind of crap is that?  So my question is, who has what extended warranty, how good is it, has anyone used the GMPP and how was it?
I am not out of warranty yet (August 25, 2010) so I am ok for now, but I am worried about the convert top.  There seems to be lots of issues with them as time goes on and I was hopeful that a GM warranty would cover a GM car with a GM roof on it...
Here is a list of what is not covered, taken directly from the GMPP site:
 Component Coverage
 Covered Parts
 •It's as simple as this: If it's not on the very short list of what's not covered, it's covered!
•For years, millions of Major Guard customers have known that, "From the engine to the trunk lock, if a part breaks - even if it results from wear and tear *Wear and Tear Coverage: The applicable coverage in the event an orginal or like replacement part is unable to function in normal service. - and it's not on the list of the few items not covered, Major Guard will pay for the repair less any applicable deductible - whatever the part!"
 Non-Covered Parts
 •Sheet metal
•Body parts, panels and rails
•Bumpers
•Chassis frame
•Cross members
•Hinges
•Trim, moldings, and bright metal
•Paint
•Rust damage
•Convertible and vinyl tops
•Weather-strips
•Carpet and upholstery
 •Exhaust component and catalytic converter
•Tires
•Glass
•Lenses
•Sealed Beams
•Light Bulbs
•Batteries
•Brake drums
•Shock absorbers
•Squeaks , rattles, wind noise and odors
•Correction of air and water leaks
 Unless required in connection with a covered part we will not pay for: engine tune-up, suspension alignment, wheel balancing, filters, lubricants, engine coolant, drive belts, radiator hoses, heater and vacuum hoses, windshield wiper blades, air conditioning recharging, fluids, spark/glow plugs and wires, brake pads/linings and brake shoes/rotors, manual clutch disc, vehicle manufacturer recommended maintenance services and parts.
Every other part is covered!
If this is a repeat of a prior thread, I appologize.  I normally search the site to see if something has been posted already, but I was too lazy and a bit frazzeled (been way under the weather the past few days) and I can't find my GJ! :mad:  oh here it is  :cheers:
Thanks,
Re: Extended Warranty questions
« Reply #1 on: January 20, 2010, 11:29:19 AM »
OK here is the deal, I have the extended warranty. If you buy the extended warranty when you buy the car IT TAKES EFFECT IMMEDIATELY, you will never use your 3 year 36,000 warranty. The extended warranty supersedes it. The top is covered under the factory warranty, and some dealers will still find a way to use it to cover the top. Now, GM has quit replacing tops under warranty anyway except under extreme circumstances, they just have them fixed now. They are in short supply, body shop I deal with, just spent a month trying to get one for a NA that a tree fell on.
Now as far as the extended warranty goes, I love it best money I ever spent. I have already recovered all the money I spent on it, about $1000. I bought mine when I had about 35,500 miles on the car. I have 36 more months and 48000 more miles and can renew it again. On the extended warranty they have already
Done the A/C groan mod
Replaced the coolant temperature sender
Replaced the thermostat
Bled the air from the system for overheating issue
Replaced the factory radio
Replaced the CV boot.
all for free.
Offline Gabes Redline
« Reply #2 on: June 04, 2013, 07:48:24 PM »
I already have the Major Guard Extended Warranty and went to my local GM dealership to see about extending for a longer period of time as my extended warranty will be up in September.  I was told by the financing dept. that to extend the warranty another 3yr/36,000 would cost $2000.00.  Though I feel this a little steep, I know that these cars repairs can be pretty pricey.  Anyone have any opinions on the GMPP extended-extended warranty?  As the car gets older, Im sure more things will break down.
« Reply #3 on: June 04, 2013, 08:49:20 PM »
Gabe, it may be worth the money to not get the warranty and go somewhere else to get repairs than a GM dealer....
« Reply #4 on: June 04, 2013, 09:23:25 PM »
Yeah, I know a GM dealer is not the ideal place to take my Sky, my cracked fenders are proof of that.  I just need something that will keep the car on the road if unforseeable events happen to it.  Anyone have outside estimates to different kappa fixes? ie. water pump, a/c repair, turbo repair.  Thanks for the quick response Deep Blue.
« Reply #5 on: June 04, 2013, 11:51:25 PM »
He could shop around.  I got mine at quite a bit cheaper than what i could at my local GM dealer think the place was in Georgia I would need to to check my paper work.
« Reply #6 on: June 05, 2013, 11:18:44 AM »
FYI California residences,
Anyone wanting to extend their GMPP warranty must do so within the state. As of a couple of months ago, California residences cannot be sold GMPP extended warranty from outside of the state. I called GMPP to verify. So shopping around for the best rate has been limited.
« Reply #7 on: June 05, 2013, 11:21:11 AM »
Yes. Shop around. Dealerships can negotiate the price of the warranty significantly. I got my extended extension down to $750. But ended up selling the car. Shop shop shop and then negotiate.
« Reply #8 on: June 10, 2013, 11:38:38 AM »
I got my extended in 2008 when I got the Car .My 5/50 is almost over come dec.20, 2013 . The dealer said they don't honor the extened 10/100 cause it is not GM I pd almost 1,400 in 2008 and that Sucks Big time.Do I have any recorse . My Pontiac Dealer went Out of Business before Pontiac Corp. did.
   They were with Fidelity Group Ins.Co.  Anybody else have that Co.???
« Reply #9 on: June 10, 2013, 12:42:50 PM »
Bobby-
You need to read thru your Fidelity warranty. It will either say you pay up front and they reimburse you, or you contact them and they pay the dealer.
No dealer is going to honor a non branded warranty.
Let me know what you find. Some aftermarket warranties are good, some are scams. Lets hope for the best with yours.
« Reply #10 on: June 10, 2013, 03:48:17 PM »
I will let you know . I got it through the Car dealer. I will contact them ,thanks for the info
« Reply #11 on: June 10, 2013, 04:57:35 PM »
Bobby-
Steven , thank you very much .Your info was correct I have the Platium Policy that is good until Dec ,20 2015 or 100,197 miles .They told me to just have the Dealer contact them and they will do the Rest Thanks again I owe you a drink at Flagstaff.AZ
« Reply #12 on: June 10, 2013, 06:49:42 PM »
Yeah!!!!!
« Reply #13 on: June 15, 2013, 11:07:10 AM »
Yeah!!!!!
Steven , I just heard from my Ins.Co.  Its a Grand slam YEAH ! they are sending me a check for 1,539.00 thats the total less the Oil change . Now the extended warranty Co said if there are any other problems just call..  thanks again.
 Are you going to Flagstaff to see a few Friends
« Reply #14 on: June 15, 2013, 12:03:47 PM »
I get you $1500 bucks and all I get is a beer?  What a rip off.
What's in Flagstaff?  Sounds boring.
« Reply #15 on: June 15, 2013, 12:33:37 PM »
 You won't know unless you Visit LOL ( Oh maybe 2 beers )
