Author Topic: I put my new Sky black and red drivers door panel on  (Read 9806 times)
Offline melissadunagan
« on: August 14, 2011, 06:00:12 PM »
  This turn out to be a bigger job than I though it would be. I had to lenthen the wires going to the power mittor switch. There or nine wires to the switch. I think they or 22 gage wires. I made it about a foot longer. There or two tan with white strip,and two gray with a white strip, so mark them before you cut them so to make sure you get the right wires back to each other. The othe hard part that I have was getting the little trim piece off behine the door opening handle. Looks like it has to be remove from the back but there is very little room to get it. I broke mine. I am going to drill a small hole in the trim piece before I put it back on. As there is a screw that has to be remove there to let the door panel come off. Also the cable that goes to the door handle is hard to remove, and the clip is very easy to brake, as I broke mine. Hope this helps some one else that is panning to do this.
Ferret Lady
Re: I put my new Sky black and red drivers door panel on
« Reply #1 on: August 14, 2011, 07:24:06 PM »
melissadunagan ; No pictures of the work done . Kelu's 1st rule
     :ttiwwp:
« Reply #2 on: August 14, 2011, 07:30:35 PM »
  Sorry I have no ideal how to post pictures so I did not take any.
Ferret Lady
Offline EarthNTX
« Reply #3 on: August 14, 2011, 08:03:52 PM »
 :cryin:
Ride it like you mean it.
« Reply #4 on: August 14, 2011, 08:49:06 PM »
You can apply a piece of velcro to the back of it and that will hold it back on.
« Reply #5 on: August 14, 2011, 09:13:41 PM »
 You would have to brake off the tangs, or you would still not get it off.
  Also it look like I will have to get a Saturn Sky door pull trim piece as the Solstice does not seem to fit the Sky door panels.
Ferret Lady
« Reply #6 on: August 14, 2011, 10:11:04 PM »
Hmmm.  Maybe you were doing it wrong.  Many folks have had the door panels off (for sound deadening, for instance) and I haven't heard of anyone breaking the cable clip.  It just slides up and off.
Getting it back on now, that can be a pain - if you don't know the trick: http://www.kappaperformance.com/forum/index.php/topic,4722.msg62488.html#msg62488
« Reply #7 on: August 14, 2011, 11:32:29 PM »
I think he's talking about the pictures! :lol:
« Reply #8 on: August 15, 2011, 11:25:56 AM »
No, I was referring to the small panel that covers the screw beneath the door release handle.
If you want to post photos here, you have to do one of two things.  Become a supporting member where you can upload them directly to the post or upload your photos to a photo hosting site and past the IMG code for the photo you want to post.
Offline GeeTeeOh!
« Reply #9 on: August 15, 2011, 04:44:49 PM »
Selling your Solstice Door Panels?
« Reply #10 on: August 16, 2011, 04:36:07 AM »
  I had not though about selling them but if some one wants to buy them I would.  If some one wants them they need to speek up soon before I throw away the boxes that the new ones came in.
Ferret Lady
« Reply #11 on: August 16, 2011, 04:51:13 AM »
  Oh by the way how do you change the colar of the lights on the switchs. The switchs have the plastic melted to the door panel. I have read about this and I was thinking they where able to that the switchs apart. I am not seeing how. Does any one here know? Also I have new Sky steering wheel that I will be putting on, and what colar or the lights on it? And if they or white how do you change them?
               Thanks
Ferret Lady
« Reply #12 on: August 16, 2011, 08:58:21 AM »
Not sure about the door lock switches, but the window switches should pop out (if the Sky's are the same as the Sol's). See: http://www.kappaperformance.com/forum/index.php/topic,4722.msg62487.html#msg62487
The Sky steering wheel lights are Amber.  Easy just to swap your Sol's switches with the Sky ones - I know they are the same. (I got a Sky Bluetooth switch pad for my Sol)
Offline MomsSol
« Reply #13 on: August 16, 2011, 09:05:17 AM »
Even if you don't sell them the box makes an excellent storage container to protect them from getting scratched.  Keep the boxes either way.
True Lady Gearhead :)
« Reply #14 on: August 16, 2011, 11:11:25 AM »
  Hello TomatoSoup  How do the steering wheel switchs come out?
               Thanks
Ferret Lady
« Reply #15 on: August 16, 2011, 11:53:14 AM »
Presuming the Air Bag is out (off the wheel) there's just a single screw on each side (IIRC).  Undo the screw and the switch pivots out.  Easy to see once you have it in front of you. See my post at: http://www.kappaperformance.com/forum/index.php/topic,5377.msg74051.html#msg74051
Also see Joe's photos here: http://www.kappaperformance.com/forum/index.php/topic,2052.msg23078.html#msg23078
