Author Topic: The Correct Battery Removal and Installation Videos  (Read 52652 times)
« on: August 28, 2010, 10:29:39 PM »
I did this using Deedle's 2009 Solstice GXP Coupe, but the process is the same for all Kappas
It took 5 minutes to remove and 6 minutes to install with panel adjustments.
Hyperviper captured the video for me.
Removal video
http://vimeo.com/14513041
Installation Video
http://vimeo.com/14513086
Re: The Correct Battery Removal and Installation Videos
« Reply #1 on: August 28, 2010, 10:45:10 PM »
Awesome video DeepBlueGXP, and Joe you make it seem so easy.  I would recommend that this thread should be made a sticky thread on the forum.  Would be a great help to those needing to remove the battery.
Offline Excelsior
« Reply #2 on: August 29, 2010, 02:52:54 AM »
I would spend at least 10-15 minutes extra once it is off and clean the areas you normally never have access to.
Offline tallcraig
« Reply #3 on: August 29, 2010, 03:18:35 AM »
A great couple of videos! I got to see the disassembly done quickly but with a plan for a proper reassembly. Now I want one of those ooga horns! Thanks again ... Craig
« Reply #4 on: August 29, 2010, 05:10:11 AM »
one of the most usefull posts ever!!!
now, i can change battery on my own, clean those areas, maybe work on removing the fake Sky air outlets or just practice and practice to outbeat your outstanding 14.25 min record!  :thumbs:
Thanx a lot DBG!
Nice to also see the face behind the name!!
 :urock:
Offline Imaj
« Reply #5 on: August 29, 2010, 11:00:02 AM »
Great vid Deepblue. Hey, can you do another one showing how to jack the car up and get jack stands on all four corners?
« Reply #6 on: August 29, 2010, 03:42:06 PM »
Flyin' fingers!!!  Great vid - doesn't look so hard.  Thanks DBG and HyperViper!
« Reply #7 on: August 29, 2010, 06:01:30 PM »
Great video, thank you Joe, appreciated that you use milliliters tools  :yay:
  :agree:
Still unsure if I lift mine correctly.
Offline GaryH
« Reply #8 on: August 29, 2010, 06:23:11 PM »
I was able to remove the battery without removing the framework that you did.  Maybe because I don't have the ugga horn.  Also, if you remove the negative post first, you don't have to worry about shorting to ground when removing the positive post.
07 Sky
VIN  1745
Magnaflow Quad Tip exhaust
Tail of the Dragon 2008
Denver 2009
Ohio 2010
08 Sky DDM SC stage ll
Solo Mach exhaust
« Reply #9 on: August 30, 2010, 07:52:07 AM »
Thanks to you and the videographer for doing this.  As I said in another post a video maintenance forum would be great idea.
« Reply #10 on: September 02, 2010, 02:22:02 PM »
Very informative, thanks! :thumbs:
Offline G8TR
« Reply #11 on: September 02, 2010, 02:25:34 PM »
GM just removed and replaced mine, as it was still under warranty. Nice to get a good look at the process though. :thumbs:
« Reply #12 on: June 22, 2012, 09:28:28 AM »
Is this still the best way to change the battery or is it better to just peel back the wheelhouse liner?
Offline EarthNTX
« Reply #13 on: August 02, 2012, 01:03:41 PM »
Bumping this up for me. I hope you don't mind. :(
Ride it like you mean it.
« Reply #14 on: August 02, 2012, 04:57:14 PM »
Followed the steps in the video when I changed mine a while ago. Piece o' cake!
Offline EarthNTX
« Reply #15 on: August 02, 2012, 05:03:36 PM »
I just posted on my thread about this...
I'M DOING IT
I'M DOING IT
 :tool:
Offline Gabes Redline
« Reply #16 on: August 04, 2012, 12:51:26 PM »
THANK YOU DEEPBLUE!!
You've shown us kappa owners the battery removal doesnt have to be a huge PITA!!  You the man!!
Live life 'cause life happens!
Offline EarthNTX
« Reply #17 on: August 04, 2012, 06:21:21 PM »
It's not a pita..if I can do it, YOU can..trust me.  :D
« Reply #18 on: January 09, 2013, 07:59:11 PM »
Many thanks!  Saved lots out expletives I'm sure!
Sent from my SCH-I535 using Tapatalk 2
« Reply #19 on: January 09, 2013, 08:55:27 PM »
I don't know if the fender liner method or removing the fender panel method is "better".  But the fender liner method is pretty quick comparatively.  I didn't do any damage to the plastic fender liner doing it that way, and I did it in pretty cold weather (around freezing temp).  With all the horror stories, I was surprised at how quick it was (40-45 min ish) and I wasn't exactly rushing, cleaned out the area, sprayed down some rust proofing and cleaned up the terminals in that time too.
« Reply #20 on: January 09, 2013, 11:22:03 PM »
I was not as quick as Joe but it really was easy.  I did it in about a half hour (including pauses to watch Joe in the video).
Offline EarthNTX
« Reply #21 on: January 09, 2013, 11:54:42 PM »
I changed mine through the fender. It wasn't hard at all and didn't take much time and saved me a ton of moola! :)
« Reply #22 on: January 10, 2013, 10:11:17 AM »
Ditto, used video.  Still took way longer than it should but vid was way helpful.
« Reply #23 on: January 10, 2013, 01:00:29 PM »
I saw this post after swapping mine.
I followed the steps in the Video.
I had briefly looked at going through the wheel well, but I just didn't see there being enough space with the tire still mounted.
FYI- on cars with Vertical doors.  The Support for the Hinge makes it a slightly tighter fit.
« Reply #24 on: January 10, 2013, 02:14:21 PM »
You want to see a tight fit wait till Steve/Spicy's old car needs a new battery.
