Author Topic: Kagem's GT dynos, Trifecta tune  (Read 21686 times)
Offline Kagem
Re: Kagem's GT dynos, Trifecta tune
« Reply #50 on: October 07, 2010, 03:30:30 PM »
Yes ok, i got it now! Yes he is right, and furthermore i think in 4th and 5th gear the car has now less power.... The question is why? The opposite should have happened....
« Reply #51 on: October 07, 2010, 06:04:36 PM »
There you go, before and after turbo-back exhaust (including tune update), same very conservative dyno on different days.
« Last Edit: October 07, 2010, 06:26:46 PM by DeepBlueGXP »
Offline Kagem
« Reply #52 on: October 08, 2010, 01:37:04 AM »
Thanks Kelu, after sending an e-mail to Vince about an updated tune, he answered that we do not change anything for a high flow cat. I also had a check engine light yesterday and the code is p0497. The code means ''Evaporative Emission System Low Purge Flow'', i'll have it checked at the dealership and see if that's the reason the car does not perform as it should. Any opinions are welcomed....
« Reply #53 on: October 08, 2010, 03:05:30 AM »
kagem, if i am not mistaken, p0497 has something to do with purge evap valve.
Offline Kagem
« Reply #54 on: February 14, 2011, 12:14:25 PM »
On Saturday some friends and I went for a dyno day on the same dynojet i went some months ago. Since my last dyno i have added to the car a custom ic with bigger pipes around 2,7 inch and a custom exhaust along with solo's high flow cat. The results were 309whp and 378lb ft of torque....
« Reply #55 on: February 14, 2011, 12:55:53 PM »
Nice numbers, I would love to race you malaka!
Last plot is boost in Bar, right?
« Reply #56 on: February 14, 2011, 01:04:04 PM »
lol Kelu!!
nice numbers Kagem, but without a stock dyno, it is just an indication. i believe the best that came out of this dyno is the comparison with the other GT dynos on that day. this way you can compare various tunes and bolt ons and their affect in performance
about boost, if it comes through OBD, it must be faulty due to it's limited up to 1.7something bar...
i believe an analogue boost gauge would show better results
Offline Kagem
« Reply #57 on: February 15, 2011, 03:04:22 AM »
Kelu we do not have any similarities, your car is now at another stage, no comparison pall.
George the boost is taken from the intake, they take off the cable that goes into the ic's pipe that's going into the motor, and they connect it to another cable with a T that leads to their computer, that way they see what the true boost is. The other gt dynos show similar whp with similar mods as mine but with different tunes....
« Reply #58 on: February 15, 2011, 03:26:04 AM »
I'm same with you if I don't use nitrous ;)
Offline Kagem
« Reply #59 on: February 15, 2011, 05:55:22 AM »
And if you don't put borg warner, and if if if.... ;)
The last plot is boost in Bar, you're right!
« Reply #60 on: February 15, 2011, 06:06:01 AM »
I was referring to race you with actual mods, not with turbo upgrade ;) I like even nice races.
Oh, now I have BW turbo too  :rofl:
