Author Topic: 2.4 automatic tunes?  (Read 5741 times)
« on: March 27, 2010, 01:23:17 PM »
Does anyone have experience with tunes for the 2.4 engine and an auto tranny? I was asked a few days ago what options are available for that set up but as I have a GXP I'm not sure what's out there.
Lets not start out with turbos and superchargers just the base engine with an auto.
Offline tallcraig
Re: 2.4 automatic tunes?
« Reply #1 on: March 27, 2010, 07:48:14 PM »
Thanks for posting this Sly Bob! There seems to be a lot offered for the "older" 2.4 Kappas but not much for the 2009 automatics. I would like to take advantage of my GMPP CAI and Solo header, HF CAT and SQ-2 exhaust. By the way Bob, I bought a used ECM today on E-Bay but need to find the right tune. Thanks in advance ... Tall    P.S. Solo Rules!
Offline JimmyBaja
« Reply #2 on: March 28, 2010, 07:56:26 AM »
Vector Motorsports can tune the ECM. The TCM is inside the transmission I believe so no one can tune that. Maybe the folks at DDM can explain it better, when they tune for the supercharger they don't/can't tune the transmission but other tweaks are made to the ECM that helps.
Just remember, since you are not having your stock ECM tuned, it will throw an engine code & you will need to take it to the dealer or someone to clear the code & perform a crank position re-learn. You also will have to re-learn the ignition key security but you can do that yourself.
« Reply #3 on: March 28, 2010, 10:17:04 AM »
Jimmy, the TCM as you can see from this illustration is located on the firewall beneath the ECM. If you have an auto it is quite easily accessible.
[attachment=1]
Offline Divingsolo (formely Randy@DDM)
    • DDMWorks - Your total Kappa Performance Solution
« Reply #4 on: March 28, 2010, 02:08:10 PM »
We can tune any year of NA or turbo or S/C solstice/sky. As mentioned above, no one can tune the TCM.  It's not on our website, but if you want it, just call and ask Dave for the details. 864-907-6004.
Randy@DDMWorks.com
www.DDMWorks.com
Offline G8TR
« Reply #5 on: March 28, 2010, 04:19:56 PM »
These guys (DDM) are great at what they do! :thumbs:
« Reply #6 on: March 29, 2010, 01:15:02 AM »
Randy,
any chance you guys are working on cracking the TCM?
Offline JimmyBaja
« Reply #7 on: March 29, 2010, 09:25:38 AM »
[attachment=1]
Sly Bob, I stand corrected. Thanks for pointing that out. I actually had to go out & look, it's hidden under a piece black shielding material. I was passing on information from another source when I was digging for the answer to the same question before I got my tune.
« Reply #8 on: March 29, 2010, 08:49:25 PM »
Yeah I read that in the past as well.  :D
Offline WoWwii
« Reply #9 on: March 29, 2010, 09:44:39 PM »
Do you have a tune for a automatic 2.4 stage II Turbo? or just manuals?
'07 NA Black on Black and Tinted, Solo Cat, Solo SQR-2, Hahn's Stage II Turbo, Wester's Tune
