Author Topic: RMR style bar  (Read 3440 times)
Offline CPB
RMR style bar
« on: January 15, 2009, 08:31:44 PM »
talked to Eric and ordered black style bar this morning. Now just have to wait for spring and some warm weather to get car out and do install. Any one that has one have any tips for easier install?
2008 Mysterious GXP
third brake light decal SOLSTICE
air bag light cover GXP with arrow head
flash to pass garage door opener
RMR style bar black
mesh back up light covers
fiberglass eye lids painted to match body
Offline Gunnys GXP
  • SEMPER FI
Re: RMR style bar
« Reply #1 on: January 15, 2009, 10:27:30 PM »
Two people...There are some adjustments and placement of the two lower mounting plates that can be a real bear if you try it on your own.  It's doable and I managed to accomplish it on my own but another hand would have been a lot easier and faster.
Also a step up/multi size bit can come in handy and make quicker and cleaner holes.
The hole saw bit must also be of metel cutting quality or you'll have a horrible time getting through the partial edge that is hidden under the plastic where you'll be drilling the pass through for the top bolts that go to the seat belt mount.
Just a note to keep in mind also.  The lower plates mount to bolts that also affect the tops alignment so it may get a bit off line when you retighten them.  I'd say you'll know pretty quick if it is.  The passenger side window started to catch the edge of the top when I closed the door but a quick readustment of the blates took care of it.
If I remember anything else I'll get back to ya.  It's not as bad as it sounds so don't let this scare ya.
07 Deep GXP auto.  A lot of cosmetic upgrades but not enough performace mods. YET.
Re: RMR style bar
« Reply #2 on: January 16, 2009, 11:01:33 AM »
Lil goat and I installed one on his car.  Like Gunny said, the hole you have to drill above the seat belt bolt is through the plastic but beneath it is a about 3/8 edge of metal showing and a metal cutting hole saw blade is the only way to go.  Don't use a jig saw as the materials are not held together good and they will more likely crack.
Re: RMR style bar
« Reply #3 on: January 16, 2009, 06:27:58 PM »
Be very careful the powder coat on mine chipped pretty easily when I first got it, but has been fine since. The plastic screws they give you to hold the plates down are worthless. Before you drill holes in the flaps figure out your own way to hold them down. Mine has been on over a year now.
After you install it there is an order to things when you put the top up and down, undo the latch then hit the key fob to release the trunk, putting back up push the trunk down below the tips of the pins in the wings, then do the latch and and close the trunk. It will make more sense when you install it.
« Last Edit: January 16, 2009, 09:30:21 PM by lil goat »
Offline Gunnys GXP
  • SEMPER FI
Re: RMR style bar
« Reply #4 on: January 16, 2009, 09:08:34 PM »
lil goat forgot to mention that before you raise the top up to make sure to remember to remove the "flaps" or the top frame can damage them.
I use something like this to hold mine in.  Mine have a fold down lever vice the twist shown here.  Painted the tops to color match the plastics.  Over a year on mine also.
« Last Edit: January 16, 2009, 09:10:35 PM by Gunnys GXP »
