Author Topic: Boost level with GMPP tune  (Read 5207 times)
Offline bokrock
« on: April 26, 2010, 02:57:05 PM »
I installed the GMPP tune along with the GMPP CAI and was wondering what kind of boost I should be seeing on the DIC gauge ?
Re: Boost level with GMPP tune
« Reply #1 on: April 26, 2010, 03:07:01 PM »
The gauge is limited to 23 lbs I believe.
Offline bokrock
« Reply #2 on: April 26, 2010, 03:13:36 PM »
The most I'm seeing is 18 pounds. When I first bought the car a couple of weeks ago it would register between 13-15 pounds and now after the install it is now registering between 15-18 pounds. Does that seem low if so any ideas ?
« Reply #3 on: April 26, 2010, 03:15:12 PM »
I have hit 19 psi - don't look that often though.
« Reply #4 on: April 26, 2010, 03:39:00 PM »
Only for 2007, 2008 is showing 25psi.
« Reply #5 on: April 26, 2010, 03:45:47 PM »
I usually hit between 18 and 20 #'s.  It depends on the temp outside.  Warmer it is higher.  I am in KC which I believe is around 750 ft above sea level.  There was good older thread where someone was keeping track of boost.
Solo HF Cat and Mach Shorty
Dunlop Dirreza *Spec
1987 Buick Grand National
1978 Trans Am
Trifecta Dealer
« Reply #6 on: April 26, 2010, 03:46:45 PM »
18-19 in 3rd is not bad. might get a bit higher in 4th and 5th WOT. Give it time and it may go higher.
It will vary with different weather conditions and altitude
Offline Brazen17
« Reply #7 on: April 26, 2010, 04:00:08 PM »
I tend to see 19-20 with occasional peaks of 21.  Temps here have been about 80 degrees or so with low humidity and approxiamately 2000 feet elevation.
Offline bokrock
« Reply #8 on: April 26, 2010, 04:14:23 PM »
Thanks for the info guys. I'm at about 1200ft above sea level and our temps haven't been above 60 deg. since I've had the car so it sounds like its doin Ok !
« Reply #9 on: April 27, 2010, 09:58:04 AM »
Air temp, Altitude, Humidity, Plaid, and affect boost.  The first three affect the amount of pressure (boost) needed to make the HP and torque.  The last just looks plain silly in our cars.
« Reply #10 on: April 27, 2010, 11:37:06 AM »
Critter,
Why you got to be like that?  I just ordered a roll of plaid tweed to redo the interior with JPM at the mod meet....  damn... I thought it was going to be looking good...
Boost-
as Critter says, lots of things affect boost.  Pre tune I was seeing anything from 15 to 22 depending on conditions.  After tune, I'm pegged at 23 all day every day.  Judging from others with aftermarket boost gauges, it's more likely 25 - 28 psi.  (07 only reads to 23 as noted above)
Offline bokrock
« Reply #11 on: April 27, 2010, 11:41:37 AM »
I bet you look awful sexy in your plaid sportcoat and hat driving Bixabel down the road !
Offline Lithium Lotus
« Reply #12 on: April 27, 2010, 07:18:22 PM »
I'm about the same elevation. My average is between 20-21psi at full throttle. I do hit 22psi occasionally.
07 GXP: Natsumi "Summer Beauty"
Sold 08/2010
« Reply #13 on: April 28, 2010, 12:52:49 AM »
Plaid is so common you should look into a proper tartan.
