Sol I'm starting to think that now as well. Critter I checked the rubber vent tube off the engine and it was surprisingly clean, very clean, no trace of any oil in it, same as the charge pipes. Because of the work DDM did it does look like there are a lot of new connections made into the harness from the MAF. Most electrical taped. We all know what happens with electrical tape when it gets hot so maybe there is an issue in one of those connections.
Thinking back the issue always happens when the engine is running hot, last time I was at idle for 20 minutes, hot day, A/C on sitting at the border waiting to cross and it came on, gave me a code. In times past at low speeds , hot humid days usually when I notice it. Although admittedly it shows up to me when the transmissions is downshifting hard into 1st and 2nd so of course I notice it when I am going slower. I don't always get a engine light , in fact most times I don't so I know the MAF has had a problem when the TCM module starts acting up and the downshift issue starts. The mystery of computer code, clean the MAF the transmission goes back to shifting properly. I do see the engine codes though for "lean on bank 1" usually when I check with the reader even if the engine light isn't on.
So maybe it is a electrical connection giving the ECM a bad reading , then the TCM is affected, heat being in play, then I take it out , move it around , cool it down. There is a wrapped wire coming from a harness that it looks like DDM had to rig into the new MAF set up, guess I may have to start looking at this. I did take the MAF connection at the top of it and re-seat it. This may take some time to experiment with.
Appreciate the input guys, any other thoughts on it would be helpful !!
Added this after thinking about it - I have had situations when I first encountered this that the engine sat overnight before I cleaned the MAF (because I consulted the BB's here on what to do with this issue) and at start up with a cold engine the condition with the hard down shifting still existed , then I cleaned the MAF and it went away immediately. Now this could be the cleaning of the MAF or moving the MAF and wiring around to clean it that eliminated the condition. It does suggest that cooling it down alone wasn't enough to fix the problem.
