Author Topic: LatinVenom Front Chassis Brace project  (Read 111366 times)
Re: LatinVenom Front Chassis Brace project
« Reply #75 on: October 18, 2010, 09:37:01 PM »
Posted from another thread about the relocating the power steering
Not needed with this brace!
But, this brace is not SCCA legal either until one is at the Prepared level, which is basically a full race car.
« Reply #76 on: October 18, 2010, 09:38:32 PM »
Bob, what level are you racing at that you can use a brace?
« Reply #77 on: October 18, 2010, 09:42:07 PM »
The SCCA rules for our car need to be modified. WE DO NOT have a Strut Tower in our car.
All 3 Braces attach to the same place and that is the Chassis rail.
Offline pharmboy
« Reply #78 on: October 18, 2010, 10:05:57 PM »
If there is ever a second run , add me to list
pharmboy
« Reply #79 on: October 18, 2010, 10:46:34 PM »
Shock tower or not, the SCCA says braces like the DDM design are permissible, and frame-mounted ones aren't. Sucks, yes, but though we constantly gripe about the SCCA rules we all tend to agree they have to draw the line somewhere. Honestly I'd be more interested in them allowing a backbone brace, with a convertible we need all the center stiffness we can get.
« Reply #80 on: October 18, 2010, 11:33:08 PM »
SCCA Solo Street Prepared.
« Reply #81 on: October 18, 2010, 11:44:12 PM »
For the purposes of these three components, the SCCA has said that the DDM piece attaches as would a true strut tower brace, so it is excepted. (I will approach them again for further clarification.) Copied below if the section that addresses this, and attachments to the frame rails is not legal until Prepared class.
15.2.C. Transverse members known as strut bars and suspension braces may be added, removed, modified, or substituted. They must be bolted
on. Strut bars must be attached to the strut/shock tower. Lower suspension braces much be attached to the lower suspension pickup
point locations on the chassis within 2 inches in any direction of the actual suspension attachment to the chassis. Except for standard
parts, no connections to other components are permitted. Additional holes may be drilled for mounting bolts. Interior trim panels may be
modified to allow installation of strut bars. Holes or slots may be no larger than necessary and may serve no other purpose. This does
not permit any modifications to the frame or unibody beyond the allowed mounting holes.
I would guess that if the piece is attached within the 2" allowance, it would be legal in Street Prepared. Somebody can ask the SCCA about that.
« Reply #82 on: October 18, 2010, 11:54:24 PM »
SOB, if it is allowed in a Prepared class is it a given for a Modified class? Just curious for us guys with base 2.4 and a power adder like supercharger or turbo who ran SSM last season.
« Reply #83 on: October 19, 2010, 12:10:09 AM »
As you stated, forced induction IS legal for the 2.4 in SSM. Prepared is above SSM and Street Prepared. SSM allowances for these braces are the same as SP, and the Backbone is NOT legal. In Prepared and Mod damn near everything is legal. A Backbone puts ANY Kappa in Prepared. Even MORE fun to work through is that update/backdate allows the GXP Z0K rear chassis rail and the Street Prepared rules allow the ReBar or ProBeam. Different allowances !!!! Fun, huh?
Offline Excelsior
« Reply #84 on: October 19, 2010, 12:16:30 PM »
Werks steering brace
DDM Backbone
DDM Pro Beam
Those put me into the FP class and have raised many a question if it correct or not.  I don't think the backbone puts you in FP, but the Probeam does instead.  But I am not 100% certain on that either.
« Reply #85 on: October 19, 2010, 05:26:21 PM »
DDM Backbone
DDM Pro Beam
Probeam is 100% legal for Street Prepared. A DDM tower thingie is SP legal as well. Other front chassis braces and the DDM BackBone put ANY Kappa into Prepared.
« Reply #86 on: October 19, 2010, 07:11:34 PM »
pharmboy
There will be as many runs as the members want to do.
I will add you to the list.
By the way the next run maybe once we hit 5 or 10.
« Reply #87 on: October 19, 2010, 07:21:21 PM »
Here is the problem that needs to be address with the SCCA.
This statement is Incorrect for our car!!!!
WE do NOT have a Strut/Shock Tower!!!
The shock is attached to the Frame and my brace or Werks is attached to the same frame rail as the shock.
So this statement by their rules would apply to the Chassis Brace.
« Last Edit: October 19, 2010, 07:30:08 PM by LatinVenom »
« Reply #88 on: October 19, 2010, 09:00:13 PM »
New list for next batch of front Brace.
1. Sly Bob
2.
3. DirtyMike
4. pharmboy
« Last Edit: October 27, 2010, 07:02:30 PM by LatinVenom »
« Reply #89 on: October 19, 2010, 09:22:37 PM »
This statement is Incorrect for our car!!!!WE do NOT have a Strut/Shock Tower!!!
Then ask the SCCA to approve it. There is a procedure.
« Reply #90 on: October 21, 2010, 08:56:21 AM »
After much careful thought, I've decided I'd like to relinquish my place on the "First Ten" list to another eager waitlister.
As I've said in other posts, I already have the DDM engine brace and I cannot see that the addition of this would bring any further detectable improvements.  I just don't have the time to mess with trying it out and then probably trying to sell it on afterward (sorry Critter).
So many apologies LV.  If, of course, all the wait-listers back out, I will stand by my original request and buy it.  Hopefully that won't be necessary though.  Good luck - it's a nice idea and if I'd seen this one first, things could well be different!
« Last Edit: October 21, 2010, 10:14:44 AM by TomatoSoup »
« Reply #91 on: October 21, 2010, 09:36:17 AM »
TS, I'm getting some so if you want to do a comparison, you can use mine before I put it on.
« Reply #92 on: October 21, 2010, 10:13:38 AM »
Hmmm, we could do that.  Do I hear a Winter mini-mod-meet... ? :)
« Reply #93 on: October 21, 2010, 01:22:45 PM »
Here is a response from the SCCA offices about "braces".
As for your brace I assume it is just a brace that goes from one tower to the other tower. Even though you don’t have struts on your suspension the rule allows bars for all cars. Here is the rule for that:
15.2.C - Transverse members known as strut bars and suspension braces may be added, removed, modified, or substituted. They must be bolted on. Strut bars must be attached to the strut/shock tower. Lower suspension braces much be attached to the lower suspension pickup point locations on the chassis within 2 inches in any direction of the actual suspension attachment to the chassis. Except for standard parts, no connections to other components are permitted. Additional holes may be drilled for mounting bolts. Interior trim panels may be modified to allow installation of strut bars. Holes or slots may be no larger than necessary and may serve no other purpose. This does not permit any modifications to the frame or unibody beyond the allowed mounting holes.
Basically as long as the bar isn’t permanently mounted (e.g. welded) and isn’t triangulated then it should be compliant. If you would like you can take a picture of it so I can take a look at it to see for sure but just like your other question the national office and/or SEB can’t provide any paperwork to prevent a protest.
This pertains to Street Prepared, and therefore Super Street Mod as well.
« Reply #94 on: October 21, 2010, 03:01:20 PM »
THX Bob!
« Reply #95 on: October 21, 2010, 07:03:23 PM »
Well then since my Kappa Front Chassis Brace is bolt on to existing OEM bolts on the chassis, then is allowed.
Am I reading this correctly?.
Thanks
PS: Thank you Bob. You can use the pictures I posted at the beginning of the thread.
« Reply #96 on: October 21, 2010, 07:27:01 PM »
Thanks
LV, the key issue is the 2" measurement.
Offline Yogi
« Reply #97 on: October 21, 2010, 07:39:30 PM »
So is it more than 2"?
2008 Saturn Sky Red Line
2.0 Turbo LNF
5 Speed Manual
Snowflake Wheels
Monsoon Sound System
Leather Seats
« Reply #98 on: October 21, 2010, 07:47:18 PM »
Once is bolted down is less than 2" from the side of the Tower.
« Reply #99 on: October 21, 2010, 08:06:43 PM »
I just measure it, the bolt on my car is exactly two inches to the tower edge
