Be very careful the powder coat on mine chipped pretty easily when I first got it, but has been fine since. The plastic screws they give you to hold the plates down are worthless. Before you drill holes in the flaps figure out your own way to hold them down. Mine has been on over a year now.
After you install it there is an order to things when you put the top up and down, undo the latch then hit the key fob to release the trunk, putting back up push the trunk down below the tips of the pins in the wings, then do the latch and and close the trunk. It will make more sense when you install it.
