Author Topic: Boxster brembo calipers  (Read 39487 times)
Offline |V3nom|
Re: Boxster brembo calipers
« Reply #50 on: June 20, 2012, 08:18:51 PM »
are the brembos a 4 piston?
is it just for the front or is there a rear brembo kit too?
another thought, i see that people feel there is too much front bias in the kappa.  what about fitting a front brake setup to the rear to even out the bias.  would that be too much rear bias then?  other than not having a parking brake, would there be any other problems from doing that?
08 Bluestone RL Manual
Wester's Race Tune
Solo Street Race with Two Magnaflow 5" Round Mufflers
8K HIDs Lows and Fogs
Lil Chromies
JPM Piston Shifter and Boot Cover
JPM Seat Belt Holders
« Reply #51 on: June 20, 2012, 08:57:08 PM »
There are 4 piston fronts only.  No rear kit that I know of for brembos.
TCE offers rear kits
Offline 40rtyp
« Reply #52 on: June 21, 2012, 01:30:46 AM »
I'm interested,
 Racer X, is there a chance I can come visit you to see this? I live off the 15(Rancho Benardo) so I'm not to far from you. Let me know.
« Reply #53 on: June 21, 2012, 11:51:50 AM »
You guys do know that a bigger brake doesn't make a Kappa stop shorter, right ?  A bigger brake provides larger thermal capacity which means braking performance doesn't fade or less likely to fade during repetitive heavy use.  That being said, a Brembo caliper does make a statement.
Bias problem is easier to tackle; install more aggressive brake pads on the less-biased end.
« Reply #54 on: June 21, 2012, 01:12:41 PM »
It all depends on how you define it.  After the stock system has faded, but the bigger brake hasn't, the kappa with the bigger brake will the stop shorter.
I have my kit due to hitting brake fade.  I now have better brake feel as well.
Offline 40rtyp
« Reply #55 on: June 21, 2012, 04:20:41 PM »
I understand this thank you, I already have tackled what you mentioned on the bias side of the house with  Carbotech's XP12 in the back and Hawk HPS in the front. Less brake fade is a win for me so this kit is a plus.
« Reply #56 on: June 21, 2012, 04:34:15 PM »
Would love to see some larger REAR brakes WITH e-brakes.
Offline Racer_X
« Reply #58 on: June 21, 2012, 08:07:30 PM »
I'm interested,
I'm in Norcal (Elk Grove), now but when I come through my hometown I'll hit you up.
Although I switched out for the larger diameter brake and rotor from the cobalt, the porsche is a cheap and easy alternative-
2008 Sly GXP (Z0K) Custom Tune, Dejon Precision 5557B Kit, Wiseco/ARP/K1 Built Bottom End, AEM Meth Injection, SPEC Stage III Clutch, DDMworks Backbone, Kappasphere ReBar, DDM Crossbrace, Custom Front Splitter, HKS SSQV, NORMS ZR-1 fenders, Cobalt SS BBK.
414rwhp/ 436tq @ 26.5psi
Offline |V3nom|
« Reply #59 on: June 25, 2012, 03:53:09 PM »
http://www.tceperformanceproducts.com/solstice/sky/kits-2/
still a single piston like stock which is what were trying to get away from right?
Wester's Race Tune
Lil Chromies
« Reply #60 on: June 25, 2012, 04:10:43 PM »
This is what I responded to
and they are larger and are a combo E-Brake
Offline |V3nom|
« Reply #61 on: June 25, 2012, 04:32:57 PM »
yeah i know, i was pointing out the fact that theyre still a single piston and not much better than stock, atleast not for the money you pay.  most people dont realize that.
Wester's Race Tune
Lil Chromies
Offline 40rtyp
« Reply #62 on: June 25, 2012, 05:50:05 PM »
Yea, isn't the cobalt rotors a 12.1 compared to our. 11.6?
Offline shabby
« Reply #63 on: June 25, 2012, 05:54:52 PM »
Think the cobalt rotors are 12.6"
