Author Topic: Wires in A Pillar  (Read 7399 times)
Offline solid
Wires in A Pillar
« on: February 07, 2009, 07:22:39 PM »
So...
I'm was in middle of installing a Boost gauge and ran into a problem.
where can I get the v12 power from?
I see Black, Dark Green, Blue, Yellow, Gray, and light Green.
I did read about wiring from a passenger side fuse box (more I read about it, more confused I got, I'm no electrician :( ), but couldn't find anything about an A-pillar wires.
thanks in advance!
Live everyday like shark week!
Re: Wires in A Pillar
« Reply #1 on: February 07, 2009, 07:37:08 PM »
Blue wire with white or gray stripe.  You can always buy a 2$ test lead and probe it...
Offline solid
« Reply #2 on: February 07, 2009, 08:11:16 PM »
Ahh thank you. I'm assuming that black wire is the ground?  I will need to get the wire probe for sure
« Reply #3 on: February 07, 2009, 11:14:51 PM »
Black is ground!
Offline solid
« Reply #4 on: February 08, 2009, 01:56:36 AM »
Black is ground!
Awesome! thank you very much, that's why I love this forum!!! :)
Offline solid
« Reply #5 on: February 08, 2009, 02:24:01 PM »
I tapped into a blue wire. But now the light in the gauge is always on.   Any idea to dimm it when ignition is off? please?? I also read to tap into a wires under the upper carpet of passenger side, is that the only way?
« Last Edit: February 08, 2009, 03:38:44 PM by solid »
« Reply #6 on: February 08, 2009, 04:20:06 PM »
Oh, sorry, I didn't realize what you needed.  That is a 12V hot all the time.  you need to run a fuse tap (fuse with a wire coming off it) to fuse #18 in the passenger foot well. It is a spare slot but is controlled via the accessories (only when the key is on).
Offline solid
« Reply #7 on: February 08, 2009, 04:24:37 PM »
thank you so much.  I can't wait to try it soon.   :woohoo:
« Last Edit: February 08, 2009, 09:51:01 PM by solid »
Offline solid
« Reply #8 on: February 09, 2009, 07:40:03 PM »
is this it?
so I used a black wire in a pillar as ground, and used this for the power, connect to the #18 fuse in passenger foot well?
« Reply #9 on: February 09, 2009, 07:59:09 PM »
correct :thumbs:
« Reply #10 on: February 09, 2009, 11:38:10 PM »
Or you could do what I did when I added my TPMS, '07s didn't come with this feature.  I found a blank spot in the passenger foot well circuit box that was switched and then I got a connector from my dealer so that I could add a circuit to the box (this was actually the hardest part of the install).  Installed a fuse and the whole thing looks like a factory installed option.
Offline solid
« Reply #11 on: February 09, 2009, 11:50:03 PM »
Just to make sure what's going on here.  But isn't that the same thing as DeepBlueGXP has suggested? or is it something different?  Plus, could you elaborate on the connector that you got from the dealer?
« Reply #12 on: February 10, 2009, 12:49:12 AM »
Sure thing
What DBG said to do and I have no problem with it is to use a device that looks like a fuse but has a wire that comes off of it and goes to what ever device you are adding.  This just slips into the fuse box like an ordinary fuse and then has a wire on the fuse side of the box.
What I did was added a wire to the wire side of the box and then just plugged in a fuse like all the other circuits have.  I have some pictures of this I think, I will have to look for them.  Basically I just used an empty circuit in the fuse box.  The boxes are designed for multiple applications so I found a unused circuit that was switched by the ignition and then added a wire.  You will have to have a special connector to do this and getting one was the big hang up but after talking to the service manager I was able to get some.  I think that I might still have the part number for the connectors, if so I will post that info as well.
So if you installed the circuit like DBG said it would be real easy to tell that something was added just by taking the cover off the fuse box and looking for the wire that was present.  In my install you would never know that I added something unless you started chasing circuits and found my car has an extra fuse that it shouldn't.
Offline solid
« Reply #13 on: February 10, 2009, 08:01:32 AM »
Sure thing
Thank you for the info, part number and few pictures of your setup will be interesting to see.
Hmm, I connected the power line to that fuse adaptor and plugged it to #18 by the passenger footwell (with ground wired to a black wire by A-pillar), but my gauge doesn't light up.  I'll give it an another try.  I hope I didn't blow the LED away.
Are there any other spot I can connect to? or just #18?
« Last Edit: February 10, 2009, 08:08:29 AM by solid »
« Reply #14 on: February 10, 2009, 09:51:01 AM »
Turn your tap around, only one side of the plug is hot!!! and only when the key is on.  We've used this many times on different cars.
Offline solid
« Reply #15 on: February 10, 2009, 10:38:00 AM »
Ahhhh. ok, i'll try that.
Offline solid
« Reply #16 on: February 10, 2009, 01:33:31 PM »
Alright, I got almost everything worked out.
I got a final question.
For that fuse-wire adaptor (picture above), I had to plug a 2amp fuse on it to complete the circuit of the adaptor (see the two slots in the picture?), I used the 2amp fuse from #17 since it was labled "empty", and plugged the whole setup in #18.
Gauge lights up without problem now.
Now, should I worry about not having anything plugged in #17?
Car starts fine, didn't drive yet, I just wanted to make sure it's okay to do that fuse setup.
« Reply #17 on: February 10, 2009, 03:05:47 PM »
If it was labeled "empty", then it was a spare fuse
Offline solid
« Reply #18 on: February 10, 2009, 04:36:40 PM »
COOL!! THAT'S IT! project is done and finished
thank you so much for your help.
now I know how to tap into the fuse box ^^ (only for #18).
« Reply #19 on: February 10, 2009, 04:58:51 PM »
Glad I could help!!!
Offline U4EA
« Reply #20 on: October 21, 2009, 07:45:16 AM »
Do you have this part # ? Would be much appreciated! Thanks!
« Reply #21 on: October 21, 2009, 11:16:19 PM »
I'm not sure if these are the part numbers or not, the tech gave me copies of the manual but he didn't highlight the numbers that he used to get the terminals from the parts dept.
There are two different numbers and as I recall they were two different sizes due to the size of the wire needed for the load.
I hope these are the numbers:
12110844/4
12110842/4
If you have a shop manual for the car these numbers are called out under the body control module (BCM) C3, page 11-14 of the service manual.
Hope this helps
Offline U4EA
« Reply #22 on: October 22, 2009, 07:25:42 AM »
Thanks Sol Asylum, yes both are good #s as terminals. 10 pack and 5 pack respectively. Since it appears I'm going to keep this car I do need to invest in the shop manuals.
Where did you mount your TPMS read out?
« Reply #23 on: October 22, 2009, 01:58:31 PM »
I modded the bracket with some suction cups and have it attached to the windshield next to the review mirror.
