Author Topic: Boxster brembo calipers  (Read 39487 times)
Offline Gregory
Re: Boxster brembo calipers
« Reply #25 on: May 04, 2011, 12:17:33 PM »
This calipers are really thick.
Forget to fit this on stock rims, 10-15mm spacer needed.
The inlet hose thread banjo to the caliper is M10x1
I think that an 8mm spacer is enough because I use 4 piston brembo cals in my stock rims (328x28) with that spacers. They are taken from a Ferrari 360 modenas 99+
Offline Kuprito
« Reply #26 on: May 06, 2011, 07:00:20 PM »
Brackets will be ready in a few days
Solo + Magnaflow 3" exhaust
OZ Ultraleggera 19"
Rotora 4p front
Brembo 4p rear
LV Brace
Custom Backbone (1/2")
Offline Kuprito
« Reply #27 on: May 06, 2011, 07:04:27 PM »
Is not a matter of pistons or disc width, is just the caliper size. Boxsters are very very wide for the width of disc they are made for (25mm). In the pic I said 10-15mm needed, you are seeing a -17 Offset from stock wheel (17mm outer) a few mms of the caliper.
Rotoras 4 pot are biting 30mm discs, and are a lot farer fromt the spokes.
OZ Ultraleggera 19"
Rotora 4p front
Brembo 4p rear
LV Brace
Offline Kuprito
« Reply #28 on: May 06, 2011, 07:13:00 PM »
OZ Ultraleggera 19"
Rotora 4p front
Brembo 4p rear
LV Brace
Offline Kuprito
« Reply #29 on: May 08, 2011, 07:45:41 AM »
Look at the rear end, yes, it is a full front brake system.
I am happy with the current set up but..
1.- There are not good pads for the stock calipers (I love ferodos ds2500)
2.- Stock calipers weight a ton
3.- This brembos fit perfect on stock rotors
4.- I will improve the bite
I will tell you how the new calipers feel on braking.
« Last Edit: May 08, 2011, 08:00:54 AM by Kuprito »
OZ Ultraleggera 19"
Rotora 4p front
Brembo 4p rear
LV Brace
Offline Gregory
« Reply #30 on: May 08, 2011, 09:01:30 AM »
What about hand brake?
« Reply #31 on: May 08, 2011, 11:46:10 PM »
This is probably too late, but if you get the upright/hub carrier off again, can you see if you can fit a C5 or C6 hub on ?
Or just the parking backing plate from the C5 Corvette? Corvette hub bolts measure 4" on center between bolts if someone has a Kappa hub off or in the air.
Offline Kuprito
« Reply #32 on: May 09, 2011, 04:55:50 AM »
I have 1 wheel hub + knuckle for spare. What do you want me to measure?
OZ Ultraleggera 19"
Rotora 4p front
Brembo 4p rear
LV Brace
Offline Kuprito
« Reply #33 on: June 17, 2011, 07:44:25 AM »
Done!
OZ Ultraleggera 19"
Rotora 4p front
Brembo 4p rear
LV Brace
Offline scotthofferphotography
    • FriendlyCarPeople
« Reply #34 on: June 17, 2011, 08:04:42 AM »
looks good.
« Reply #35 on: June 17, 2011, 08:27:22 AM »
nice mod Kuprito!!
let us know of how braking feels and is now, that you have a much much better rear brake set up.
maybe i missed it, but what about handbreak?
brembo on burberry, now that's an expensive combination :)
« Reply #36 on: June 17, 2011, 09:43:47 AM »
Looks good, how does it stop, and yes what about the handbrake?
« Reply #37 on: June 17, 2011, 11:37:56 AM »
I just realized you were in Spain.  Getting a C5/C6 hub could be a major problem there :)
Could you place a ruler in the back view of the hub ?  I want to see if the PCD is the same as C5/C6 hub.
Another picture would be a ruler with the hub positioned horizontally, sitting on the studs.  I want to see if some dimensions are equal.
Lastly, if you got the rear hub, see if you can count the spline/teeth.
Thanks !
Offline Kuprito
« Reply #38 on: June 17, 2011, 04:18:13 PM »
I'll take you the pics you want this weekend.
OZ Ultraleggera 19"
Rotora 4p front
Brembo 4p rear
LV Brace
Offline rlhammon
« Reply #39 on: March 20, 2012, 04:24:58 PM »
Did you ever get pictures?  I know I'm late to the thread.
Also.. do you have dimensions for the mounting bracket you needed to make to mount the Boxster calipers on the stock upright?  I'm interested in looking into this further based upon reading this thread.
Thanks.
Offline Racer_X
« Reply #40 on: March 20, 2012, 07:32:01 PM »
Hey RL...
Kuprito has been MIA for quite sometime...
I'm doing this upgrade, so as soon as I have it bolted up, I'll post all the photos and dimensions!
2008 Sly GXP (Z0K) Custom Tune, Dejon Precision 5557B Kit, Wiseco/ARP/K1 Built Bottom End, AEM Meth Injection, SPEC Stage III Clutch, DDMworks Backbone, Kappasphere ReBar, DDM Crossbrace, Custom Front Splitter, HKS SSQV, NORMS ZR-1 fenders, Cobalt SS BBK.
414rwhp/ 436tq @ 26.5psi
Offline rlhammon
« Reply #41 on: March 20, 2012, 07:57:56 PM »
Hey RL...
Would be greatly appreciated.
« Reply #42 on: March 21, 2012, 11:25:55 AM »
Those rotors look sooooooooo tiny
« Reply #43 on: March 21, 2012, 01:13:51 PM »
And Elff knows tiny.
Offline rlhammon
« Reply #44 on: June 13, 2012, 04:28:02 PM »
Hey RL...
Maybe I missed this thread you speak of?  :)
Offline Racer_X
« Reply #45 on: June 14, 2012, 01:09:57 AM »
Bro, I have the adapters and the Calipers... but I got a killer deal on Cobalt SS calipers! Check ur PM.
Offline 40rtyp
« Reply #46 on: June 19, 2012, 06:02:45 AM »
Ok, so now I'm confused. Are you the same guy that figured out that the Cobalt's stock brembo could be retro fitted into our cars? Where do you get the brackets? Are they custom. The reason I'm really wanting to find out is cause I track my car a lot and I'm looking into upgrading the brake up front. Let me know. Thanks
« Reply #47 on: June 19, 2012, 06:36:30 AM »
Crate engine depot sells a full kit for the brembos it include a bracket to relocate the caliper
Offline 40rtyp
« Reply #48 on: June 19, 2012, 07:24:16 AM »
interesting, I'll check it out!
