so the other day i came home from work and noticed that my car while idling it was running between 205 and 210 mostly staying 207. now it was 50 degrees out and when i took it for a drive again it dropped immediately to about 198-201. when it idles and is at 207ish the fan is on full speed but blowing cool/cold air and the top coolant hose is fairly soft. i replaced all the coolant and the water pump about 3k miles ago. im thinking maybe i have a thermostat that is sticking shut some or not opening all the way or properly. jw has anyone else experienced this and if so what was the issue. also there are no leaks.
