Author Topic: What did you do to your Kappa today - Part 2  (Read 1539360 times)
0 Members and 13 Guests are viewing this topic.
« Reply #1675 on: July 16, 2012, 09:19:41 PM »
Duck
We unfortunately don't have the proper smileys to translate
 :lol: :lol: :lol:
« Reply #1676 on: July 16, 2012, 10:52:45 PM »
Ok, I did this stuff yesterday...
Washed the car in the rain and cleaned up the engine bay.  However, I don't know if we got a little hail here or what but I found a ding in my hood.  No missing paint, just a ding and I'm pretty sure it wasn't there when I started washing the car.  I am not pleased.  Anyone have a good dent doc?  That's 2 dings in my hood now. :(
Here is the engine bay pic with the rest of the caps installed...as of yesterday:
Damn...I missed a spot!
And here is the other item I installed.  Thank you Mr. Miller. :)
Little sucker is bright!
I still need to replace the insulation, but I have a hell of a time getting those stupid retainers out!  I was standing in the trunk playing tug of war with them.  The insulation might have to wait for someone to take pity on me this weekend! :lol:
« Last Edit: July 16, 2012, 10:58:57 PM by ihawk95 »
« Reply #1677 on: July 16, 2012, 10:58:05 PM »
Plasti dipped the wheels last night.
Nice job!  Glad to know what my stock wheels will look like when I paint them!
You should black the rest of your car out! ;)
« Reply #1678 on: July 16, 2012, 11:03:51 PM »
That engine bay looks too clean to be your car
 :poke:
We have some good dent people in PA around where I live.  They normally charge $125 a body panel.
« Reply #1679 on: July 16, 2012, 11:11:38 PM »
 :poke:
That used to be my engine bay all the time!  Sad huh? :(
Hmm...good info to know about the dent doc.  I'm gonna ask around here.  If I don't find anyone decent, then I'll travel.  The snow shovel dent has been there long enough.  Drives me up a wall!
Offline blackbirdracing
  • Kappa Newb
« Reply #1680 on: July 16, 2012, 11:21:10 PM »
It's just plasti dip.  I suppose I could do the windshield surround.  Not much else to black out. Head lights were already swapped out for the street editions.
« Reply #1681 on: July 16, 2012, 11:25:34 PM »
I noticed that on the headlights.  That's what I'm talking about.  Although I wonder how the surround would look in plastidip with the black gloss of the car.  Hmmm.  The grill is fine so it might work.  I want to do the door handles, but I'm waiting for the report on how they hold up!
  • Kappa Newb
« Reply #1682 on: July 16, 2012, 11:52:10 PM »
I'm going to swap to the cobalt door handles. I think they come pre-finished in what ever color...
I was also worried about how the would hold up with the dip.
« Reply #1683 on: July 17, 2012, 01:30:32 AM »
Dip holds fine if you get a quality coat all around.
« Reply #1684 on: July 17, 2012, 08:54:14 AM »
Ran some new grounds in 4 AWG, high temp, power cable.  A proper 4 gauge crimper tool makes life so much easier.  Used a die grinder with a mild abrasive pad to clean the ground surfaces, and covered everything with dielectric grease.
Then I started with the oil pressure sender installation for the oil pressure gauge I'm going to install.  Should have been a 5 minute job, as it is easily accessible.  I was informed that it would it the sender at the front of the engine with the harness coming off the back of it, through the hole in the expanded foam surround.  Should have been a 5 minute job.  As I started removing the sender I quickly realized it is actually a fuel pressure sender.  As I backed it off a few turns I started hearing a hissing noise.  There's no way there would be that much residual oil pressure in the system.  I backed it off again to see if I could get a whiff of gas, and yup, it was gas.
I started snooping around until I found the real oil pressure sender just above the starter.  What a 8itch to get to.  I started trying to remove it with the starter in place.  And by the way, the power connection to the starter is not 100% insulated.  A stubby wrench made contact with said exposed terminal, which led to the battery disconnect.  Managed to get the stock sender out.  There was no way I could install the aftermarket sender with the required adapter for our block if the starter was in place.  Had to remove the starter.  With that out of the way, I got the adapter in nice and easy.  But then when I tried to get the starter bolt back in, it was so awkward to get to, in such a tight place, I found it much easier to remove the rubber elbow under the throttle body and the intercooler pipe, to access the bolt with some extensions and a universal joint, then it was the get the bolt in from under the car.
Started up the car to check for oil leaks, seems to be fine.  Between the adapter and the block was a hollow copper with an internal rubber, crush washer, and between the sender and the adapter, I used some high temp teflon tape.  If anyone is ever interested in putting in an oil pressure sender, let me know, and I'll do what I can to help.
The boost sensor sender install was much happily much less exciting.  Basically put a 'T' into the line coming off the intercooler pipe near the MAF.
Interestingly, drove the car around after, and even with no oil pressure sender plugged into its harness, no warning of low oil pressure.  WTF?!  Anyone got any input on this one?
The LN5 and I have been told the LNF also has 3 access bolts on the exhaust side of the engine.  All three lead into the oil feed system and can be used to install an aftermarket pressure switch.
Offline MomsSol
« Reply #1685 on: July 17, 2012, 09:25:36 AM »
How long do you want me to wait on that report?  So far so good, 1st wash will be this Friday ...... I'll be changing out the red stripe for a burgundy one.
True Lady Gearhead :)
« Reply #1686 on: July 17, 2012, 09:48:43 AM »
Quick question; Is there a valid reason for me to drive from MI to NY to have the Solo installed?  Reason I'm asking is when I placed my order I asked if they had any recommended install shop in my area and was told no but the NY location (Muffler Man?) has done several installations.  Now I'm thinking it may not be my smartest move to drive all the way to NY for Solo installation when we have several shops in my hometown.  Currently waiting for Solo to call back and ask, problem is if its already been shipped I'm basically committed to drive there.
Nevermind, Solo called back and Jeff said it hadn't been shipped it to NY yet so will be shipping it here.
« Last Edit: July 17, 2012, 10:09:19 AM by ChopTop »
« Reply #1687 on: July 17, 2012, 01:17:27 PM »
If you get the system installed in their shop, from my experience, they will install it for free but the trip might not make that worthwhile.
« Reply #1688 on: July 17, 2012, 02:02:30 PM »
A decent Muffler shop would be able to install this for you.
Or,
someone could help install it at the Mod Meet if you are coming.
« Reply #1689 on: July 17, 2012, 06:18:32 PM »
You were washing the Car in the Rain and you don't know if it was Hailing .. Must have been a (1) hail stone Storm they are Rare in any Location.
« Reply #1690 on: July 17, 2012, 06:46:29 PM »
:rofl:  Bobby with the jokes!!!
« Reply #1691 on: July 17, 2012, 08:06:45 PM »
Ha ha!  OK, always a story with me.  So I go out to wash the car.  Get everything ready, start in and realize the sky is looking a little dark to the west.  I figure I can beat it and if it rains, who cares because I'll just rinse it off again quick after the storm goes through.  Which worked really well, I might add!  Anyway, I went inside right before the heavy stuff came down.  It poured twice and I heard a lot of pinging on the house during the 2nd downpour.  I looked out and didn't really see anything, other than it was raining really hard and the rain drops were very big, but who knows.  There is no paint missing from that ding and it's right on the top of the hood.  I would think if it were a rock, it would have left some sort of mark.  And I saw it right away when I came back out to rinse off the car, so I'm sure I would have seen it while I was washing it.
I don't know...my hood seems to dent easy.  Who else gets a dent in their hood from a snow shovel that was resting against the garage wall in the winter.  I opened up the garage one day to start the car during the winter and the shovel is resting against the hood.  I don't think anything of it because the garage was pretty narrow.  I grab the shovel and sure enough...dent!  How the hell?? :(
« Reply #1692 on: July 17, 2012, 09:52:20 PM »
ihawk95   I understand , the door on my PT just tapped the rear fender and there was a dent . Any way now we know what happened. A friend of mine in Baltimore does that type of dent Repair work for the New car dealers.seems like the panels on our car are very thin . I hope you can get it fixed OK.
« Reply #1693 on: July 17, 2012, 09:59:01 PM »
Oh ya I got a phone call from the repair shop today. They approved a new set of Wheels and (2) tires for my car .Told them to Piick a set that he would use and in Black. Almost done now .
« Reply #1694 on: July 17, 2012, 10:03:10 PM »
Me too because it looks like it's gonna be a PITA.  I already took it in after the shovel mark and the guy wasn't real excited about messing with it.
« Reply #1695 on: July 17, 2012, 10:03:25 PM »
Good news Bobby!
« Reply #1696 on: July 17, 2012, 11:07:35 PM »
 They look at it then they call people like The Dent Doctor to fix it and then give the Bill to us . Like they fixed them selfs.
« Reply #1697 on: July 18, 2012, 08:33:41 AM »
My understanding is that metal ability to dent has a direct correlation on if the metal was tempered (heated) to make it stronger.  Gets into the chemistry/metallurgical fields, and since many of our body panels used the hydroformed (water pressure) method the tensile strength of the metal probably played a significant role.
BTW, just so you know you can buy hail damage car covers for your car.
http://www.google.com/imgres?q=hail+damage+car+cover&num=10&um=1&hl=en&safe=active&biw=1132&bih=727&tbm=isch&tbnid=hQ6taWAq8vu7tM:&imgrefurl=http://www.hail-guardian.com/&docid=CK7LZVjP-uFg5M&imgurl=http://www.hail-guardian.com/wp-content/uploads/2012/01/HG-Home-Page-Image-with-Titles.jpg&w=300&h=300&ei=jKwGUOqRK8PF6wGyhtn6CA&zoom=1&iact=hc&vpx=116&vpy=224&dur=4260&hovh=225&hovw=225&tx=136&ty=140&sig=104888017032367732925&sqi=2&page=1&tbnh=135&tbnw=136&start=0&ndsp=15&ved=1t:429,r:10,s:0,i:110
Hail Guardian storage, email alerts, installation and activation_Sept 2011 (Prototype unit)
« Last Edit: July 18, 2012, 08:37:06 AM by ChopTop »
« Reply #1698 on: July 19, 2012, 05:35:08 AM »
you are correct...your first photo does show the fuel pressure sensor in the center.
« Reply #1699 on: July 19, 2012, 09:00:28 AM »
I'm adding a dual zone radar proximity detector to the existing shock alarm.  I figure no use in getting a glass break detector, since it's a convertible, and it's just another sensitive sensor to false.  I'm sure like with other proximity detectors, I will have to adjust it from time to time.
This shows where I put mine.  I have the outer 'zone' triggering a squarker (audible alarm buzzer thingy), and the inner zone triggering the car's alarm.  Haven't had to adjust it since I put it in.  http://www.kappaperformance.com/forum/index.php/topic,5620
