Author Topic: LIPSTICK'S 800hp first LNF compound turbo/engine build!  (Read 359902 times)
« Reply #500 on: July 16, 2014, 05:34:33 PM »
Errr, I made a mistake, Insignia OPC with 2.8l V6 turbo - 325hp (LP9 Turbo) or Astra Opc 2l I4 - 280hp (LDK - A high-performance version of the LNF with 9.2:1 compression. This engine is also known as A20NFT and A20NHT by GM Powertrain Europe.)
« Reply #501 on: July 16, 2014, 06:29:34 PM »
I read his posts ;)
I was asking from which model of Opel and a direct difference between old ones and new ones on the same rpm and airflow/boost if he has that kind of data.
At 7500 rpm w/ fuel rail pressure at 16mpa and stock injectors , I get 9ms which is not good.
Now, at 7500 rpm w/ fuel rail pressure at 17.4mpa at Opel injectors, I get 3.4-3.8ms which very good :)
« Reply #502 on: July 17, 2014, 08:27:35 AM »
Thank you Antonio for sharing comparative cases ;) Appreciated
« Reply #503 on: July 25, 2014, 02:29:26 PM »
Bye K1, hello Carillo Pro H-beam rods!!!! We'll install these bad boys to make sure my block can handle 800hp of compound turbo power all day w/o even sweating!
Thanks to "project scarab" for providing the rods! :)
« Reply #504 on: July 26, 2014, 01:56:25 AM »
GTFOH
Are you really going to take apart everything at this point just to swap brands?
« Reply #505 on: July 26, 2014, 06:20:52 AM »
Well last week, I learned a small lesson not to skimp on small stuff during a build. Or I'll end up paying even more.
About two years ago, a stock chain tensioner was installed in this engine, since I completely forgot to have my Bates unit be used. So I just let it be..... And wasn't really worried about it.
After all the dyno/street runs, last week the stock unit failed and caused the timing to skip a tooth or two.
Btf believes that nothing internally was damaged. All rockers was still in place, which is a good sign.
He has to remove the whole compound manifold to get access to this issue, and replace it with my Bates tensioner.
Well I figured that, since josh (project scarab)basically just gave me his set of Carillo rods since he is going V8, and BTF is basically gonna hook me up by pulling the engine out to have access to the tensioner and also install the Carillo rods.....so why not take this opportunity to have a peace of mind?
By spending a couple of hundreds now to install the carillo rods, will prevent me from spending several thousands later on.
Once a rod breaks, it can damage lots of engine internals or can easily go make a hole in the block :)
I've seen photos of some members with a window on their blocks :)
K1 rods are very decent rods, but probably maxes out around 600hp. I will sell them to recover the couple of hundreds extra that I have to pay for pulling out my engine.
The carillo h beams will easily handle 1000hp. I'm not shooting for that number, but I rather have an over-kill bottom end with this compound build, for safety reasons.
« Reply #506 on: July 26, 2014, 06:51:00 AM »
I have carillo rods and wiseco pistons.  The carillo's are a more exact length for the LNF.  The K1s were really for the 2.4 but would work.
Now it makes sense.  I thought you just got the rods and without a reason, thats a decent amount of work to swap rods after having all the other work done.
« Reply #507 on: July 26, 2014, 07:02:04 AM »
Well, four yrs ago when I was "planning" my compound build. I didn't know that I'll go for 800hp.
I think I was only planning for 600hp.
That's why I got the k1 sponsorship.
And I looked at the carrillo rods..... A beams for $900 and H beams for $1200. Ouch!
So the choice of rods was a no brainer for me during that time!
But as the years passed by, I kept changing the numbers to 700 then to 800hp lol
Esp when I bought the gt4294r for my big turbo.
So I'm glad, that project scarab decided to go w/ v8 build and doesn't need his carrillo rods anymore.....and my tensioner broke. So kinda perfect opportunity for me to upgrade the rods! :)
« Reply #508 on: July 26, 2014, 12:38:13 PM »
K1 sponsorship doesn't mind you tossing their sponsored rods in the used parts pile?
« Reply #509 on: July 26, 2014, 12:55:35 PM »
It used to be managed by Mr. Molnar who sponsored me.
I did my advertisement for years and even in car shows.
I even sent them a magazine a year or so ago with my car and k1 mentioned on the article as well as listed as one of my sponsors.
So I already did part of my bargain.
On top of that..... K1 is owned by Carrillo which is under Dover group.
So I'm still representing their company :)
Plus he now owns his own rod company = molnar technologies
« Last Edit: July 26, 2014, 01:00:44 PM by SKY888 »
« Reply #510 on: July 31, 2014, 07:30:02 PM »
Well today, I just found out that project scarab's donation was a Bates billet chain tensioner
I will use this unit instead of my gen 2 chain tensioner with bates stiffer spring that fell apart
Hopefully this will hold better
« Reply #511 on: August 23, 2014, 01:07:18 PM »
I recently got this bullet-proof bolt for ecotec's timing chain guide.
Might as well install it, while fixing the chain tensioner issue.
« Reply #512 on: August 23, 2014, 01:21:14 PM »
Bates timing chain tensioner doesn't have the ratchet mechanism, stock unit has one.
also
Bates spring tensioner vs stock unit
« Reply #513 on: August 23, 2014, 02:22:55 PM »
Interesting. I think the werks one just added a spacer for the spring
That looks a little better as it can still give all the way if needed
« Reply #514 on: October 09, 2015, 12:44:21 PM »
ok, we're back on the project  :)
sorry, I had to prioritize my finances for the past year.  Having a baby girl makes a huge difference........and car hobby becomes the last of my priorities.
Anyways, when BTF was test driving the car on the street last year,  the timing chain skipped a tooth or two.    So that was a major blow.
We talked about getting a smaller turbo so we can spool faster.   Basically replacing my small turbo (gt2871r) with a gt2860r.    And we have to pull out the motor so he can inspect the internals if there were any damages due to the timing chain skipping.    While the motor was out, he also replaced the k1 rods with Carillo H-beam rods.
We dodged a bullet, and luckily no internal damage found!
Just found out today that My plan of replacing my small turbo (gt2871r) with a smaller turbo (gt2860r) to get a faster spool ....won't work after all.
I thought these gt28 based Garrett turbos share the same size turbine housing, but I guess not .
The gt2860r that I bought won't fit the Tial turbine housing used for my gt2871r.
We'll just stick with my original turbo then.
Motor is all back up. I'm glad nothing was destroyed.
BTF gasket matched the head with the Werks phenolic spacers
Stock Intake is being prepped to be matched as well
Stock intake manifold was gasket matched and ported clean
Secondary injectors already plugged in!
« Reply #515 on: October 09, 2015, 02:52:50 PM »
As a matter of interest ('cos I don't know), does porting/polishing the intake on a turbo car make much difference to power?
Offline roxer
« Reply #516 on: October 09, 2015, 03:11:55 PM »
According to Dr. Dave, when I asked that question last week, it depends on the hp you are trying to achieve. At 400-450, not really.
« Reply #517 on: October 09, 2015, 05:06:43 PM »
Sweet
Nice to see this project back in the works.
« Reply #518 on: October 11, 2015, 04:11:13 PM »
Sweet
thanks... but you know how build works....
« Reply #519 on: October 11, 2015, 04:11:25 PM »
Engine back to the car :)
« Reply #520 on: October 11, 2015, 04:56:25 PM »
Yes I do.  It's the simple stuff when it's not done properly that infuriates me.
Offline MARVIC 1
« Reply #521 on: October 12, 2015, 02:01:18 AM »
:huh: Elf, while your still in the infriation mode, what ever happened to your "Lucifer is Home" thread on this forum?
« Reply #522 on: October 12, 2015, 09:48:37 AM »
I removed it.  I may or may not post updates.
« Reply #523 on: October 12, 2015, 11:04:58 AM »
Is Dante's Inferno a new subdivision of Keebler?
« Reply #524 on: October 12, 2015, 08:28:00 PM »
Engine bay filling up
« Last Edit: October 12, 2015, 08:46:50 PM by SKY888 »
