Author Topic: What did you do to your Kappa today - Part 2  (Read 1542175 times)
0 Members and 6 Guests are viewing this topic.
« Reply #1650 on: July 14, 2012, 05:40:52 PM »
Everything looked ok under my car when I was in Asheville.  Which is surprising seeing as how both front splash guards scraped those stupid speed bumps everytime!
Elff...this is exactly why I rarely drive my car around Cleveland.  The roads are horrible!  Except the metroparks...those are decent.  But I never drive it to work for a ton of reasons
1.  I have to park it in a gravel lot across the street except on Fridays.
2.  We have a ton of construction going on and people have been getting nails and screws in their tires like crazy lately.
3. The roads are horrible.  There is a huge pothole on W 25th and I-71 that is unavoidable in the morning.  My G6 doesn't even like it.  I can't believe I haven't ruined a rim on it yet.  And the on ramp to I-90 and I-71 are both full of potholes.
Offline EarthNTX
« Reply #1651 on: July 14, 2012, 05:42:49 PM »
There is a clip in the center at the front that has to be popped off, plus the two tabs at either side of the front that slide under the piece in front.
I'll try that again. Thanks :)
Ride it like you mean it.
Offline MARVIC 1
« Reply #1652 on: July 14, 2012, 06:28:00 PM »
I can probably swap coil overs with the best of them on our cars now.
I've got this down to a science.
Then you need to make a trip down to Florida, I just can't seem to separate the ball joints to install my new coilovers....:banghead: That doesn't sounds right. :huh:
« Reply #1653 on: July 14, 2012, 10:16:20 PM »
You do not need to touch the ball joints on the rear, only the tierod.
Then slide the shock spring out towards the rear of the car
Use a pry bar if needed.
For the front, I always disconnect the top one.  Undo the nut with a ratcheting 18mm wrench and hold the bolt with an Allen key/socket
Then use a pickle fork to separate the ball joint
« Reply #1654 on: July 15, 2012, 05:04:58 AM »
No, I wasn't talking about Cartmann. I was talking about a guy from Chicago who probably hasn't posted on the forums for at least 3 years. And yeah, if you're gonna be a passenger in your own car, then you would notice this. Me, I still had plenty of leg room, but I'm short.
« Reply #1655 on: July 15, 2012, 04:08:29 PM »
You know Elff with that shroud modified like that you will never be able to legally run in SCCA solo events.  :poke:
 :coffee:
« Reply #1656 on: July 16, 2012, 07:03:03 AM »
Got coupe stripped!  WooHoo!  Shot camera vid but for whatever reason metallic doesn't really show up.  But think Sea Bass boat Silver Metallic, metallic really sparkles likes a crushed disco ball.
« Reply #1657 on: July 16, 2012, 09:11:54 AM »
Success
I railed my Sky down a couple of roads that have some very weird road noise, bumps, dips and potholes.
While the car leaned significantly more than with the B&Gs, I did not bottom out once and as such was able to maintain a faster speed.
I can also leave and enter my driveway again without scraping.
That's actually really nice
« Reply #1658 on: July 16, 2012, 09:13:03 AM »
Wuss!
« Reply #1659 on: July 16, 2012, 09:20:38 AM »
Sorry, but I like non leaking intercoolers.
« Reply #1660 on: July 16, 2012, 10:07:29 AM »
How is the hip?
« Reply #1661 on: July 16, 2012, 11:02:57 AM »
Not great.  I get a nice big needle stuck in me on friday which apparently will hurt so much they are giving me an epidural.
FUN FUN FUN
That's so they can clear out as much of the inflammation as possible to get an accurate MRI of the damage.
« Reply #1662 on: July 16, 2012, 02:28:49 PM »
FUN FUN FUN
Ouch!  If you don't mind my asking, was this due to a genetic/inherited problem, or due to activity/use?
« Reply #1663 on: July 16, 2012, 02:57:03 PM »
Genetic after all he is an elff :poke:
« Reply #1664 on: July 16, 2012, 03:09:10 PM »
Ordered Solo Mach Shorty (for the GXP coupe), will be driving it to NY for install in 2 weeks.  :yay:
Question; Can the 2.0 exhaust system be transferred to our 2.4?  Understand 2.4 would need dual exhaust valance.  Just seems a waste to lose a perfectly good 2.0 exhaust system and not reuse.
« Reply #1665 on: July 16, 2012, 03:42:20 PM »
A number of NA owners have the LNF exhaust.  Sounds really good, too.
« Reply #1666 on: July 16, 2012, 03:43:40 PM »
 :slap: :slap:
Carbon
This is what is occurring in my hips
http://www.hipfai.com/
If you look in the box labelled MIXED, that is what I had in the right hip and my left hip has what is in the box labelled CAM.
If you look at the type of athletes who tend to get affected by this, I have been a soccer player, Lacrosse Player and Martial Artist.
So it's a combination of my bones just growing wrong and all the activity.  I stopped playing soccer and doing martial arts due to this.
I had an FAO in December to fix the right hip.  Somehow the Cartilage is damaged again and we are trying to figure out why.  I am hoping this will be an easy fix, I can continue with my exercise and weight loss and then get the Left hip done over the winter.
Then, if all goes well, after ANOTHER HALF YEAR OF RECOVERY, maybe, just maybe, I can get back to being the Athlete I used to be.
ChopTop
Any Good Muffler shop can weld the 2.0 Exhaust to the 2.4 Exhaust, anywhere along the straight pipe.  Like you said, you just need a second opening for the driver side exhaust tip.
Offline Yogi
« Reply #1667 on: July 16, 2012, 03:57:45 PM »
Elff - Sorry to hear bout your problems!  I hope that you can get it all worked out and back to normal.
Good luck   :thumbs:
Yogi
2008 Saturn Sky Red Line
2.0 Turbo LNF
5 Speed Manual
Snowflake Wheels
Monsoon Sound System
Leather Seats
« Reply #1668 on: July 16, 2012, 06:47:35 PM »
As long as I am good enough to drive the Sky, I can't complain all that much.
Speaking of which, my dog was cracking me up tonight.   I took her to the Vet for some Blood Work.
During the drive there, I noticed that she is so used to my driving and the Sky that she counter leans against the turns to maintain her balance.
I verified it on the way home, and she is as smooth as  Motor GP rider transitioning from side to side.
And When I look at her, she gives me this smile that says she knows exactly what she is doing.
Offline EarthNTX
« Reply #1669 on: July 16, 2012, 06:48:24 PM »
 :lol:  that's so cute!
Offline DaveOC
  • Running Wisconsin
« Reply #1670 on: July 16, 2012, 07:01:20 PM »
This reminds me of "The Art Of Racing In The Rain" by Garth Stein.    If you have never read it, it's worth the time to read it.
Aggressive #000741
Offline baconbits
« Reply #1671 on: July 16, 2012, 07:06:16 PM »
Elff I had a Sheppard Rotti that use to do the exact same thing cept in a 3/4 ton GM truck..I use to say "corner Sam" and he would set up for it...he also loved to climb ladders had to keep them laid down or else he would be up on the garage roof..
Offline blackbirdracing
  • Kappa Newb
« Reply #1672 on: July 16, 2012, 08:14:47 PM »
Plasti dipped the wheels last night.
« Reply #1673 on: July 16, 2012, 08:31:46 PM »
Looks sharp!
Offline brad_wp
« Reply #1674 on: July 16, 2012, 08:32:06 PM »
ROTFLMAO!!!!
Sent from my Inspire 4G
Brad
'08 Redline Manual
Polar White, Black on Black, Single Disc Monsoon
"Fly Navy"
