Author Topic: Aluminum or Cast Iron  (Read 7760 times)
Offline Dan Furr
« on: June 27, 2010, 08:34:57 PM »
Which is better ? I know the aluminum is lighter...............
                        The truck 4.8 and 5.3's are cast iron .....why? :huh:
Re: Aluminum or Cast Iron
« Reply #1 on: June 27, 2010, 09:02:42 PM »
Not for much longer. With the mileage requirements going forward, all engines including the truck engines will be aluminum.
There was, in the past, the perception that the cast iron was better and the manufacturers continued to build cast iron engines on the same equipment that they have for years. Those plants and those processes are falling by the wayside as more technology and lighter materials are being incorporated into modern powertrains.
« Reply #2 on: June 27, 2010, 09:03:52 PM »
In general, cast iron blocks are more durable and better if you want to make crazy power. Aluminum isn't as tough, more susceptible to issues after overheating, etc. In a truck, where weight isn't the primary concern, cast iron is usually the preferred choice. Many serious race engines are also cast iron.
Offline Dan Furr
« Reply #3 on: June 27, 2010, 09:12:18 PM »
Thanks guys..............that's about what I figured..............but I needed to know..............
     I got away from car-fun for many years........... :(
     NOw my grandson has me loving cars again! :)
     But things have changed a lot , since the 60's. :huh:
     I had a family-car for 10 years in the eighties, put 120,000 miles on it,  and never raised the hood, not once! :lol:
  But my Solstice has cured that!........... :cool:
« Last Edit: June 27, 2010, 09:20:57 PM by Dan Furr »
Offline JimmyBaja
« Reply #4 on: June 27, 2010, 10:17:32 PM »
My '08 GMC truck I traded for the Sol had the 5.3L with a cast iron block but had aluminum heads - I guess maybe the best of both worlds.
« Reply #5 on: June 28, 2010, 10:56:33 AM »
Someone else has made more power than you with the engine you are looking at getting. If they can make more than the power you want with aluminum, then your questions are answered.
Offline Rogue
« Reply #6 on: June 28, 2010, 11:23:31 AM »
The cast iron blocks maintain their dimensional tolerances under stress much better than the aluminum. If you look at the serious high HP racers who use forced induction, CI is the runaway preferred material.
Go N.A.K.3.D..
« Reply #7 on: June 28, 2010, 03:17:00 PM »
If you are considering a V8 swap, I would think that aluminum is the only way to go. ADDING power to a V8 Kappa is nearly useless, as USING the power already available in a V8 would be enough of a challenge !!!!  The weight penalty for a cast iron small block Chevy would be awful.
« Reply #8 on: June 28, 2010, 03:21:08 PM »
Agreed. The only way you can justify a cast iron V8 in one of our cars is if you're making the car into an all-out dragster. (By all-out I'm implying a roll cage, tubbed rear wheels, racing transmission and gears, and so on.)
« Reply #9 on: December 03, 2010, 07:11:25 PM »
Aluminum for sure!!!  The hey to going fast is power to weight!!!
