Author Topic: running temp is high not sure why..  (Read 3778 times)
Offline hammy221
« on: September 17, 2011, 05:47:56 AM »
so the other day i came home from work and noticed that my car while idling it was running between 205 and 210 mostly staying 207. now it was 50 degrees out and when i took it for a drive again it dropped immediately to about 198-201. when it idles and is at 207ish the fan is on full speed but blowing cool/cold air and the top coolant hose is fairly soft. i replaced all the coolant and the water pump about 3k miles ago. im  thinking maybe i have a thermostat that is sticking shut some or not opening all the way or properly. jw has anyone else experienced this and if so what was the issue. also there are no leaks.
Re: running temp is high not sure why..
« Reply #1 on: September 17, 2011, 09:29:55 AM »
Did you bleed the air out of it?
« Reply #2 on: September 17, 2011, 12:11:50 PM »
I second the idea of bleeding the system.  I'd at least attempt that before replacing parts.
DDM has a nice video detailing it in their sponsor section.
Offline hammy221
« Reply #3 on: September 17, 2011, 02:17:36 PM »
i did bleed the air when i did the water pump and haven't had an issue for a few months until recently but i guess it dont hurt to do it again
« Reply #4 on: September 18, 2011, 08:40:55 AM »
I had to bleed it twice because there was still air in there after the first time.  After the second time, my temps are usually around 194-198.
Offline hammy221
« Reply #5 on: September 18, 2011, 11:45:05 PM »
i guess ill give it another try thanks for the advice guys
Offline BigSal
« Reply #6 on: September 19, 2011, 01:02:12 PM »
I agree with all above on another bleeding. DDM video/procedure was great. It took me about 4-5 minuted with top hose squeezing (calm down GJ   :rofl:) to get all of the air out of the system.
BigSal
Performance Mods
Westers Tune v5.2
DDMWorks Extreme BackBone
DDMWorks Charge Tubes
kappaSPRINGS by Eibach
Dejon Cold Air Intake
DeJon BOV Spring
Solo High Flow Cat
Solo Mach Shorty Cat Back
Show Mods
lil' Chromies
Lambo Doors
JPM Sown Seatbelt Loops
DeepBlueGXP Front Light mod
Debadged except for
