Author Topic: engine code  (Read 12089 times)
engine code
« on: March 29, 2012, 04:43:13 PM »
Got an engine light today PO 236 my reader says Turbo/super Boost sensor A . could this be oil on sensor contact? Crimped connector. Help  :banghead:
Re: engine code
« Reply #1 on: March 29, 2012, 05:51:59 PM »
Isn't that one of the codes that pops up when there is a bad connection with the GMPP crimp connections?
Re: engine code
« Reply #2 on: March 29, 2012, 07:41:12 PM »
Yes it is Tazz.
How are the gmpp traps wired?
If they are using the butt connectors, I would suggest removing them and soldering them together first.
Otherwise you could chase your tails for months like I did
Re: engine code
« Reply #3 on: March 29, 2012, 07:42:45 PM »
elves have multiple tails?
Re: engine code
« Reply #4 on: March 29, 2012, 07:50:26 PM »
I have one in the front too.
Re: engine code
« Reply #5 on: March 29, 2012, 07:54:53 PM »
:lol:  Which is longer?
Re: engine code
« Reply #6 on: March 29, 2012, 07:56:19 PM »
Definitely the mushroom stamper
Re: engine code
« Reply #7 on: March 29, 2012, 08:13:47 PM »
It's all about the girth ;)
Re: engine code
« Reply #8 on: March 29, 2012, 08:16:00 PM »
KP drift team is on full patrol tonight
Re: Re: engine code
« Reply #9 on: March 29, 2012, 08:47:16 PM »
True. It's not about whether or not you hit bottom!
Offline EarthNTX
Re: engine code
« Reply #10 on: March 29, 2012, 09:00:10 PM »
Are y'all havin' fun? huh? :poke:
Ride it like you mean it.
Re: engine code
« Reply #11 on: March 29, 2012, 09:02:28 PM »
Well this Thread started out about Wire connectors . Will check them Friday after work or Saturday morning. What is it that you clean the sensors with . I gased up Sunday morning and I think I grabed the regular Handle . would that make it throw a code?
(Girth) Thats around the Belly , I don't fish and only one tail But like an Elephant or Corvair or even a VW Bug.
 Now whats that stuff called and I did put 87 oct in it.
« Last Edit: March 29, 2012, 09:08:51 PM by 1 LIL NDN »
Re: Re: engine code
« Reply #12 on: March 29, 2012, 09:09:50 PM »
Yikes! You put regular in your car?
Sent from my DROID X2 using Tapatalk
Re: engine code
« Reply #13 on: March 29, 2012, 09:15:01 PM »
Yep  I think I did .Found  aslip on the seat said 87
Re: engine code
« Reply #14 on: March 29, 2012, 09:30:58 PM »
The GMPP tune requires 91
I'd highly suggest that you get some octane booster before you start knocking.
Re: engine code
« Reply #15 on: March 29, 2012, 09:46:05 PM »
Never tried it but I would think that since the standard GMPP tune can pull 8* dynamic and 12* RPM based he would still be OK as long as he doesnt go mashing the pedal.  The car would not have the power since it would be pulling timimg and the ECM adjust really quick but who knows.  Could be why he's throwing that code since it's limiting boost.
Re: engine code
« Reply #16 on: March 29, 2012, 10:39:11 PM »
Dave   I have a bottle of 104 that I had for my PT only about a month old . I put it in and (picked the car up and shook around a few times <--- was feeling my Oats   :bs: )  . will let it sit tonight and go fill her up on Friday w/93   :rofl:  mao
Re: engine code
« Reply #17 on: March 29, 2012, 10:54:33 PM »
Good deal.
Do you have something you can clear the code with to make sure it stays away?
Re: engine code
« Reply #18 on: March 29, 2012, 11:24:17 PM »
Yes I do. But gonna check the sensor wires first before I go to far . Will let you know what I find ,whats that spray they use on the sensors? want to pick some up to  clean them off.
Re: engine code
« Reply #19 on: March 30, 2012, 08:46:32 AM »
I use MAF cleaner for the MAF.  I've never cleaned the MAP sensors.
Re: engine code
« Reply #20 on: March 30, 2012, 11:26:43 AM »
I have... same process as the MAF...
Step one, get electronics cleaner/MAF cleaner
Step two, remove sensor
Step three, Spray the unholy living  :censor: out of it... allow it to dry for a minute.
Step four, replace sensor.
Repeat process as deemed necessary
Offline dengel
Re: engine code
« Reply #21 on: March 30, 2012, 11:44:32 AM »
Could have been the gas.  I took my Solstice (GXP with GMPP tune) on a business trip to Virginia a few weeks ago.  Before heading home, I filled the gas tank with the "premium" gas available in VA - 92 Octane with some percentage of Ethanol.  Had a CEL and code all the way home (forget the code but it had something to do with the fuel system).  Filled up the tank when I reached NJ with the local premium which my car is used to drinking, 93 Octane and no Ethanol - CEL went out and no codes since.
Offline HotScott
Re: engine code
« Reply #22 on: March 30, 2012, 01:26:43 PM »
Bobby, what did you do to your car now!  I have MAF / Electronics Cleaner at my house if you want to borrow some.
•Werks Tune
  •Performance Werks V8 525hp Conversion
  •T-56 6 Speed Manual
  •Spec 2+ Clutch
  •Custom Stainless Dual Exhaust
  •BC Racing Coilovers
  •Rear Brace
  • A/C and Cruise
  •Forgestar F14 wheels and Pilot Sport tires
Re: engine code
« Reply #23 on: March 30, 2012, 05:32:40 PM »
Scott      I gased up sunday morning and didn't watch what I was doing. I put regular 87 or 89 in the car . Got6 an engine light yesterday . Last night I put a can of octane boost in and also found the gas cap was loose. But I'm going up the garage and checking the connectors on the GMPP sensors to see if they are soldered or Crimped. I got a can of sensor spray going to clean them while I'm at it .  Didn't do anything LOL
Re: engine code
« Reply #24 on: March 30, 2012, 05:45:48 PM »
When travelling down to VA, NC, SC and TN look for exits with Shell Stations and use their 93.  It's considered top tier gas and if I can help it, its the only gas I put in my sky
