Author Topic: Boost level with GMPP tune  (Read 5488 times)
Offline TC-GXP
« on: October 07, 2011, 11:41:49 PM »
My car has the GMPP tune, CAI and exhaust and I noticed it goes as high as 18 lbs of boost and then tapers off to 15 lbs after it upshifts a few times. I believe I read it should be more like 21-22 lbs with this tune so should I adjust the wastegate rod a little or will the computer just lower it back down to 18 lbs or less again? I'm thinking if I shorten the rod the boost will go up and stay there but I figured I'd ask the experts. I checked all the clamps and there's no obvious boost leaks anywhere. I'm running 93 octane Sunoco Ultra and don't hear any knock but I don't have an OBD2 reading device yet so I can't see what the computer "sees".
Tony
2009 Solstice GXP roadster
Agressive victory red, automatic, GMPP exh, GMPP air intake, GMPP turbo upgrade kit, Kapparoo pouches and Attic, DDM Extreme Backbone brace and Pro Beam, LV Kappa front chassis brace, Opel antenna, ZOK sway bars
Re: Boost level with GMPP tune
« Reply #1 on: October 08, 2011, 03:47:04 AM »
18 lbs overvoost and 15 lbs boost sounds like factory numbers and not GMPP. before doing any wastegate mods, i believe u should take it to the dealer and have them re write the gmpp tune on your ecm..
Offline 2.0 tspeed
« Reply #2 on: October 08, 2011, 10:08:48 AM »
do not touch the wg
2013 verano turbo
« Reply #3 on: October 08, 2011, 12:14:20 PM »
It completely depends on the atmospheric conditions.
People in higher altitudes will need higher PSI to get the 290hp at the crank whereas people in lower altitudes won't need so much.
If you are concerned about it running properly, or just want to have fun verifying it, take it to a Dyno.
On a Dynojet you should get about 260-265hp at the rear wheels
I believe you are actually ok.  I rarely if ever hit 20psi on my GMPP tune
« Reply #4 on: October 08, 2011, 01:31:34 PM »
Also the Automatic may behave a little different and your readings are actually fine.
However as elff said altitude definitely plays a part on the numbers display on the DIC.
Offline TC-GXP
« Reply #5 on: October 08, 2011, 01:44:11 PM »
That makes sense, I'm pretty close to sea level where I am. I'd like to dyno it sometime so this gives me another reason to. Just out if curiosity if someone had removed the GM tune and put back the stock tune wouldn't it run weird with the Bosch  3 bar MAP sensors in it? The car runs perfectly.
Tony
« Reply #6 on: October 08, 2011, 02:33:03 PM »
You would need to put the 2bar sensors back on with the stock tune.
Offline TC-GXP
« Reply #7 on: October 09, 2011, 08:35:59 AM »
That's what I thought. Thanks!
By the way I checked the elevation in my area and it's 100 ft. I knew it was pretty low....
Tony
« Reply #8 on: October 09, 2011, 09:04:31 AM »
Cool
Now get out there and have some fun with your new tune
« Reply #9 on: October 09, 2011, 10:33:47 AM »
Now after looking up the ( Sea Level ) for Maryland . It says the mean Sea Level is 350ft above sea level for MD . Just saying for anyone that was not sure that uses the tunes . " It is Amazing what you can find out and LEARN if you look Things UP".
« Reply #10 on: October 09, 2011, 12:16:28 PM »
Actually Bobby if you look up the information for your closest airport you can find the elevation for your area in this case Nottingham MD is close to Martin State airport and a quick check shows that the elevation there is 23 ft.
http://en.wikipedia.org/wiki/Martin_State_Airport
« Reply #11 on: October 09, 2011, 04:46:39 PM »
You can also use Google Earth. It seems pretty accurate.
« Reply #12 on: October 10, 2011, 08:36:40 AM »
You can run 3 Bar sensors with the stock tune. It's a new trend on the HPT forums. I'm going to actually start doing this one day.
« Reply #13 on: October 10, 2011, 09:24:16 AM »
What's the benefit of doing that Kenny?
« Reply #14 on: October 10, 2011, 09:25:35 AM »
