Author Topic: Boxster brembo calipers  (Read 39487 times)
Offline Kuprito
« on: March 18, 2011, 12:01:29 AM »
I borrowed a Porsche Boxster front caliper and I am testing with it.
Advantages of this caliper:
a) Weight, it only weights 2.6kg
b) Monoblock design (no bolted 2 parts caliper)
c) Cheap (2nd hand)
d) Full range of racing pads
e) Easy to fit
This caliper is originally fitted to bite a 299x24 disc brake, almost the same as our stock front rotors. I removed a pad from the Porsche caliper and put on the disc braking surface, the pad fits perfect, no more no less, so good news.
The set up I am looking for is:
Rotora 330x30 4p front (done)
Stock 297x25 disc + Porsche 4p rear
As you can see, the pad area is very similar to the Rotora pads. The whole caliper is almost same size to the Rotora 4p
I had a set of brake lines that fitted the calipers... I would need and adaptor on the other side of the brake hose.
Weight (In kg)
This caliper fits pretty well our discs, you only need to make your own brackets + brake lines. So here you have a cheap and good mod.
Solo + Magnaflow 3" exhaust
OZ Ultraleggera 19"
Rotora 4p front
Brembo 4p rear
LV Brace
Custom Backbone (1/2")
Re: Boxster brembo calipers
« Reply #1 on: March 18, 2011, 01:32:06 AM »
hmmmm.... interesting mod.  Any issues with our lines / resevoir being able to provide enough "pushing" power to operate these properly?
What year Boxster?
Offline Kuprito
« Reply #2 on: March 18, 2011, 03:30:29 AM »
Part nrs.:
986.351.421.03 LEFT
986.351.422.03 RIGHT
Fitted on front Boxsters (not "S" versions) from '99 til today.
Didn't have probs with the swap from stock to rotoras in front so the same now.
I'm posting more pics later.
OZ Ultraleggera 19"
Rotora 4p front
Brembo 4p rear
LV Brace
« Reply #3 on: March 18, 2011, 03:58:14 AM »
Carlos: NICE FIND!
Please to mention these are for REAR!!!
Offline Kuprito
« Reply #4 on: March 18, 2011, 04:08:27 AM »
Carlos: NICE FIND!
Rear for me! Not for you with stock front brakes!
OZ Ultraleggera 19"
Rotora 4p front
Brembo 4p rear
LV Brace
Offline Kuprito
« Reply #5 on: March 18, 2011, 06:51:09 AM »
This calipers are really thick.
Forget to fit this on stock rims, 10-15mm spacer needed.
The inlet hose thread banjo to the caliper is M10x1
OZ Ultraleggera 19"
Rotora 4p front
Brembo 4p rear
LV Brace
Offline Kuprito
« Reply #6 on: March 18, 2011, 07:17:36 AM »
That's a FRONT knuckle and a REAR brake disc. Not the final set up I want but it's good to get an idea (front discs are on the car right now and I can't remove anything from the car cause it's daily driven).
Once I see everything it's ok, I'll buy a new front brake disc set and I'll make the brackets.
OZ Ultraleggera 19"
Rotora 4p front
Brembo 4p rear
LV Brace
« Reply #7 on: March 18, 2011, 12:26:39 PM »
Cool!  I will have to see what fits and how much these parts are here.  So no good with stock wheels?
Offline Kuprito
« Reply #8 on: March 18, 2011, 01:12:38 PM »
My car has 8" ET38 Ultraleggeras fitted and there is enough clearance (no spacers). You will need 10-15mm spacers with the stock rims, that means longer wheel studs but I think it worths it.
The most important fact is that the pad covers the whole disc braking surface and there is enough space to add a bracket in the knuckle.
I'll make the brackets in steel, but not right now, this will have to wait.
OZ Ultraleggera 19"
Rotora 4p front
Brembo 4p rear
LV Brace
« Reply #9 on: March 18, 2011, 03:20:56 PM »
good job Carlos!
thanks for sharing!
« Reply #10 on: March 18, 2011, 04:19:43 PM »
Nice find! I'll be watching for updates.
Offline Kuprito
« Reply #11 on: May 03, 2011, 05:13:07 AM »
Same caliper:
OZ Ultraleggera 19"
Rotora 4p front
Brembo 4p rear
LV Brace
« Reply #12 on: May 03, 2011, 07:54:33 AM »
Maybe it is too early in the morning to fully understand some things. So -
Which end of the car is this on - front or rear? The answer to THAT will mean a couple more questions.
« Reply #13 on: May 03, 2011, 07:57:30 AM »
Same caliper:
Carlos, you don't like powdercoat?
Offline Kuprito
« Reply #14 on: May 03, 2011, 08:01:00 AM »
I did not open this topic to get any advice... I know what I need and what I want. Nobody like me knows what I am looking for.
This is something like how to.
Read, I wrote what end of car is this twice.
OZ Ultraleggera 19"
Rotora 4p front
Brembo 4p rear
LV Brace
Offline Kuprito
« Reply #15 on: May 03, 2011, 08:01:56 AM »
Not needed Antonio, just caliper paint.
OZ Ultraleggera 19"
Rotora 4p front
Brembo 4p rear
LV Brace
« Reply #16 on: May 03, 2011, 08:05:36 AM »
gotcha!
how many layers did you use when painting?
Offline Kuprito
« Reply #17 on: May 03, 2011, 02:45:18 PM »
2 red layers + 1 gloss
OZ Ultraleggera 19"
Rotora 4p front
Brembo 4p rear
LV Brace
« Reply #18 on: May 03, 2011, 04:20:02 PM »
This is probably too late, but if you get the upright/hub carrier off again, can you see if you can fit a C5 or C6 hub on ?
« Reply #19 on: May 03, 2011, 05:25:50 PM »
So I missed it. Shoot me !!!!!!!!!!!!!!!!!
Offline BigSal
« Reply #20 on: May 03, 2011, 06:03:34 PM »
Shoot him! it's SnapOnBob season!!!
My sincere apologies to Bugs Bunny and Daffy Duck...
Performance Mods
Westers Tune v5.2
DDMWorks Extreme BackBone
DDMWorks Charge Tubes
kappaSPRINGS by Eibach
Dejon Cold Air Intake
DeJon BOV Spring
Solo High Flow Cat
Solo Mach Shorty Cat Back
Show Mods
lil' Chromies
Lambo Doors
JPM Sown Seatbelt Loops
DeepBlueGXP Front Light mod
Debadged except for
« Reply #21 on: May 03, 2011, 10:23:14 PM »
Holy crap. Apologies to THEM?  :slap:   :rofl: :rofl: :rofl: :rofl: :rofl: :rofl:
« Reply #22 on: May 04, 2011, 01:47:04 AM »
Daffy Duck?  Bugs Bunny?
Who has the furry fetish?
« Reply #23 on: May 04, 2011, 08:20:38 AM »
That just BEGS for a response, but the ones I have are not "G" rated !!!!!!!!!!!!!!!   :o :D
« Reply #24 on: May 04, 2011, 08:54:07 AM »
Is that really ?
