JPM COACHWORKS ROCKS!!!
THANK YOU JOE AND ALEX!!!
I asked Joe and Alex at NASSM to get back to me about a new shifter and they REALLY hooked me up!
Here it is installed:
Here are the specs:
Stainless Steel STi Teardrop
Gunmetal-Blue Burnt FinishThis shiftknob is cut on a lathe from solid 303 Stainless Steel. After the rough cutting, each knob is hand-sanded, polished, and given a brushed finish by myself. This allows me to ensure a perfect finish on every knob. The steel is BY FAR the heaviest material used for any knob. This knob weighs a massive 600 grams! (Three times the weight of the aluminum sphere) This heavy weight provides the most solid shift feel available for your Subaru. The finish is a wonderful accent for your interior, and the smoothness and confidence from this knob will keep you smiling on every shift.
Any stainless steel knob comes with a brushed finish as shown below. An optional burnt finish can be performed for an additional cost. The burnt finish is done using a torch to heat the metal to the desired temperature. A variety of finishes can be done this way and are listed below.
GENERAL SPECIFICATIONS: * Solid Stainless Steel material gives AMAZING solid feel to shifting
* 2.0" diameter for comfortable size
* 680 grams weight for a good feel
* Brushed finish looks up-scale and holds up well to abuse
* Internal threading provides a quick screw-on installation
* Counterbored hole allows for reverse ring function
* Knob is drilled precisely to sit as low as possible on the STi shifter
Source: http://store.lathewerks.com/product_info.php?cPath=1_7_15&products_id=104&osCsid=cc9ce623cb88f9aa0683a665f073ae85The silliness follows
- - - - - - - - - - - - - - - - - - - - - - - - - - - - - -Will be delivered tomorrow.
I hear it's hot and big . . . just like I like my men.
and Joe said I'm going to like how it feels in my hand
Pictures to follow.
