Author Topic: I love a 283 ! Am I the only one in the world?  (Read 10230 times)
Offline Dan Furr
« on: June 23, 2010, 07:28:26 PM »
I would love to put a 283 in my Solstice. I loved the 283 back in the 60's. A friend had a 1960 Vette with a 283 and it was wonderful.
Am I the only guy in the world that doesn"t want 400 ci ? :sorry:
Would Mallet or Dave do a 283/Solstice? :poke:
                                                          Dan Furr :cool:
Re: I love a 283 ! Am I the only one in the world?
« Reply #1 on: June 23, 2010, 07:55:19 PM »
I think it would be a lot more difficult to put a 283 in the kappa, while it is a great small block, it is not an engine that is made for electronic control.  You would have to really go old school to install and set it up.
Offline Dan Furr
« Reply #2 on: June 23, 2010, 08:02:02 PM »
Is there a modern engine about that size?
« Reply #3 on: June 23, 2010, 08:08:11 PM »
The current 4.8 is as close as GM gets as far as I know.  It is a 293 CI modern electronic control engine.  Should be plenty of help for it out there.
Offline Rogue
« Reply #4 on: June 23, 2010, 09:43:35 PM »
GM is now offering the LS based 5.3 as a complete crate engine for some amazing low price. It's not a 283...but it is a 327! 327 HP with a mild cam, iron block, aluminum heads...and GM is preparing a complete ECU to go with it. List price (w/o ECU) is $4030. Street prices are approx $3175 to $3600. You can read more about it in the Sept 2010 issue of High Performance Pontiac, now on newstands.
Go N.A.K.3.D..
Offline ChiliSky
« Reply #5 on: June 23, 2010, 09:57:55 PM »
I have a 283, I have a 1967 Chevy Implala Ragtop, Irmine white with black interior....It was built at the same plant as my 07 Sky....40 years apart.....both have those LINES that ya just gotta love......
« Reply #6 on: June 24, 2010, 09:25:35 AM »
Sorry, I don't get this.
You have some sort of nostalgic feeling for the 283 because you once owned one, so you want to put a lower power obsolete engine in a Solstice that came with a much better motor, just so you can be close to a 283 whenever you drive it?
I think you need to get out more...... :nuts:
2007 BMW Z4M coupe
Recently sold:
Offline ChiliSky
« Reply #7 on: June 24, 2010, 10:21:45 AM »
ME THINKS HE JUST NEEDS MORE TOYS!!!!
« Reply #8 on: June 24, 2010, 12:50:29 PM »
I want a 2.4 Liter V8 like the Formula 1 cars :) :) :)
Offline JoshMcMadMac
« Reply #9 on: June 24, 2010, 02:09:33 PM »
The 4.6L is 281...although it is a Ford  :gaah:
Offline Dan Furr
« Reply #10 on: June 24, 2010, 06:04:39 PM »
The Vortec 4.8 might be the ticket...............even though it's a "truck engine".
The 5.3 sounds interesting ( or was it 5.6?)..........but isn't that a damn transverse mount ?
Offline SolNut
« Reply #11 on: June 24, 2010, 06:27:18 PM »
I have always had a warm place for a 5.0L (302).  327 with a 283 crank.  Early Z28's had them.   :thumbs:
Steve
 :drive:
« Reply #12 on: June 24, 2010, 08:25:38 PM »
I agree leave those wonderful engines to the old cars they belong to.
Back in the late 60 early 70's when I was doing serious drag racing my 1964 Vette with a stroke 327(383) was a consistent 11 second car.
With the 4:56 rear and a set of slicks it was lots of fun.
However that 64 Vette was a tank to drive because of the optimal drag racing setup.
Now I love the feeling of a well balance roadster you can put through some twisty roads, although not many of those here in South Florida.
« Reply #13 on: June 28, 2010, 10:08:54 AM »
can you take a old 283 block and put some new modern parts on/in it?
might be fun if you are into making a funky different car and spending the money on a custom solution.
Offline Brazen17
« Reply #14 on: June 28, 2010, 01:07:56 PM »
All the better to go with our "truck" transmission!
Offline jwvess00
« Reply #15 on: July 04, 2010, 01:31:57 PM »
Hi there!
A 283 is a historic engine, but isn't a good choice considering the alternatives unless you have to have a period-correct or numbers-matching engine (i.e. a restoration).  With it's sub-4" bore it is difficult to get decent heads.  The oiling system has been revised since then.  The only cranks available are small-journal cranks (though I suppose you could have a custom crank made and stuffed in a 307 to make a large-journal 283).  It's not easy to build big power from a 283 without going to radical headwork ($$$), radical cam timing (not easy to drive), or forced induction.
A "modern 283" as a 4.8L LS truck engine is the right way to go if you want a small displacement V8.
The 5.3 LS engine is a RWD engine used in trucks.  It's a good choice.  GM has a 5.7 crate that makes 327 horsepower, or pull one from a late-model truck.  The salvage truck engine makes a bit less power than the crate but that's easy to fix.
Offline scanner
« Reply #16 on: July 05, 2010, 08:18:47 PM »
I really enjoyed the 327 V8 from my 1969 Impala SS, the engine was close to square. They were very popular for HP improvements. I can recommend using anything like that on a new car like our Kappa's.  If you go V8 look at the crate engines from http://www.gmperformanceparts.com/
Clear Skys
Scanner
