Author Topic: coolant leak  (Read 5016 times)
Offline smacmoyle
coolant leak
« on: November 01, 2011, 03:23:10 PM »
2008 2.4 Solstice with 80,000 miles is using about 12 ounces of coolant every 2 weeks. cant find a leak any where. Temp is fine. Any ideas where it could be going ??? I see alot of water pump write ups. is this why the pumps get changed ??
Thanks,
Scott
Offline Buzzardt
Re: coolant leak
« Reply #1 on: November 01, 2011, 04:21:11 PM »
Make sure your oil is not milky looking (water and oil) and check for white smoke out the tail pipe. Other than that I am at a loss.
Good luck.
Re: coolant leak
« Reply #2 on: November 01, 2011, 10:44:14 PM »
My coolant leak was very difficult too find. See thread here.
 http://www.kappaperformance.com/forum/index.php/topic,7976.0.html
Offline diamoney
Re: coolant leak
« Reply #3 on: November 01, 2011, 11:18:54 PM »
I saw evidence of a leak in  many areas.  When I got it up on a lift with a strong light I still had to be in the exactly right position to see the weep hole at the bottom of the w/p to verify that was the source.
#000600 S/C
158000+ miles
'07 GXP T/C+
0-100 in what?
Offline smacmoyle
Re: coolant leak
« Reply #4 on: November 02, 2011, 09:39:16 AM »
Thanks for the fast replys. I will bet its weeping out the pump. I will get it up in the air and have a look. I will make my best pitch at a warranty repair.
Re: coolant leak
« Reply #5 on: November 03, 2011, 11:59:20 PM »
It is a warranty repair. Covered for 100k miles. I found mine by finding the residue on the front right sub frame. Like a red gooey residue. Not coolant looking at all. Have the person look in the vicinity of the right motor mount. That is the easiest place to find leakage buildup.
