Author Topic: Gas Smell Inside The Car  (Read 7541 times)
« on: December 13, 2010, 05:11:42 PM »
Here we go yet another problem thank goodness the first one is fixed. the issue Im having now is that it smells like gas in the cabin when I turn the heat on. Im leaning towards an exhaust leak but I cant hear one, so any more help is much appreciated.
Re: Gas Smell Inside The Car
« Reply #1 on: December 13, 2010, 05:18:35 PM »
High flow cat bolts are loose.  Pull off your turbo heat shield and see if there is any soot on the underside.
« Reply #2 on: December 13, 2010, 05:23:51 PM »
Pulled the shield off and no soot bolts are tight maybe the other end is loose. I havent check that yet.
« Reply #3 on: December 13, 2010, 05:27:26 PM »
Do you have the DDM Fuel Filter installed?
« Reply #4 on: December 13, 2010, 05:28:43 PM »
yes I do
« Reply #5 on: December 13, 2010, 05:29:56 PM »
Check to make sure the "B" nuts are tight going to the filter bowl.  I had a loose one on mine and it leaked, gave the gas smell.
« Reply #6 on: December 13, 2010, 05:32:19 PM »
which nuts am I looking for
« Reply #7 on: December 13, 2010, 05:33:50 PM »
In the center of the addon is a larger diameter tube, there are nuts about line/tube nuts that connect the fuel line to it.  About 11/16 wrench or some where close to that.
« Reply #8 on: December 13, 2010, 05:36:05 PM »
The nuts are pictured below.
« Reply #9 on: December 13, 2010, 05:43:14 PM »
lol I turned it the wrong way at first and gas came out lol. So i revered it not sure if that made a difference since now it def smells like gas lol..
« Reply #10 on: December 14, 2010, 11:15:31 AM »
HA HA HA!!! That is classic... Sorry, but I needed a little humor today. Hope this smell clarifies itself soon.
« Reply #11 on: December 14, 2010, 11:51:01 AM »
Hahahah, can't stop laughing :lol:
Offline Craig
« Reply #12 on: December 14, 2010, 02:02:25 PM »
When my car was new, the gas fumes were so bad it burned my eyes.
There was no exhaust leak.
No fuel spilling anywhere.
My tailpipe was rediculously sooty.
Seemed to clear up on it's own.
« Reply #13 on: December 16, 2010, 12:01:59 AM »
so now gas is leaking out of the ddm fuel filter that i tighted
Offline MARVIC 1
« Reply #14 on: December 16, 2010, 12:41:14 AM »
I also had a problem with the DDM Works Fuel Filter with gas leaking from one of the connectors...
I just pushed in at one end a little harder (Plastic connector side of the line) and seemed to stop, but I keep my eyes and nose on it from time to time...  :f:
« Reply #15 on: December 16, 2010, 06:58:58 AM »
The lines are B nut fittings and can handle quite a bit of torque.  Grab both ends of the filter can and tighten at the same time.   Don't be scared :poke:
« Reply #16 on: December 16, 2010, 02:35:48 PM »
FYI if you try this remember to turn the wrenches in opposite directions. :poke:
« Reply #17 on: December 16, 2010, 03:13:40 PM »
lmao, I tighted the hell out of them and so far no more leaking.., waiting for the gas smell to go away so I can see if it still smells inside.
Offline G8TR
« Reply #18 on: December 16, 2010, 04:13:54 PM »
stick a match down there and see if you can tell. :lol:
« Reply #19 on: December 16, 2010, 09:25:25 PM »
Lol! ^^^^
« Reply #20 on: December 18, 2010, 05:05:07 AM »
Hmmmm
Hope you found your nuts and got them screwed on tight.
« Reply #21 on: December 18, 2010, 05:50:08 AM »
can you give me a hand with my nuts..
« Reply #22 on: December 18, 2010, 11:51:22 PM »
 Just Remember ( LEFTY LOOSEY and RIGHTY TIGHTY )   All Gearhead should know that . Unless you are working with Welding Gases Opposite Thread. Oxygen has a Pin index . Now don't go Nuts with your Nuts
« Reply #23 on: December 21, 2010, 03:47:37 AM »
   BFF: --------> ( Best Friend Farted )  in car
